Question about Acer Aspire 3050-1150 (LX.AXE0Y.118) PC Notebook
Acer 3050 power up problem
When i first plug in the computer powers up on its own then quickly shuts down. then it refuses to start using the power button.
ACER ASPIRE ONE
Unplug the computer, hold the power button down until the laptop shuts down, then remove the battery. Plug in the charger, and try powering up. If all is okay, shut it back down, unplug it, and reinstall the battery. Then, plug it in and let it fully charge. Restart it, plugged in and with the battery installed. Good luck.
Apr 06, 2014 | Acer Aspire One PC Notebook
When I go to start menu to shut down and press shut down it will just reboot and will ot shut down
Step 1:
Laptop computers can be wonderful devices, except when the need to troubleshoot arises. Acer laptops are no different. A quick way to fix many problems with an Acer laptop running Windows is to reset it to factory settings. Resetting your Acer laptop to factory settings can eliminate slow operation, registry problems, virus problems and spyware issues. What's more, a factory reset of your laptop may reduce the need for a full reinstallation of Windows.
Back up all necessary data to an external device such as a disk, flash drive or hard drive Make sure all programs are closed and shut down your Acer laptop. Detach any external hardware such as an external hard drive or printer. Press the Power button to boot your Acer laptop. Press "Alt-F10" on your keyboard when the Acer screen appears at the start of the boot-up process. Wait a moment while Windows loads the reset files. Select "Restore System from factory default" in the Acer eRecovery Management window. Click "Next" on the next screen to continue. Click "Next" on the following destination information window. This will pop up a notice telling you that resetting your Acer laptop will erase all data and restore the laptop to its original settings and configuration. Click "OK" in the notice window to proceed with resetting your Acer laptop. Wait while your Acer laptop is reset to factory settings.
Feb 20, 2013 | Acer TravelMate 2300 Notebook
My acer all in one z5600 runs for awhile and then shuts down very annoying!!!
Start by cleaning the fan or fans, heatsink, and vents, you may have to open the computer. When you open, you may as well replace the Thermal Paste on the CPU and Graphics Chips. Overheating will cause shut downs, heat sensors set to detect a set temp. will shut down to protect vital components from heat related damage. ALSO, Open Control Panel, Power Options, set to High Performance, open Change plan settings, under Plugged In, set both to Never, open Advanced Power settings, go through thr Advanced settings set Sleep and Hibernate to Never, Adjust to your preference. It's a good idea to Always shut down your computer when not in use, it will last longer and a reboot everyday will reset the machine. Make sure ALL your Windows and Acer Updates are current.
Feb 15, 2013 | Acer Z5600 All-in-one 23" 4gb 2.8ghz 500gb...
Need a recovery disc for acer aspire 5738g
Acers have recovery disks built in.
To access the feature. Shut down the computer.
Start it, As soon as you press power to start it.
Hold down the ALT key, and quickly tap F10
This will load the factory restore mode, which will do a complete recovery on your acer.
KittyTech
Mar 09, 2011 | Acer Computers & Internet
Computer has not power
If the power supply is bad replace it.
If the computer boots up for a second and then shuts down you can try the following method:
Remove the battery for a few minutes, put the battery back. Locate the connection to the power switch, turn computer on and then quickly disconnect the power switch
. If you have a battery with a power switch you can use that instead. Otherwise if this method solves your problem you will have to turn the computer on and off by plugging and unplugging it.
If you are going to get a new power supply, look for one that has a power switch on it.
Dec 14, 2010 | Acer Power FG (APFGUP5161) PC Desktop
I tried to shut down the computer and when it was taking too long, pulled the plug. Now it refuses to start up again, the power button won't work
Check your power box whether its working when you plugged in the cable, it will be checked if the fan of the power box is working and gets on when u plugged in the power cable
Sep 22, 2010 | Acer Computers & Internet
My touchpad doesn't work when the charger is plugged in. ANy reason for this?
acer aspire 3050 laptop will not power down nor will it boot up windows
Sep 14, 2010 | Acer Aspire 3050-1733 Notebook
I cannot get my settings in my asprie 3050 to change to boot from cd
  • Press Del or F2 immediately after powering on.
  • The BIOS on the Acer Altos 600 server uses the Ctrl+Alt+Esc key and the F1 key for advanced options.
  • Older Acer computers may use also use the F1 or Ctrl+Alt+Esc keys to access BIOS.
Mar 05, 2010 | Acer Aspire 3050-1733 Notebook
On boot up of a acer 3050 i get a black screen of death making me believe its a hard drive problem so i change the harddrive and i still get a black screen of death .it showed me the acer screen then it...
i had a similar problem with my acer aspire 4315 (witch i got for free because of this problem :D ) and i just reinstalled vista then it worked just fine
Dec 23, 2009 | Acer Aspire 3050 Notebook
3050 will not boot
Try a different power supply. Plug in the AC with the battery out.
Jan 18, 2008 | Acer Aspire 3050-1733 Notebook
Acer Aspire 3050-1150 (LX.AXE0Y.118) PC Notebook Logo
98 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
