Question about Sub-Zero 632 / S
Ice maker drawer for sub-zero 632
Took drawer out to empty ice. can not get back in. rollers on sides came out of the guide tracks and I do not see how to put back.
  • Anonymous Mar 22, 2014
    i took to the ice maker drawer out to clean and cannot put it back in
  • Anonymous Mar 30, 2014
    I can't put the Ice drawer back in correctly
  • 175 Answers
Look at both those tracks on each side. its likely one or both are cracked or broken. Each one has 2 screws holding it in. To put the metal hange back in the tracks, you must get new tracks (if broken/cracked) then hold the2 tracks onto the bucket carriage...then stick thewhole thing in as an assembly, hen put the 4 screws back in. there are 2 more small screws way in the back (one on each side), but they do not have to be removed, only there to guide the racks in properly. these tracks are only about 7 bucks apeice, and shouldn't take long to chamge. Good Luck!
Posted on Aug 16, 2007
My sub zero ice smells bad like fish how di I remove and clean?
My ice maker smells like bad fish too! Emptied everything out. Cleaned every part, placed baking soda inside to absorb odors, but still stinks! Why? What more can I do?
Mar 07, 2011 | Sub-Zero 632 / S
Water leaks into ice maker bin
2 possible causes. 1) tehe tube is not inside of the ice maker. 2)the ice maker has acrack. better to call a tech
Mar 13, 2010 | Sub-Zero 632 / S
Ice in the bin on subzero 632 freezer is in clumps
if the ice maker leaking it's easy to replace, or may be just a water supply tube has been moved to the side
Oct 03, 2009 | Sub-Zero 632 / S
Water Leaks from Ice Maker of Sub-Zero 642
Sounds like the water inlet valve to icemaker is leaking - not closing completely after filling the tray. Rare, but possible. Prove it by shutting off icemaker arm or switch. If that is the cause, the drip will continue.
If dripping stops when I/M is off, then it is ice blockage in I/M fill tube and or diverter funnel at end of ice tray. Remove I/M, clean ice from both, and re-assemble.
Replacing that valve (water supply to refrig connects to it in the back) should solve it.
Jun 13, 2009 | Sub-Zero 30.1 cu. ft. Cabinet Depth...
I have the problem of the ice tray being covered with a layer of ice and very few cubes. I have a Sub Zero 632 ice maker that is 8.5 years old. Am I best off just replacing it or try to find out which part...
Try replacing the water filter if it has one, also it could be a bad door seal or may not be properly removing ice if it is a frost free model
Dec 16, 2008 | Sub-Zero 632 / S
Icemaker for sub zero 632 is not working, tray will not fill with water,there is no water in tray, It worked fine before hurrican, we emptied the frig and freezer and shut off the breaker for the hurr
check the water pressure ... if you have a filter in the line it may be restricting the pressure ... I had the same problem and a new filter fixed it
Nov 06, 2008 | Sub-Zero 632 / S
Ice drawer
Call the factory at 800-222-7820 they will walk you through it and send you a manual.
Oct 23, 2008 | Sub-Zero 632 / S
Cannot get ice drawer back on the track 500 series
Unfortunately, you need defrost freezer - put freezer thermostat on OFF. You possibly got broken ice tray or damaged sliders.Or leak in ice maker area. Till you defrost that compartment - no chance to pull tray out.
HTML clipboard_______________________________
http://www.subzerolosangeles.com
Los Angeles Sub-Zero refrigeration experts
Jul 23, 2008 | Sub-Zero 632 / S
Ice maker leaking
what is the model number of this fridge?
May 19, 2008 | Sub-Zero 632 / S
Sub zero 532 ice maker
When my repair tech came out, he showed me that the fill tube sometimes retracts toward the rear of the freezer. He simply pulled it forward with a pair of needle nose pliers until it rested in the delivery reservoir. This placement allows the detector to know when the tray is full and shut off; thus not overfilling the freezing tray and/or splashing additional water onto the freezer wall and into the ice cube drawer.
Nov 21, 2007 | Sub-Zero 632 / S
Sub-Zero 632 / S Logo
821 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
Sal De
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
