Question about Canon ImageRunner 1730iF Copier
Error Code E000020 - Canon ImageRunner 1730iF Copier
muleskinner2
  • 270 Answers
SOURCE: E000020-0000
This is a standard toner error code. This is a way for the copier to prevent the Developer Unit from being completely emptied of toner. Was the copier displaying to replace the toner cartridge? Remove the cartridge and see if it feels empty, if so replace the toner cartridge. The manual indicates that there is a blockage between the toner supply and the developer unit. I really don't think this is the case. This will really be a bear to fix if it is. The book doesn't indicate that the copier error has to be cleared in service mode. But this is the procedure ( for all the newer digital copiers ) if you need it. Depress the Additional Function key, then the 2 & 8 keys at the same time, and the additional function key again. This will display the service mode menu. Touch the Copier key. Across the top of the screen you should see " Function ". Touch it, look for CLEAR in the middle column. Touch it, then ERR, then OK. Turn off the copier and wait a few seconds then turn it back on and all should be well. After the initial reboot, you might hear the whirring on the toner motor trying to add the toner to the developer unit and this may take a little bit. Make several copies and make sure the copier doesn't error out again. If it does the then the supply tube maybe clogged and I don't think I could explain what is needed then. Hope this helps.
Posted on Jan 17, 2008
spinal
  • 287 Answers
SOURCE: Error code E000020-0181
Hello Brass, This error code means that the yellow drum/developer unit has failed. Your machine has 4 drums, cyan,magenta,yellow and black. At best they are good for about 40,000 copies. You can order one online and it is fairly simple to replace. Let me know if I can help further.
Posted on Jan 05, 2008
  • 58 Answers
SOURCE: ir8500 error code e000020-0010?
you have to clear this error by doing the following press additional function(*) and 2,8 together) then press additional functions (*)again (you have to do this quickly to get into service mode then you press copier
then you press function
then you press clear
then you press ERR
then you press ok
then turn off the machine and then back on
this is a low toner level detection code
do you have a new toner in the machine?
Posted on Aug 07, 2009
SOURCE: error code E000020-01b0, E000020-0260
E020 is a Drum/developer error code
-01b0 is a yellow drum error
-0260 is a magenta drum error
drums need replaced
7622A001AA Yellow drum part#
7623A001AA Magenta drum part#
7624A001AA Cyan drum part#
7623A001AA Black drum part#
Posted on Aug 21, 2009
Testimonial: "very helpful"
randula7
  • 78 Answers
SOURCE: error code e000020 in ir6000
E020
General condition
1) Is the developing assembly locking plate mounted correctly?
NO: Mount the plate correctly.
General condition
2) Is the shutter releasing member of the hopper mouth mounted correctly
to the developing assembly locking plate?
NO: It is likely that the inside of the hopper is clogged with toner. Remove
and then mount back the shutter releasing member to remove
the clog, or replace the hopper unit.
General condition, Developing assembly toner sensor (TS1)
3) Is the developing assembly adequately provided with toner?
YES: Check the developing assembly toner sensor.
General condition, Hopper toner sensor (TS2)
4) Is the hopper adequately provided with toner?
NO: Check the hopper toner sensor.
Hopper connector, Hopper supply motor (M10)
5) Is the connection of the hopper connector normal?
NO: Connect the connector securely.
YES: Check the hopper supply motor.
Posted on Oct 25, 2009
E000020-0281. I have this error in my printer model canon C4080
Canon imageRUNNER C3200 Copier 0281 e000020 ...
www.fixya.com > ... > Canon > Canon imageRUNNER C3200 Copier
E000020-0281 Hi in relation to your question about the error code (it seems to be from aCanon iRC3220 printer), I have found this webpage whch looks as if ...
Oct 08, 2015 | Canon Office Equipment & Supplies
Error code e000020-02a2
i have canon ir2570ci but shows error code E000020-02a2
Aug 31, 2013 | Canon imageRUNNER C3170U Color Copier
Canon irc 3080i error code e000020-0023
NITIAL FAULT IS ERROR CODE DUE TO WORN BLACK DRUM GIVING PATCHY IMAGE, ON FITTING A NEW DRUM IT CREATES ANOTHER ERROR CODE ABOVE E020, ON RE-FITTING OLD ONE ERROR DISAPPEARS. PATCH CREATED ON ITB IS UNDERTONED DUE TO LESS INTENSITY LASER BEAM PASSING THRO, THE RESIDUE ON THE GLASS, HENCE E020-0023.
THE CLEANING TOOL ON THE DOOR IS INADEQUATE TO CLEAN THIS RESIDUE. PULL OUT PROCESS UNIT TO MAX. LIMIT. PRISE UP THE DUST SHUTTER, THEN CLEAN WITH DAMP WIPE AND DRY IT. REPEAT IF NECESSARY OR TAKE LASER UNIT OUT
Mar 28, 2012 | Office Equipment & Supplies
Error Code - E000020-02a8
e000020-02a8 and e000020-02a2,these errors are coming in my copier 3100 how can i resolve this errors.it will be very thankful if u get me out of these errors.
Feb 12, 2011 | Canon iRC3100 Printer
Error code E000020 - 0081 in ir C3170 PCL5c
Apr 28, 2010 | Office Equipment & Supplies
Error code E000020-01b0, E000020-0260
drums need replaced
Aug 20, 2009 | Canon imageRUNNER C3200 Copier
Canon IR C3200 Error Code E000020-03C0?
plz tell me reason of e602 code in canon ir c3200
Mar 20, 2009 | Canon imageRUNNER C3200 Copier
Canon ImageRunner 1730iF Copier Logo
117 people viewed this question
old marine
old marine
