Question about Panasonic KX-FHD351 Plain Paper Thermal transfer Fax
Faulty fax machine
My KX FP363 fax machine will not pick up paper unless i really push the paper hard. i suspect the problem is the roller that is visible when you lift the top covers,it looks pretty smooth, but i dont know how to get the roller out so that i can put in a new one. pliz help ...
  • 186 Answers
You can try cleaning that roller with a rag and some rubbing alcohol. Scrub it really good all the way around and that should help.
Posted on Aug 03, 2007
Document won't feed
Paper Pick up Rollers get dirty or worn out with the passage of time. Hence, require cleaning or replacement if worn out. In case you find them dirty use a soft, dry, lint free cloth to clean the rollers. Dont use chemicals as they may damage the rubber and plastic. However, if needed, you can use damp cloth or some cleaning liquid such as mild detergent of glass cleaner to damp the cloth. As you have posted your question under Panasonic KX-FL511 is would highlight the steps for it. Im Using a similar model KX-FL612
After lifting the top cover, you have to pull down the under part of it down to locate the rollers
Lift the top Cover, Locate the roller and clean them..
Hope it helps! Good Luck!
CreativeTECH
Dec 01, 2011 | Panasonic KX-FL511 Plain Paper Laser Fax
My fax machine is showing failed pickup error, what shall i do
CreativeTECH
May 03, 2011 | Panasonic KX-FL511 Plain Paper Laser Fax
Rollers will not grab the paper through to fax or copy. Please help!
You need to go and order the bottle called "roller rejuvination solution) from the website fixyourownprinter.com.
Cost under $20.00 and all you need to do is dab a qtip some of the solution and spread the solution from the qtip onto all the roller pin paper pickups.
Wait 10 minutes for it to dry and then test the fax again. It will now pick up single sheets afterwards.
Mar 19, 2010 | Panasonic KX-FL511 Plain Paper Laser Fax
Paper jam in Panasonic KX-FHD331
from person who sending fax ' please eng. hany use it good
Jul 07, 2009 | Panasonic KX-FHD331 Plain Paper Thermal...
Your document feed is separate from your received and report prints so that's why your reports are printing ok and the document feeder jams. When you open up the doc feeder and look inside the machine you will see a roller and above it on the cover that opens you will see a rubber pad. Clean both the roller and pad (in fact anything in there that is rubber) with a rubber cleaner, alcohol, or even soap and water on a cloth without it been dripping wet. You will probablt find that they are very dirty. The roller feeds the document in so that needs to be clean and the pad helps to keep all the other docs from feeding in at the same time and that should be very clean so it produces good friction.
How do you adjust paper feed on a panasonic kx-fl511fax/copier
One of two things is happening ok maybe three. If the machine thinks the size of the paper is not what u are using this could happen. Try:
http://pdf.textfiles.com/manuals/FAXMACHINES/Panasonic%20KX-FL511%20Laser%20Fax%20Machine.pdf
For any adjustment you could make.
The second is the paper is getting picked up a little late. The machine knows it did not print the entire page and finishes the job. Try cleaning the pick op roller.
The third is the page being sent to you is to long. This would likely be from one location only. There machine could be slipping when scanning and "extending" the page it is trying to send.
Hope this helps
Mar 10, 2009 | Panasonic KX-FL511 Plain Paper Laser Fax
Kx-fl511 wont pick up paper
try cleaning the paper pick up rollers with rubbing alcohol, use a cloth rag and the alcohol, try to rotate the rollers so that you can clean all the way around
Feb 26, 2008 | Panasonic KX-FL511 Plain Paper Laser Fax
Panasonic model no kx -FL 512cx fax machine
1-use fresh papers and fan it .
2-clean paper feed roller carefully.
3-confirm that no foregin object droped inside.(pins etc..)
4-confirm that gear train working propably and there is no broken gear.
Nov 15, 2006 | Panasonic KX-FL501 Plain Paper Laser Fax
Panasonic KX-FHD351 Plain Paper Thermal transfer Fax Logo
165 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
