Question about Scotts Company 589384 Scotts 5000 SQFT Basic Broadcast Spreader 74101 ()
My scotts rotory spreader will not spin - Scotts Company 589384 Scotts 5000 SQFT Basic Broadcast Spreader 74101 ()
  • 822 Answers
The design is quite simple with one wheel driving a bevel gear in a gear box. If the wheel turns the axle shaft and the center pin in the spreader with the retainer/cotter pin does not turn it is likely something has failed in the gear box.
If both wheel spins and the axle does not turn than the drive wheel has disengaged the axle shaft and the cotter pin in the drive wheel needs to be replaced.
The compounds used in the spreaders are corrosive. Usually the gears and axle become bound due to corrosion. By oiling the bearings and wiggling the wheels they will free up,
.my scotts rotory spreader will not spin - 17780863-gjsi4oayl5rfr4vtc4ia3vae-5-0.jpg
Hope this helps?.
Posted on Mar 23, 2016
SOURCE: Spreader Settings
I called Scotts, and according to them the Edgeguard Deluxe uses the same settings as the SpeedyGreen 3000.
Posted on Jun 16, 2009
SOURCE: I have a Scotts Accugreen 3000 Drop Spreader. How
I found drop-rate tables at http://www.vigoro.com/ProductCategories/WeedInsectControl/SummerFertilizer/ProductDetails/Spreader+Settings.htm and http://www.bayeradvanced.com/media/productlabel/502840A_label.pdf. I don't know how accurate they are, but they are consistent with one another so I'm using them :)
Posted on Mar 21, 2010
SOURCE: need spreader settings for Scotts Speedy Green 3000
I found this:
For 18-24-12 %50 PPSCU
Product Application Rate:
*LBS PER 1000 SQFT 4
Coverage:
* 12000
Craftsman 3
Craftsman Drop 7
Cyclone 4.25
Earthway 14.25
Lely 4.5
LESCO HD-1 7
LESCO R-94 7.5
LESCO Rotary (80# & 100#) 15
Ortho 3
Precision 6
Red devil 6
Republic 3
Scott's Accu Green 7.25
Scott's Easy Green 26.25
Scott's R7- X F.5
Scott's R8-A J.5
Scott's Speedy Green 1000 6
Scott's Speedy Green 2000 7
Scott's Speedy Green 3000 6
Spyker 4.5
True Temper 1500 \ 5000 5.5
Vicon 28
Posted on Oct 24, 2010
jyackle5
  • 8197 Answers
SOURCE: The product I want to
May I ask what product you are using so I can help you better
Posted on Feb 20, 2011
  • 10 Answers
SOURCE: I just bought a new
I am sorry that neither spreader performed as they should have. This is very concerning to us, and we would like to get more information about the spreaders, if you still have 1 the manufacture date would be most helpful to us. It sounds like you could possibly have an over-application of the product as well. If you could call us at 1-800-543-8873, we would be happy to discuss this with you. Stacey at Scotts.
Posted on Jun 08, 2011
How do you check to see if calibration is exact
Usually the cheaper residential grade spreaders are not exact, nor do they need to be. The best way to tell how close it is, is to measure the area to be fertilized length and width. Multiply the two numbers (example: 30' x 40' = 1,200sq ft.) Adjust the spreader according to the reccomendations on the bag, and follow the directions exactly! Walk at a brisk pace around the perimeter once, and then back and forth spaceing your passes about 5' for rotory spreaders. Compare the amount of product you used, to the coverage chart on the bag. In my experience, most all lawn fertilizers are best spread at 50% to 60% open on your spreader setting adjuster. (example: If your spreader has settings of 1-15, I'd go with 8) Always follow the directions on the product container as best you can. Spreading a little too heavy, or a little too light is not going to hurt anything, so there is no reason to be concerned with exact calibration unless you are applying discriminative herbicides... Hope this helps!
Oct 08, 2011 | Scotts Company 589384 Scotts 5000 SQFT...
What setting should I use to set my pro spreder for pennington grasss seed?
I suggest a rotory spreader! How much turf are you planting? The rule of thumb is, you should see a light dusting of seed over the planting area before raking it in. You cannot put too much seed down, so remember that when spreading... The most important thing is, keep it wet for at least 30 days! Good luck!
Sep 18, 2011 | Scotts Company Scotts& Accugreeen 3000...
I ave a pro edgeguard broadcast spreader and the spinning wheel stopped functioning
Sorry to hear about the problems you are experiencing with your spreader. We may have replacement parts available. Please give us a call at 877-465-5160.
Hilary @Scotts
Sep 01, 2011 | Scotts Company Scotts Pro Edgeguard...
I have a new Scotts Classic Drop spreader and an old bag of 16-4-8 fertilizer. 2,130 SF of Zoysia Zeon lawn. According to my guidance I need to spread 6.5 # of the 16-4-8 fertilizer over the entire area....
Does the product you are using list any Scotts AccuGreen spreader settings? If so, you can safely use the spreader settings listed for the Scotts AccuGreen. If your product does not list any spreader settings, please give Scotts a call at 866-465-5160.
Hilary @Scotts
Aug 27, 2011 | Scotts Company Scotts Turf Builder Classic...
I have Scotts deluxe edge guard. How go check calibration
The Scotts Edgeguard Spreader is calibrated at the factory. This spreader cannot be calibrated, and shouldn't need to be. For further assistance, call Scotts at 877-465-5160
Hilary @ Scotts
Aug 14, 2011 | Scotts Company Scotts Lawns Edgeguard...
I HAVE A 10 YEAR OLD SPEEDY GREEN SPREADER. THE BALCK SPINNING WHEEL NO LONGER SPINS. WHAT DO I DO TO FIX?
I am sorry for the problem you are experiencing with your SpeedyGreen spreader. Sometimes we have replacement parts available. Please call Scotts at 800-543-8873 to check part availability. Hilary @Scotts.
Jul 02, 2011 | Scotts Company Garden
I buy Scotts fertilizer and use an earthway broadcast spreader.
add 10 - Scotts Turfbuilder spread at # 4 on a Scotts spreader should be on setting # 14 on an Earthway spreader.
Mar 28, 2010 | Earthway "Earthway" Medium Duty Commercial...
My scotts spreader propeller will not spin, i have used it twice and clean and maintain it well, when i went to push my yard yesterday the propeller wouldnt move, how do i solve this
Had same problem. Empty contents into a bucket, tip it over and push wheels together. Apparently right and left wheel axles pull out of the gearbox that run the propeller. I think if you can see the flat part of the axle, it has pulled out. Push the wheels together and the axle flat part will engage the gear box and spin the propeller.
Jul 08, 2009 | Scotts Company Scotts& Accugreeen 3000...
Scotts Company 589384 Scotts 5000 SQFT Basic Broadcast Spreader 74101 () Logo
601 people viewed this question
Top Scotts Company Garden Experts
john h
lnbn1975
jhnolson
Are you a Scotts Company Garden Expert? Answer questions, earn points and help others
