Question about Ovens
Reset timer on gorenje oven after power cut
Electric oven will not work after power cut timer is continually flashing and needs resetting but have no instructions on how to do this
SOURCE: Oven won't work after power cut.
The power outage may have been a result of a power surge or included one. Check the surge protection, breakers or fuses, most likely found inside control panel. Of course turn power off to stove before opening up the panel. Breakers should be pushed all the way off before being pushed to the on position.
Posted on Nov 05, 2007
SOURCE: clock setting
Press the fourth button from the left (that looks like a tick) then turnthe knob to the right of it to set time as required
Posted on Mar 29, 2008
  • 22 Answers
SOURCE: oven won't work - its a timer problem how do I reset the timer?
I believe the control's child lock function is enabled. To disable it, press and hold the cancel key (will have small padlock icon under the word "cancel"). That should clear the condition.
Posted on Apr 25, 2009
SOURCE: clock on cooker flashing
Just to let you know that i have solved the problem with my cooker, (clock flashing after electric going off) i held down the cook period button and the end time button, then i was able to reset the clock by pressing the +button.
Posted on May 01, 2009
  • 8 Answers
SOURCE: Electrolux oven won't come on
It appears that the "return to manual" button has to be reset
Posted on Sep 02, 2009
Main oven not working following a power cut. Timer flashing AUTO and clock control buttons not working
The auto function will cut off the power to your oven try switching the oven to manual control to reset the control.
Apr 26, 2015 | Ovens
Teka ha 830 oven timer will not reset after power cut
I have a Teka HA830 oven I held the buttons down but it never resets. Would like to know if its possible to change the computer board, and where can i purchase it online?..
Jan 29, 2013 | Ovens
We had a power cut, now I can't get the oven to work the auto light is flashing but when I turn the knob for the oven it won't come on.
You need to reset the oven from auto to manual setting.
This is done by pressing 2 or more buttons on the timer at the same time to reset it, until you do this, the oven will not work
Feb 17, 2011 | Tecnik TKC8085 Electric Double Oven
Hi. I think I've had a power cut and my Stoves oven (about 10 years old) Is not working. The clock is flashing and the main oven won't switch on. I'm sure this has happened before but can't...
The clock is on auto because of power cut, you need to reset it to manual to enable the oven to work as normal. Refer to your user instructions.
Oct 15, 2010 | Stoves 720EF Electric Double Oven
Dead oven despite element replacement?
If it has a timer, then make sure it is set to manual, and not auto, otherwise the oven will not come on.
What usually happens is, if you have a power cut, or switch the oven off, then the timer automatially goes to auto when the power is on again.
Please rate my solution.
Thankyou.
Feb 02, 2010 | Belling XOU592 / XOU593 Electric Double...
Clock on cooker flashing
Apr 28, 2009 | Hotpoint UY46 Style Line Stainless Steel...
The timer clock has gone off.
to stop the clock area from flashing and for it to display time, the time must be set.
Apr 09, 2009 | Ovens
Dacor Electric Double Oven - bottom oven won't heat
If ti has a timer that is flashing auto, reset it to manual , as it will not work in auto mode.
Hope this helps.
Plz rate soltuioun.Thanks
Dec 26, 2008 | Ovens
Display works but no lights on either oven and no fan
If the display is flashing, it sounds like the timer needs resetting
U need to refer to your instuctions on how to do this..
If it does it again once u have reset it, then I suspect that the oven element has blown..
Pls leave feedback.
Thanks.
Nov 28, 2008 | Hotpoint DY46 Style Line Stainless Steel...
Ovens Logo
96 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
