Question about Frigidaire Affinity ATF7000E Front Load Washer
Frigidaire fafw4011lw error code 1.30
Error code 1.30 appears when I set wash cycle to normal, but when I switch to casual the appropriate time appears
  • warnerperry6
    warnerperry6 Apr 22, 2013
    The 1.30 appears in the time window on the washer for a normal wash cycle. When I switch from normal to casual or delicates the machine goes through the complete cycle. But I get nothing with the 1.30 setting.
  • Official Brand Answer
  • 4,342 Answers
Hello warnerperry6 - Based on the symptoms you are describing the unit could possibly either have a faulty User Interface Board or Main Control Board. You may try and reset the washer by disconnecting the power to the unit for up to 30 seconds by flipping the circuit breaker off and back on. This often clears most false error codes. If the error code persists, it would be advisable to contact an experienced appliance repair tech to assist further.
Posted on Apr 24, 2013
SOURCE: Affinity E21 error
E21 means "Not pumping out fast enough". Could be debris caught in the pump inlet sump or pump body.
a75737b.jpg Disconnect the inlet sump from the pump. Disconnect the outlet hose from the pump. Remove the (2) screws, one on each side, holding the pump housing to the washer base. Unplug the wires from the pump motor and lift the pump assembly out.
Posted on Feb 08, 2008
catriver
  • 878 Answers
SOURCE: Frigidaire front load washer (LTF600ES1) Error E20
holla, Im not showing a E20 code on the tech sheet. There is a E21. Water not draining fast enough. Try holding the start/pause and cancel key together for 3 seconds. The door lock, wash, rinse and final spin leds should light. Any error codes should be displayed when holding those keys. If you see a different error code, post it. If not, I would suspect a clogged pump...Catriver.
Posted on Aug 04, 2007
Master_Tech
  • 770 Answers
SOURCE: washing machine error code on Frigidaire ATF6000E
No E20 on that model# Heremis a list of the codes
Failure code Fault condition Check
E11 Fill time to long. Refer to test (1).
E13 Water leak in tub or air leak in air bell. Refer to test (2).
E21 Water not pumping out fast enough. Refer to test (3).
E23 Drain pump relay on control board failed. Replace control board orwire.
E24 Drain pump relay on control board failed. Replace control board orwire.
E31 Pressure sensor not communicating with control board. Refer to test (4).
E35 Pressure sensor indicates water overfill. Refer to test (5).
E36 Control board problem. Replace the control board.
E41 Control board thinks the door switch is open. Refer to test (7).
E43 Board communications problem. Replace the control board.
E44 Board communications problem. Replace the control board.
E45 Board communications problem. Replace the control board.
E46 Board communications problem. Replace the control board.
E47 Board thinks the door PTC circuit is open in spin. Refer to test (7)
E48 Board thinks the door PTC circuit is closed. Refer to test (7)
E52 Bad signal from tacho generator. Refer to test (8)
E56 Highmotor current. Refer to test (9)
E57 High current on inverter. Refer to test (9)
E58 High current on motor phase. Refer to test (9)
E59 No tacho signal for 3 seconds. Refer to test (10)
E5A High temperature on heat sink. Test first if bad replace
speed control board.
E5B High temperature on heat sink. Replace the speed control
board.
E5C High temperature on heat sink. Replace the speed control
board.
E5D Communication problem. Refer to test (11).
E5E Communication problem. Refer to test (11).
E5F Communication problem. Refer to test (11).
E66 Heating element relay failure. Refer to test (14).
E67 Input voltage on microprocessor incorrect. Refer to test (15).
E68 Current leakage to ground on heater or fuse opened. Refer to test (14).
E74 Wash temperature does not increase. PlaceNTC in correct position.
E75 Water temperature sensor circuit. Refer to test (12)
E76 NTC temperature for the cold water valve over the limits. Hot and cold water hoses
switched.
E82 Console control problem Replace the control board.
E83 Console control problem Replace the control board.
