Question about Hoover SteamVac SpinScrub 50 Carpet Washer with Hard Floor Tool and Accessories
Hoover spin scrub clean water dispensing tank. How do I replace the spring, seal and valve stem at bottom of clean water tank?
The valve seal is not keeping the clean water in the tank. What is correct way to replace this par?
reddevil6
  • 1673 Answers
SOURCE: Will not dispense water or solution
On the bottom of the tank is a valve, push it in and see if water comes out Where the tank sits, there is a black round seal, is it in the proper place? The rod in the handle hits just under that seal, with the tank off, you can see if the rod is movin up and down when you depress the trigger. The resevior asm. may be bad, that is what the tank sits on.
Posted on Mar 11, 2008
reddevil6
  • 1673 Answers
SOURCE: Model F7441980 Hoover Dual Action Spin Scrub Wide Path
You will have to replace the tank, and it will come with the soap dispenser attached.
Posted on Mar 30, 2008
  • 8 Answers
SOURCE: won't dispense cleaning solution
I had this same problem. There is a solution posted elsewhere on this website. Search for Hoover Floormate H3000.
The following solution is the one I tried: Remove the fluid dispensing tank and put a small dab of hot glue on the tip of the blue/greyish "plunger" piece that is located in the middle of the black rubber circle. Let the hot glue dry (this forms an extension to the plunger piece...) and replace the fluid tank.
I did this and my machine is working properly again! Whoever posted this solution was very helpful!
Posted on Aug 29, 2008
SOURCE: Hoover Steam Vac clean water tank valve leaks
Honey! It's broke. You can manuever the little black valves out, but you will only find the hole in the clean water tank. I have the EXACT same problem. My advise to you is to take the valves, caps and handle off, sell them on EBAY and then buy you a whole new clean water tank.
Posted on Nov 18, 2008
SOURCE: my hoover spin scrub machine has stopped
There is a filter on the front right hand side of my F5871-900 Hoover. If you remove the plastic covering and clean that filter (wet finger may do), you're Hoover will begin spinning again!
Posted on Jul 06, 2009
How do I cycle the valves on the bottom with the eraser end of a pencil on my hoover dual vac shampooer
The center part of the valve (stem) pushes up (spring loaded) to release liquid. If it leaks it can (and should) be replaced. Also, check the black valve seal (conical shaped ring around the outside) for cracks or splits as this can contribute to leaks. The entire valve assembly (similar to photo) should be replaced to solve both issues.
Oct 09, 2014 | Hoover SteamVac F5914-900 SpinScrub...
How do I replace the hoses on a Hoover Spin Scrub?
I'm guessing you have an F7000 series machine. You have a bad solenoid. When they go bad they don't close so all the water poors out. Take it to your local vac repair shop for the repair.
Sep 11, 2014 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover agility steam vac F6210 solution tank repair
Hello! The valve assembly is not replaceable on the F6210. We recommend replacing the solution tank part number 90001091, can be purchased online or through a local service center. Hope this was helpful!
Jun 19, 2014 | Hoover F6212-900 / F6215-900 SteamVac...
Clarification to elextek: The right side
If the valve itself is leaking, it needs repaired/replaced. There should be a plastic stem in it, with a rubber seal washer, and a coil spring to close the valve stem when removed from the cleaner. If these parts are not there, or stuck, it will leak.
Oct 12, 2009 | Hoover SteamVac F5914-900 SpinScrub...
It won't dispense water to scrub. How do we fix it. Can you use a vinegar solutionto clean the nozzles
First check that the sloution is getting though the valve below the tank. istall and remove the tank with water in it. you will see water in the valve assembly. when pulling the trigger, water will go down. if it does, check the diffuser above the brush. the holes may be plugged, if so, use a small pointed object to clean out. if the water does not, then the valve should be replaced.
Oct 10, 2009 | Hoover Floormate H3000 Upright Wet/Dry...
Leaking Solution Tank/Seal Install - Hoover Steam Vac
Not sure this will help, but we have a Hoover Steamvac F5843 and our valve seal seemed to have shrunk so the tank was leaking. Bought a new seal and had the same problem. How to install? There weren't any instructions or pictures of the part(s) involved in the manual. Online there were a few pics but nothing helpful. After careful examination of the existing part and where it was supposed to be, I removed the original off the valve stem, placed the new one on it and carefully pressed the valve stem with the seal into place. It didn't look quite right and we were thinking "now what?". My wife and I got the idea at the same time...install the clean water tank (with the stem & seal in the bottom) back onto the steam cleaner. I took it back off to see what the stem & seal looked like afterwords and voila...the seal was perfectly inserted where it should be and the tank no longer leaks! The 'peg' that presses up on the valve stem pushed the seal perfectly in place.
Nov 16, 2008 | Hoover SteamVac F5914-900 SpinScrub...
Won't spray
This could be caused by several things. First take the clean water tank off of the machine, and turn it upside down to inspect the bottom of the tank. There should be a gasket with a spring and valve stem, which you should be able to move the valve stem up into the tank when pushed upwards. If you notice that there is no gasket, or vale stem, you'll need to purchase a new clean solution tank.
If the valve stem and gasket are ok, then it is most likely going to the pump assembly that has gone bad. This is a little more difficult repair, you should probably look up your closest Hoover repair center, or independent vacuum repair store, and take it in to them to have it repaired.
Chris Jones
GoVacuum.com
Sep 28, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Mar 30, 2008 | Hoover SteamVac F5914-900 SpinScrub...
Mar 10, 2008 | Hoover SteamVac F5914-900 SpinScrub...
Hoover SteamVac SpinScrub 50 Carpet Washer with Hard Floor Tool and Accessories Logo
103 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
