Question about Doheny Catalina Floating Pool Lounge
The end of the cloth/like lounge ripped right down the metal bar.......one year old.......can I just replace the cloth seating?
  • 3,103 Answers
Yes you can..
Posted on Jan 10, 2014
Some sort of felt type insulation has come off the inside back of the dryer. I have had the dryer not quite 3 years. Is there some sort of warranty or solution to this. It is tearing clothes.
You need to check your owners manual about the warranty, most likely it just carried 1 year warranty. The felt is what the drum glides on, and if it ripped, the tub will have a gap for cloths to get snagged and rip. The felt glide will need replaced, but, you need to check the edges of the tub for sharp or metal burrs, or it will just rip the new felt. good luck, Shane
Oct 03, 2009 | Maytag MDE308DAYW Electric Dryer
Dryer difficult to get started
all you need to do is take some real fine sand paper and sand it down litely
Jun 23, 2009 | Maytag Atlantis MDG7400AW Gas Dryer
Replace belt
Take the head off the vacuum, look at back. You will see two metal latches, the latches hold the bottom of the head on. If the latches are stiff, you can use a small hammer to tap the in the right direction, don't go crazy. The bottom will swing away towards the front. The beater bar can then be pulled out and a new belt slipped on. Replace the beater bar, be sure to get the black ring at one end installed so it is line with the little light that tells you the bar is turning. Replace the metal bottom, if you have trouble getting it to seat check that you have the front side seated properly over the 'bumps' on the front of the head. Lock the clips back in. Turn the finger to catch & pick up the belt so you may place it back on the vacuum.
Ted
May 23, 2009 | Kirby Heritage II Vacuum
Instructions to remove Driver Seat and replace the drive cables for the seat movement.
You need to remove the 4 nuts underneath the seat and take the seat out to replace the cable. usually the metal strip inside the cable has tiny line groves at both ends. This will wear off over the years.
May 17, 2009 | 1997 Volvo 960
My Sears Kenmore, 2 years old washing machine is ripping clothes
If this has a paddle,check it for a sharp edge,also make sure it is not loose, the top cap should be able to be pulled off to see the locking
bolt,and you can check to see if it has loosened.
Feel everywhere on the inside of the washer for a edge that might be catching your cloths. You can also try the gentle cycle and see if it does not rip them.
You did not post the model# ,so I have no clue what style it is.
Apr 07, 2009 | Kenmore Washing Machines
Mitsubishi Colt 2004 - car seat problem
a 4 year old car you bought 12 years ago?? please clarify.
Jan 06, 2009 | Mitsubishi Colt Cars & Trucks
Need help with putting straps back on
I know this is months later, but here you are in case you (or anyone else) needs the info again. First, though, I feel that it wouldn't be responsible to neglect to tell you that if you got the seat in 2000, it is expired and no longer safe to use. Car seats generally expire after 6 years because the plastic degrades over time - in a 10 year old seat, it can look fine but actually be brittle enough that the entire harness can rip out of the seat if it's an accident. For the manual, visit Cosco's website and fill in the product number and date of manufacture. It will bring up a PDF file of the manual that you can download. To rethread the straps, first replace the **** strap. Slide the metal plate down through the slot in the seat, with the buckle facing out. Slide the metal clip under the tab and push it down to lock it in place. Facing the seat, start by threading the end of the harness strap down through the slot of the left side of the bottom (where the child's right hip would be). Under the pad/cover, thread it across the bottom of the seat and up through the matching slot on the right side. Pull it until you have equal lengths on both sides. Thread the buckles onto the the strap (one one each end) and buckle them. Thread the chest buckle onto both ends, making sure that the harness doesn't twist. Buckle it, too. Push the ends through the harness slots. Pull the harness through to the back, making sure that it goes OVER the metal bar, but UNDER the plastic adjuster handle. There is a loop sewn into each end of the harness. The adjuster strap has a splitter plate, kind of shaped like a Y. Slide each loop over the ends of the plate and all of the way into the slot, so that the curved ends of the splitter plate are exposed and the strap is secure in it's slot. Adjust the harness height by squeezing the metal bar on the back of the seat (the one behind the harness) forward and moving it and the plastic adjuster bar up or down to the correct position (at or below the shoulders for rear-facing, at or above the shoulders for forward facing). Do note that the very top slot is NOT for use with the harness - it's only to adjust the headrest when the seat is being used as a seat belt positioning booster and is not reinforced to support the harness in an accident! Adjust the tightness of the straps with the button/extra length on the front of the seat. Properly tightened straps should lay in a straight line without sagging and you should not be able to pinch up any slack (lengthwise going down the harness, not across the width of it) at the shoulders or hips. Adjust the chest buckle to lie in line with your child's armpits, never his neck or belly.
Oct 15, 2008 | Cosco Alpha Omega Elite 5-Point 22-155
Time skips from 18 minutes to 6 minutes on automatic mode
It is the moisture sensor system, it is not sensing the wet clothes. Open the door, inside you should see a part with 2 metal bars that is around 3 inches long, clean these bars with a mult purpose cleaner. Sometimes fabric softner sheets and detergent builds up on this so that the machine cannot sense the moisture. Hope this helps.
Jan 28, 2008 | Whirlpool GEW9250 Electric Dryer
GE top load Washer ripping clothes
Solution!
GE has replaced the "boot" (the large rubber gasket at the opening of the washer) on my washer. This has fixed the problem!
Although the majority of people I spoke with at GE did not know about this, eventually I got a repair technician out here who spoke with one of the engineers. The engineer said that there was a problem with the boot causing clothing to rip. The new boot we have on our washer covers a ring of plastic just on the outside of the metal drum (the plastic rim remains stationary while the metal drum spins - this is the cause of the ripped clothing) - the old boot left this plastic ring exposed. Our washer was only 8 months old - so even if your washer is new, if your clothing is being ripped, insist that the boot be replaced for an updated version.
May 03, 2007 | GE Energy Star WCVH6260F Front Load Washer
Shield reattachment
Well, I don't have a solution to getting it back on, but if you could tell me how to get the stupid thing off, I could maybe figure out how to get it back on for you. :) I can't find anything about it via Cosco either. grrrrr!
Aug 08, 2006 | Cosco Alpha Omega 22-180 - with Shield
Doheny Catalina Floating Pool Lounge Logo
736 people viewed this question
Top Doheny Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Doheny Pool and Spa Expert? Answer questions, earn points and help others