E91 Selector LEDs do not light up Refer to test (16)
E93 Console control problem Replace the control board.
E94 Console control problem Replace the control board.
E95 Communication error. Replace the control board.
Posted on Apr 01, 2008
  • 196 Answers
SOURCE: Washing Machine starts, squirts water, then stops.
E5E  IS FOR  Communication problem. THERE IS 100 %WIRE SHORTING SOMEWHERE.PLEASE CHECK OUT.
ALSO OTHER ERRORS Error code - Fault condition
E11 Fill time too long.
E14 Reed switch.
E31 Better models. Pressure sensor not communicating with control board.
E35 Better models. Pressure sensor indicates water overfill.
E42 Door remains locked after cycle is completed.
E43 Control board problem.
E44 Control board problem.
E45 Control board problem.
E46 Control board problem.
E55 Motor overheating.
E56 High motor current.
E75 Better models only. Water temperature sensor circuit.
E76 Better model only. NTC temperature for the cold water valve over the limits.
EB1 Incoming power frequency out of limits.
EB2 Incoming line voltage above 130 VAC.
EB3 Incoming line voltage below 90 VAC.
EF1 Clogged drain pump.
EF2 To much soap.
Posted on Nov 12, 2008
Macmarkus
  • 2605 Answers
SOURCE: My Frigidaire front load washer
Welcome to FixYa.
Based on what you've described,...you likely need a door lock/switch assembly. The closest I found to your model is actually CLTF2940ES0.
The door latch is likely the single most common fault (which prevent's any spin, and consequently drenching wet clothing at the end of the cycle) with the frigidaire/electrolux built washer's, aside from pump's being obstructed.
I think it fool's many people because the lock indicates it is energized on the panel, however the built in "monitor" switch inside the assembly fail's. I do see a lot of these particular machine's...unfortunately.
You should be able to purchase one at most local brick
Posted on Sep 05, 2010
What does e90 mean?
  • E90 Error - YouTube www.youtube.com/watch?v=IhHvw2K7XO0
    • BY D CUTHRELL
    • 3 MIN
    • 24K VIEWS
    • ADDED 2012-11-16
    Video embedded ยท E90 Error Code on Frigidaire Washer cleared with Hair Dryer.
  • Frigidaire E90 Error ' eHow www.ehow.com > Home > Home Appliances > Washer & Dryers Frigidaire E90 Error. Frigidaire front-loading washing machines offer a control panel with keypads to set the desired wash cycle and any options, as well as monitor ...
  • Zanussi Washing Machine displays an error code E90.? howtomendit.com > ... > Household Appliances, Washing Machines How to fix anything. Free repair help - zanussi washing machine displays error code e90.
  • Dec 23, 2015 | Washing Machines
    My Frigidaire Stainless steel FFHB2740PS D.D. has an error code that reads 5H. What is wrong?
    I appreciate your inquiry, friend!
    Based off the information you have provided your Frigidaire dishwasher is displaying an error code of "5H". That appears to be the time remaining on your wash cycle. Typically an error code would be displayed with a number and an "E". What is the current problem with your dishwasher? Are you getting long wash times? There is a sensor inside of your dishwasher that reads how dirty the water is, if your dishwasher continues to circulate dirty water it will tell that sensor to continue washing. You may want to check your filter, which is located at the bottom of the tub, for any debris. Additionally, if your drain hose is restricted it may be providing dirty water back into your tub. I hope this information is helpful to some degree. -Matt
    Feb 24, 2015 | Frigidaire Dishwashers
    I have a 10 beep continous and showing e90 on my frigidaire washer, what will i do?
    E90. The E90 error code is not a common error but it may occur when the washing machine electronics get wet for some reason. This may happen if wet clothes are left in the washer for a prolonged period after the wash cycle ends or if the same load is washed repeatedly.
    Basic Reset
    One of the first steps whenever an error code appears on a Frigidaire washer is to perform a simple reset to the machine. To reset the washer, press and hold the "Cancel" button for 15 seconds. Then try to set a new wash cycle and press "Start." Note that any clothes that have finished washing should always be removed promptly after the cycle is done.
