Question about Emerson THREADED SHAFT UP RATED - 1.00 HP - EB228
Remove older AO Smith 1102 motor - Emerson THREADED SHAFT UP RATED - 1.00 HP - EB228
  • 717 Answers
Is there a question here?
Rod
US Parts Center
Posted on Apr 19, 2013
I have a US!1102 AO Smith 1HP Pool Pump Motor. I was told to hold one end of the motor shaft and turn the Impeller clockwise to remove the impeller, I was told NOT to remove the nut at the center of the...
I have never taken this pump apart.
If I were in your position and I could move the impellar 1/8 turn, the next thing that I would do is carefully loosen the nut on the end of the shaft being careful that nothing else disassembles. Once this nut is loose say 2 turns, try the impellar again watching what is moving. It seems that the nut may have to be removed.
Also, I'm not sure which way the nut of the impellar rotates to remove, but you seem to have that under control since you have it moving already.
Gary
Feb 20, 2011 | A O Smith Motors A O Smith 1hp 115/230v Ur...
Motor is frozen.
Unlessyou can find an HVAC shop with a NOS motor for this unit you will notfind a drop in replacement. Even if you do get lucky and find a NOSmotor be prepared to pay nearly as much for it as you would a whole newevap cooler.
That said, there are motors out there that will work, but you're going to have to make them fit with custom mounts.
It'sstill a little spendy, especially if you want two speeds like theoriginal motor had, but you can get out for $80 or less if you'rewilling to settle for one speed (on/off).
boatandrvaccessories.com has a "Packard 40066" compressor motor for $69 plus $13 shipping. It may work but has only one speed.
Basicallywhat you're looking for is a "48 frame", 1/8 hp, direct drive,110-120v, 1075rpm, 1/2" shaft diameter and around 3" in length (to giveyou flexability when mounting), "totally enclosed" or "open drip-proof"housing (NOT "open"). Rotation can be either CW or CCW as you can mountthe motor on either side of the housing and some motors are reversable.If you've got the skill to custom make some mounts then you canprobably fudge some of these specs. The ones you can't change are the1/2" shaft and the RPM. Do not exceed 1075rpm. The blower assemblysimply can't be made to go much faster in that housing and if you tryyou will overheat the motor and burn it out very quickly (trust me onthis one!). Most of the cheap motors I've found are 208-230v and I justdon't see the point in having a small 220v PORTABLE evap cooler, that'sjust dumb.
After a LOT of online research I've found thefollowing motors that would be a suitable replacement, with all theabove mentioned specifications. I'm sure there are more, but crossreferencing this information for someone not in the business is trickyand time consuming.
AdobeAir 1/8 HP 115V Motor for Adobe MMB10A RF031095 $116.66
http://www.comfortgurus.com/product_info.php/cPath/25_142/products_id/7451
Emerson 4856 (k055srj4796722b) (www.emersonmotors.com)
A.O. Smith 136A (UH1036NB) (www.aosmithmotors.com)
Magnetek 136 (now owned by A.O. Smith - www.aosmithmotors.com)
Fasco D733 or D261 (fasco.com)
Marathon X924 (www.marathonelectric.com)
AdobeAir RK232A check acehardwaresuperstore.com
Emerson K55HXKZT-9867
Grainger.com is a good resource but they are expensive.
The motors listed are suitable replacements, but have only one speed, "ON" or "High".
Packard 40066 - 115v 1075rpm $69 - SINGLE SPEED
A.O. Smith 321P177
A.O. Smith 323P077
A.O. Smith 323P487
A.O. Smith 323P490
A.O. Smith 323P677
A.O. Smith U6521
A.O. Smith UH1016
A.O. Smith UH1026NB
A.O. Smith UH9034
A.O. Smith US1016
A.O. Smith US1016NB
A.O. Smith ORZ1026
Brownell MTG3206
Century C045A
Carrier HC37DX120
Emerson 9034
Fasco D834
Franklin 8736010170
Franklin 8715810230
Franklin 8735810180
GE 3081
GE 3206
GE 3950
Grainger 3M658
Grainger 3M800
Grainger 3M828
Grainger 3M829
Marathon X302
Mars 03950
Packard 70066
Packard 40066
R.E. Michael 1E521
Reznor 55682
Reznor 64678
Rotom R12177
Rotom R12834
Rotom UH9034
Trane MOT6195
Universal U136
Universal U177
Universal U380
Universal U566
Universal U730
Good reading for selecting a replacement motor:
http://www.aosmithmotors.com/WorkArea/DownloadAsset.aspx?id=13100
Isuppose that if you found a smoking deal on eBay for an "Open" typemotor you could try it, but I doubt it would last long and make damnsure that ****** is grounded well.
Jul 17, 2010 | AdobeAir Evaporative Cooler Direct Drive
How to remove motor AO Smith Model C48K2N143CIC
Take off the rear cover as to expose the capacitor. Remove capacitor. Place a 7/16 wrench on the shaft threw the opening where you removed the capacitor. Put a rag on the impeller and with a wrench turn it counterclockwise. It should come off easily. Make sure you replace the seals before reassembling
Jun 05, 2010 | A.O. Smith SQ1102 Pool Pump Motor
I HAVE AO SMITH MOTOR BL6414 HOW DO I WIRER IT UP
The BL6414 motor is shaded pole and does not require a capacitor.
Jul 12, 2009 | AO Smith A O Smith Motors Century 1hp 115v...
Emerson THREADED SHAFT UP RATED - 1.00 HP - EB228 Logo
21 people viewed this question
Top Emerson Pool & Spa Experts
Jay Finke
Jay Finke
Mike
Ian Kime
Ian Kime
Are you an Emerson Pool and Spa Expert? Answer questions, earn points and help others
