Question about Ricoh Aficio Office Equipment & Supplies
I have code sc542 on my ricoh aficio sp 3400n, how do I reset?\
All lights are lit, turned off and on, no difference. lost power last night but printer was plugged into surg protector.
4 Suggested Answers
mimranon
  • 72 Answers
SOURCE: Ricoh Aficio SP 420dn shows SC542 error code after
Hi dear pls take you printer to service center
Thank you
Imran
Pls rank as possible have nice day
Posted on Apr 20, 2009
SOURCE: Ricoh Aficio SP 3400n Toner
Try to turn off, then remove the toner and then press and hold the power button for 5 secs. Make sure to insert the toner properly. Then reinsert cables and then turn on the printer. If the alert light continues to flash, consult Ricoh for possible repair...
Posted on Nov 24, 2010
bosegautam11
SOURCE: Ricoh Aficio SP C411dn error SC542
Ricoh Aficio error SC542
Posted on Sep 26, 2011
Service manual for Ricoh Aficio SP 5200 DN with all parts and troubleshooting
go to service mode.
press up and down button. then press ok. go to SP5810 and reset.
Jan 29, 2017 | Ricoh Aficio SP 5200 DN Laser Printer
What is error code SC542 for ricoh aficio 9005?
Ricoh Aficio MP2510, 3010 Error code sc542 on Lanier ...
? 6:08
https://www.youtube.com/watch?v=58MQVyjfDyg
Sep 3, 2013 - Uploaded by Used .Copier
Are you getting Error Code sc542 on your Ricoh, Lanier,Savin or Gestetner copiers? ... Ricoh Aficio 1022 ...
How to reset Ricoh Error Code sc542 sc546 sc548 problem ...
? 2:41
https://www.youtube.com/watch?v=3CnGl1Ytp34
Sep 21, 2015 - Uploaded by Copier Liquidation Center
How to reset Ricoh Error Code sc542 sc546 sc548 problem ...Ricoh Aficio copiers : AFICIO 1013 F
Dec 02, 2015 | Ricoh Aficio Office Equipment & Supplies
My printer ricoh aficio SP 3400SF is showing service call error code SC542. kindly help to come out of this error. \r\nvr babu
FOR RICOH AFICIO SP 3400SF follow below steps.
1. To access Service Mode, On Control Panel press following buttons one
by one immediately.
Cancel Button (Red) ---> 1 (Numeric One) ---> 0 (Numeric zero) ---> 7
(Numeric Seven) ---> Copy Button (Green)
2. In Service Menu you will find Engine reset Menu. In that you can reset
SC 545 in Fuser Reset Menu. And you can also reset SC 542.
Jun 23, 2011 | Ricoh Aficio AP3800C Laser Printer
Error code sc542 on ricoh spc222sf?????????????????
Press the red CLEAR/STOP key till you hear the little beep. Press 1 0 7 Press the green COLOR START key. The display changes into MAINTENANCE MODE Use arrow keys to go to ENGINE MAINTENANCE and hit Ok Use the arrow keys and select FUSER SC RESET and hit Ok Hit OK again at the Execute prompt.
Once it is done executing the reset, power the unit off and on.
If the error comes back again, it is likely a real hardware problem and you may need to replace some components.
Sep 30, 2010 | Ricoh Aficio SP C222SF All-In-One Laser...
Ricoh aficio 2232c sc542 error
SC542 means that the thermistor hasn't detected right temperature in given time.
Often you only have to reset service code.
Try this reset:
  • Press and hold online + escape, then power on.
  • Use up and down arrow keys to select SP2
  • Press Enter
  • Use up and down arror to locate SP5
  • Press Enter
  • Use up and down arrow keys to select 810
  • Press Enter
  • Confirm the selection
  • Power off and on.
from http://www.fortc.com/2007/06/17/ricoh-cl4000dn-error-code-sc542/ here is another service procedure:
  • Press Mode(The Yellow Button)
  • Enter 107
  • Press STOP Button for 3 second (RED Button)
  • Copy Sp
  • 5810#
  • Execute
  • Power Off
  • Power On
Nov 19, 2009 | Ricoh Aficio 2015 Copier
Aficio Ricoh 350e - Warm up error (fuser)
Hi first you have to check the fusing unit and all give you how to reset the error enter the sp mode c 107 ca then use the sp np 5-801 then pres okouble-
shooting
SC542: Fusing temperature warming-up error
-Definition- [A]
The fusing temperature does not reach the fusing standby temperature within
125 seconds after the main power switch is turned on.
- Possible causes -·
Fusing thermistor defective or out of position
· Fusing lamp open
· Fusing thermofuse open
· BICU defective
· Power supply board defective
· Poor fusing unit connection
if the proplem not solved contact me ill give you more detales . thanks
May 22, 2008 | Ricoh Aficio 450 Copier
189 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