    Feb 26, 2014 | Frigidaire Washing Machines
    E90 error
    If the cancel button reset does not remove the E90 error code from the display, try a full power reset. To accomplish this type of reset, unplug the washing machine and wait 15 minutes or more. Then plug the washing machine back in and make a new wash selection. If the error code does not return, normal function may resume.
    Unfortunately, if the cancel button and/or full power reset attempts do not eliminate the E90 error code, it is very possible that the electronic control board will need to be replaced. Here is the board to order.
    Nov 29, 2012 | Frigidaire FAFW3577KR - Affinity 3.5 Cu....
    Not spin
    problem with motor control board
    Jul 08, 2012 | Frigidaire ATF6000ES Front Load Washer
    My washing maching is reading E20 and it is not washing. it seems to stop after a few minutes of washing and then it will read E20 and just continuosly beep
    Hello.
    Frigidaire front-loading washing machines have an electronic control panel where the wash cycle and any other wash options are selected, and the wash cycle is initiated and stopped, if necessary. The control panel also has indicator lights that show the washer status and will display an error code if there are issues with the washer. The "E20" error code indicates a possible pump problem.
    Blocked Pump
    One of the primary reasons why there may be an "E20" error code on a Frigidaire front-loading washing machine is if there is something blocking the pump. Disconnect the washing machine from the power and release the clips on each side to remove the front access panel. Set a container under the pump drain, which is located on the lower right side of the washing machine. Open the pump drain plug and allow it to drain. Clean out any debris that might be causing the obstruction, then close the drain plug. Close the access panel and restore power to the washer.
    Drain Hose
    If the drain hose is blocked or crimped, the water may not pump out fast enough, causing the pump error to appear on the display. Straighten out the drain hose in the rear of the washing machine and move it away from the washer if it's trapped between the wall and the washing machine.
    Oversudsing
    If too much detergent--or the wrong kind of detergent--is used in the washing machine, too many suds may result. This can overwhelm the drain and pump system, resulting in the error. Use only high efficiency (HE) laundry detergent with Frigidaire washing machines and follow specific instructions on the laundry container for the recommended amount of detergent. Run a drain cycle if there are excess suds in the washer to clear out the system.
    Pressure Switch or Control Boar
    The pressure switch may not be communicating properly with the control board, which can cause the E20 error to occur. The other possibility for the E20 error code is if the control board has failed entirely. Try to reset the washing machine by pressing "Stop/Cancel" and disconnecting the washing machine power cord. Wait 30 seconds, then restore power. Make a new cycle selection and press "Start" to see if the error code returns. If it does, turn off the washing machine and contact Frigidaire for repair.
    Thanks.
    Nov 08, 2011 | GE Energy Star WCVH6260F Front Load Washer
    Washer stopping mid-cycle with no error
    Remove the 3 screws at the bottom of the front panel under the washer door. Your filter door will be light brown. If you find a hose there it is to drain out excess water (water that could not be drained by your pump) After you have drained, unscrew the cap and remove all the junk inside. Have a large plastic bag to catch junk and water. Refit carefully after cleaning out. If not solved, something shd be blocking your pump, check this out. F-21 filter blocked.
    How abt a nice rating for the free help?
    Jan 04, 2009 | Whirlpool GHW9300 Duet Washer
    Kenmore elite he3 - door lock
    If sound like a lid switch issue. Open the top of the washer to get an access to the lid switch(located near the doorframe). Look for a loose wire or a broken switch. In case there is no loose wire or broken switch, you should replace the switch. Good luck!
    Sep 05, 2007 | Kenmore Elite 45986 Front Load Washer
    Frigidaire Affinity ATF7000E Front Load Washer Logo
    220 people viewed this question
    Top Frigidaire Washing Machines Experts
    Dan Webster
    Dan Webster
    Gerry Harvey
    Gerry Harvey
    Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
