Question about Vehicle Parts & Accessories
2003 buick century, instrument cluster not visible
The digital mileage is no longer visible, also the transmission gear selector is not visible in the cluster
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 125 Answers
You probably have to replace the instrument cluster. I don't know if you can get this at a salvage yard or not but that's a good start.
Most likely you will have to replace the memory chip out of your old one and install it in the new one if you want to retain the miles you had on it.
Posted on Nov 01, 2013
Gear indicator light delays or does not light up
is it on the dash?...digital?..near the odometer?
your instrument cluster may need repair.
common problem.
check out ebay for "instrument cluster repair"
eg
http://shop.ebay.com/i.html?_nkw=instrument+cluster+repair&_sacat=0&_dmpt=Motors_Car_Truck_Parts_Accessories&_odkw=buick+century+instrument+cluster+repair&_osacat=0&_trksid=p3286.c0.m270.l1313
just do a little searching on ebay
let me know if this helps..
Apr 02, 2011 | 2003 Buick Century
The gear lights on the dash went out
same as my 2003 buick regal..
a common problem..
i sent mine to have it repaired. about $120 i think it was..
go to ebay. and search "instrument cluster repair"...or if you ar confident..go to youtube and search " buick instrument cluster repair"
let us know how it goes for ya
Jan 05, 2011 | 2002 Buick Century
My digital odometer and transmission indicator no
you will need to remove the cluster and have it repaired call your dealer they will know were to send it to repaired
Oct 31, 2009 | 1997 Buick Century
The gear shift indicator light and the odometer comes on intermittantly on my 2001 buick century
you will need the instrument cluster replaced. there are several companies that rebuild them, take it to a qualified repair shop, I'm sure they have a place they deal with to repair these. you will need to send yours in, as they usually want the old one first, to program mileage.
Oct 15, 2009 | 2001 Buick Century
I have a 2001 buick regal and on the instrument cluster, the P R N D L 2 and the odemeter are no longer able to be seen. Do I have to replace the whole thing?
Hi. The instrument cluster on this vehicle is not servicable. The prndl2 indicator is serviced with the whole unit. You can find a suitable replacement at your local salvage yard. Make sure mileage is close to the mileage you have or your state may require a odometer dis-closure statement. Hope this information helps!
Sep 12, 2009 | 2001 Buick Century
MY GEAR SHIFT AND MILEAGE WILL NOT LIGHT UP ON MY CAR
You need to have it repaired. Remove it and send it ti model electronics.
Aug 18, 2009 | 1997 Buick Century
The mileage lumination is no longer working
The problem is blown resistors on the instrument panal circut board. the dash needs to be removed and instrument cluster. Resistors are on the circut board. between six and ten..
May 14, 2009 | 2000 Buick Century
Odometer light out on a 01 buick century
I had this same problem and I removed the long plastic dash piece that goes from door to door (after removing other pieces which hold that one in place) and then tilt the steering wheel to the lowest position. turn the key and put the car in gear 1 then shut the car off -this enables you to remove the instrument cluster, which is held in by 4 screws. Unclip the back of the instrument cluster and remove the circuit board. On the board to the right of the speedometer are 4 resistors which look like tiny black cylinders -these need to be replaced (if they haven't already fallen off the circuit board). I was missing two and I just touched the other two with my finger and they fell off. I soldered onto the board 150 ohm, 1/8 watt resistors ($1.99 for a packof 5 at Radio Shack). This entire process took me about 30 minutes. I put everything back together in the reverse order I took it apart and my instrument cluster, odometer and gear-shift indicator works fine.
Nov 19, 2008 | 2001 Buick Century
1993 buick century instrument cluster
My experience has been they are not interchangeable - a number of sensors are usually unique to the specific cluster type installed.
Jul 01, 2017 | 1993 Buick Century
Odometer indicator not working for buick century custom 2001
You do not need to replace the instrument cluster! The fix for this is a pack of resistors that you can buy for $1.00 or less. Take the cluster right out and you'll see 4 resistors in the upper-right area on the back of the cluster. You can probably pick them off with your finger, they'll be so worn out. Once those are off, solder new ones on (carefully, don't burn your circuit board) and reassemble the dash board.
I fixed the odometer/gear selector light on my 2001 Century this way and there are videos on youtube that will walk you through the whole process.
Jul 09, 2008 | 2001 Buick Century
Vehicle Parts & Accessories Logo
50 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
