Question about Eureka Smartvac 4870 Bagged Upright Vacuum
Eureka air extreme hose assembly replacement - Eureka Smartvac 4870 Bagged Upright Vacuum
2 Suggested Answers
  • 10 Answers
SOURCE: Eureka 4870 hose assembly replacement
Boy, it's been awhile since I took one of these hoses off, but I think at least one of those plastic hose guide things has to come off in order to remove the hose. Those screws that look like they cannot be removed are probably torx screws which need a T20 torx scredriver that you can get at any hardware store. That is the most common size torx screw that Eureka uses.
Here is a link to the owner's manual in case you need any diagrams for getting the clear tubes off:
http://www.eureka.com/service/manuals/70750.pdf
Hope this helps. :-)
Posted on Oct 24, 2008
My eureka boss 5856 has suction through the hose, but the cyclone isn't spinning and it will not pick up anything. I have tried using it normally and with just the hose and it will not pick up.
Is the suction strong or weak?
Have you cleaned or replaced the filter?
A plugged filter will restrict air flow and cause vacuums to lose the ability to work properly.
Mar 10, 2017 | Eureka Vacuums
Eureka vacuum 4499 b manual
go to www.eureka.com and download for free.
God bless you
Jun 20, 2012 | Vacuums
My vacuum won't pick up anything how do I clean it out
1. Replace bag if needed.
2. Check hose/s for clogs. You'll need to detach both ends of the hose, check for visible clogs first, then try to roll a marble through the hose. If it doesn't go all the way through, there's obviously a clog that needs to be removed. Blowing it out with a machine that has an exhaust port usually works for me.
3. Check tube in powerhead and intake on vacuum for clogs. Remove if necessary.
4. Clean filter.
5. Leaky hoses will also cause extreme loss of airflow/suction. No fix for this, except to replace the hose.
Aug 23, 2010 | Eureka 12 Amp Capture Vacuum Upright...
Eureka Altima (yellow)
the hose under your dusting tool, remove that and you should see the clog. i had the same issue and also found that the smell that is emitted went away after i unclogged it
Aug 24, 2009 | Eureka Altima Upright Vacuum Model 2996AVS...
Missing Part(s) for Eureka Whirlwind 4496
The part number for the hose assembly for the 4496AV and AV-1 is 61028-1 if you call EUREKA customer support (1-800-282-2886), they will be able to tell you where your closest dealer is. They would also be able to give you the number on the extension hose (Bonus)
Apr 03, 2009 | Eureka Whirlwind 4496 Bagless Upright...
Oct 17, 2008 | Eureka Smartvac 4870 Bagged Upright Vacuum
Eureka the Boss Smart Vac. Hose has suction, but still isn't picking up. Weird.
Your belt is probably broken. Check your belt and make sure your brushroll has not seized. If both of those check out ok, (because the smartvac belt doesn't stretch,) the belt tensioner assembly may have gone bad.
-R
Aug 11, 2008 | Eureka Vacuums
Tear in Eureka Upright "The Boss" 4870
http://geeksquad.fixya.com/ThreadView.aspx?prdid=414813&thid=652524
Posted by kdunnett on Jun 07, 2008
I have a tear in the hose of an upright Eureka "The Boss" 4870 vacuum. I cannot find how to release the parts I need to get the hose out and put in a new hose (which I already have) I've searched the Eureka site and the owner's manual - nothing about how to replace the hose itself. Thanks in advance.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Eureka 431A Optima Bagless Upright Vacuum. In answer to your question, the owner’s manual may or may not give an example to install the hose only, but on most vacuums the hose sometimes will screw in to the hose cuff on both ends unless if it is a hose assm then it will then twist and turn. Check with the
Eureka website and have them send out a schematic and owner’s manual for you so that you can install your hose properly. Sometimes you have to place hose glue on the end of each side in order for the hose to screw in properly. the website address will be listed below and they certainly should supply you with the owners’ manual and maybe a schematic of the parts breakdown that also may help. If not; check with your local vacuum cleaner dealer in your area. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.eureka.com Customer Service 1-800-282-2886
Customer Service Dept for U.S.
Electrolux Home Care Products
P.O. Box 3900
Peoria. IL 61612
Hours of Operation
Monday thru Friday 8:00am to 7:30pm CST
Saturday and Sunday 10:00am to 6:30pm CST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 07, 2008 | Eureka 431A Optima Bagless Upright Vacuum
Eureka Smartvac 4870 Bagged Upright Vacuum Logo
Top Eureka Vacuums Experts
JoeVacs
Alan Matzke
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
