Question about Durabrand HT-3915 System
I am lookink for the 12 volt dc wires so i can connect another amp to this system.
  • 71 Answers
Most all 12v cord are the same. you might have one already. Check the label on one you have for the output volts.
Posted on Mar 14, 2009
I have an Astec DS 1500-3-001 power supply that I want to use a a stand alone PS. What pins do I need to connect to get +12v DC output with 120 VAC Input.
Mike
I take it that this is a standard power supply out of a PC (switch mode)
These are a common connection point on any brand PC
Use a DC Voltmeter to find the Ground, +5 Volt & +12 volt wires to power your 3.5 inch Hard Drive. The 2.5" Hard Drives (laptop) has only Ground (Black) & +5 Volt.
Oct 30, 2014 | Computers & Internet
What specifications do i use to get a replacement charger for a Peak Charging Adapter . . . . . . . . 120 volt AC (700mA, 12 volt DC Output
Just as your information says ask for a 12 volt 700 ma charger..but seeing that yours is a 450 amp jumper..any 12 volt that fits your ac input will do the job...one more thing if you do not have a charger..just connect it to your battery and run the engine for 20 min or so it will recharge the car battery and you jumper..also you can get a lighter wire with two lighter plugs and charge it through you lighter..good luck
Oct 22, 2014 | 450 Amp Jump-Starter with USB and 12 Volt...
Would like to know more about the solar panels discussed and shown on 2nd October 2014 at 05:15+
Solar panels are typically rated at .3 volts per cell. These cells are connected in series until they add up to 12 volts,24 volts or 36 volts depending on the solar system. The more cells you have the higher the charge rate of the batteries connected to the system. The DC voltage from the cells are used to charge the batteries then the voltage from the batteries is used to drive a DC to AC- convertor which is the power used by your home. The more cells connected the quicker it will charge the batteries and the more batteries connected the more power the solar system can provide.
Oct 04, 2014 | Solar 200 Amp Murray Mda 2200 Main Circuit...
My ups has failured only giving an alarm indicating that batdisconnected
Check the connections on the batteries. One or more may be loose or corroded. Also check the fuse for the batteries. It may have blown.
Sep 25, 2014 | Powerware 9120 UPS System
It does not seem to be charging the batteries. 12 volt lights work good for about 2 days then go dim until I put a charger on the batteries and bring them back into working order. The battery connect...
The Parallax 7155 converter should not require battery support for any 12 volt load amperage that is less than the maximum amperage capacity of the converter. A standard RV incandescent 12 volt lamp draws about 1.5 amperes for each bulb. With the battery disconnected and other 12 volt loads off, turn on lamps (not fixtures) and calculate the number of bulbs which can be turned on. If you run out of lamps, turn on vent fans etc. The idea here is to try to get to 55 amperes of DC load if possible without going over 55 amperes. At a sustained DC load of about 25-30 amperes or higher, the fans should cycle on continuously after about 5 -10 minutes. Lamp brightness should be normal and the measured voltage from the converter should be above 13 volts if under 55 amps of DC load. If the voltage drops with only a few lamps on, a converter issue would be likely.
Diagnostic tests an RV technician should make would be to:
1. Disconnect the battery system.
2. With the converter system powered on, measure the DC amperage with a DC ammeter capable of reading at least 60 amperes DC from the blue lead at the DC fuse panel terminal VCC.
3. Measure the DC voltage at terminal VCC and DC ground.
4. Record both readings.
At any DC load amperage less than 55 amps, the voltage should be above 13.0-13.2 volts DC. This method should take out all guesswork and confirm a DC converter section issue or not.
Nov 04, 2013 | Parallax Power Supply Parallax 7100 Series...
I HAVE A STOCK 2008 700 GRIZZLY, IT WONT CHARGE. i HAVE THE FACTORY MANUEL. I KNOW ITS EITHER THE REGULATOR, OR THE STATOR. ANY HELP
Find the Regulator & unplug. Connect a AC volt meter to the 3 white wires at the connector that is unplugged from the reg. connecting the 2 red & black meter leads to ANY 2 white wires at the plug (colors don't matter with AC. Run the bike & rev up. You should have starting at about 30 volts ac Up to about 90 volts ac reved if the Stator is good. Now move the 2 meter leads to 2 more white connections & check again. Now you have one more pair of white connections to check. Should have the same 90 volts on any of the 3 pairs of whites (3 phases). If they are low, The startor inside the cover is burnt--Replace it. If good, Then the Regulator/Rectifier Unit that rectifies ac to dc & then regulates the output at 14 ~ 14.5 volts DC on the red & ground (Green or black or housing ground) to go to the battery is the only other part that is for charging. You can't test a regulator other than to see if you have 90 v AC going into it & the plugged in it should be showing 14 Volts DC at the battery terminals , Not just 12 volts. Make shure you have a fully charged GOOD battery before tests or the readings will all be off.
Jun 03, 2011 | Yamaha XS 650 F Motorcycles
There are 2 sets of wires on the rca rt2760 home theatre system subwoofer, i know thay the purple ones are the speaker inputs......but the red and black is dc input for the amp thats inside the...
one is for the speaker connection the other is a control wire for the sub that should have a white plug on it to plug in the back of receiver
Oct 13, 2009 | RCA RT2760 System
Two car batteries @ 24-volt, would like to go to 15-volts
Hello j37p,
You will need a thing called a "DC to DC Converter". Here's a link to one place that makes them: http://www.powerstream.com/
One model they have is the PST-D24/12-800. It will accept 20-28V input and has an adjustable output from 12.5-15.5V.
I'm hoping that you are not planning on trying to charge 3 batteries with your vehicle alternator. You would not want 2 12V batteries in series anywhere near the vehicle electrical system. They would definitely burn stuff up. You'll also want to be thinking about how to keep the dc converter and your amp(s) cool. Believe me, they will be getting hot and require some serious airflow.
Hope this helps.
Apr 14, 2009 | Car Audio & Video
Durabrand HT-3915 System Logo
Top Durabrand Audio Players & Recorders Experts
Lyle Siemens
Lyle Siemens
Carlos L. Burgos
Carlos L. Burgos
SHARCNET-USA
SHARCNET-USA
Are you a Durabrand Audio Player and Recorder Expert? Answer questions, earn points and help others
