Question about Mitsubishi WS-55511 55" Rear Projection Television
Won't power on
Power relay comes on then kicks out
  • Mitsubishi Master
  • 3,459 Answers
Check the Mitsubishi TV error codes using the instructions on www.TvRepairKits.com . Look on the tips page. If its a steady blink its likely the blinking light of death issue. If its a 2-2 pattern its likely a convergenec failure. Both are failry easy DIY tv fixes.
Posted on Apr 19, 2013
I have a 92 mustang lx 2.3 and it won't start. There is no fire at the plugs, and I can't hear the fuel pump kick on. The reset on the fuel pump is not popped out, so it is good. Any help woul
I would check the EEC relay and the fuel pump relay for power and ground signals first. Both circuits are controlled by the ignition key switch. The fuel pump should be powered for 3 seconds when you turn the key on.
Sep 29, 2012 | 1992 Ford Mustang
Cooling fan won't come on when I turn on the AC
Your bigger problem is the compressor not kicking in. The cooling fan is not coming on because there is not enough high side pressure to turn the fan on. I would start by checking power to the compressor, fuses and relays would be inspect. Check to make sure there is the proper charge of refridegerant in the system.
Jul 29, 2012 | 1988 Chevrolet Cavalier Z24
My 1995 saab 9000 is not getting power to the fuel pump the car has a new fuel pump fuel preasure regulator and filter now the pump won't kick in what coulld be wrong
You have a fuel pump relay,in the main fuse box under the dash,left hand it is listed as I right hand it is listed as F, check for power at the relay.
Apr 02, 2012 | 1995 Saab 9000
Bogging
Make sure the fuel pump is kicking on it won't hurt to check the relay but I have never seen one bad yet it could be the plug on the plug on the end of the wires that plugs on the pump this run hot and it burns the ends alot several fuel pumps are replaced because of this make sure you have power at the pump if you can't hear it run it will only stay powered for a few seconds and then kick off. so you might need someone to turn it on while someone checks the power.
Dec 29, 2011 | 2000 Pontiac Grand Am GT
I pulled out each relay one at a time and reseated them, so I know they're back in the right position and should be seated well, now the car won't start. All the instruments come on , just the car...
you owners manual will contain that information. In most cases like this for BMW it is the ignition switch, to clarify, not the ignition lock.
regards,
ZiM
Nov 08, 2011 | 1994 BMW 3 Series
My 95 lincoln town car will be fine and then all of a sudden I can't get it to crank. I have changed the fuel pump, the fuel filter, I have sparks because I got shocked. was taught a trick of pushing...
check all your rounds on the body, behind kick panels, and in engine compartment. The relays you hear clicking are the power relay whcih turns your engine computer on. The other relay is the fuel pump relay, which is turned on by the engine computer. start there, report back.
PS. When you press the gas pedal to the floor during cranking, it shuts off the fuel supply to clear a flooded engine.
Sep 08, 2011 | 1995 Lincoln Town Car
04 Kia Sorento, Compressor won't kick on. Fuses are good and refidgerent is full.
if the fuses are good and its full of freon. check the a/c relay in fuse box for power. the relay may be bad.
Jul 20, 2011 | 2004 Kia Sorento
Cooling fans won't kick on fuses are good fans are
Hi, Did you check the thermostat. If the thermostat is stuck and will not open properly, the fan will not come on. Have it checked out. Good luck.
Jun 07, 2011 | 1998 Cadillac DeVille
Mitsubishi WS-55511 55" Rear Projection Television Logo
44 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
