Question about Sewing Machines
My brother overlocker blades dont cut anymore and thet dont move either, please help!!!
The blades dont cut or move
  • Sewing Machines Master
  • 7,365 Answers
If the blades don't cut then they need to be replaced,, and for the
blades not moving,, the machine need to be checked..
Posted on Apr 19, 2013
jrrysthl
  • 9 Answers
SOURCE: BROTHER OVERLOCKER
Click on this to go to the brother website and download your manual in PDF format.
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_1034D_ENES_178.PDF
Posted on Dec 13, 2008
  • 14 Answers
SOURCE: Brother 1034D serger is not cutting and is binding up
This problem is usually when the lower blade drops below the sewing plate. Look at the blade in relation to the plate and see if it has dropped below the plate, then you can reset the blade. If it is not the upper blade may be too dull to cut so it will need to be replaced.
Posted on Jul 07, 2009
  • 1116 Answers
SOURCE: I accidentally sewed over a pin and now the moving
Disengage and then engage the blade to see if this will reset the position of the blade.
You could replace the blade - this should be in the manual or you may need to take the machine in for service as replacing the blade may or may not be all that needs to be done.
Posted on May 12, 2010
sewinsnap
  • 135 Answers
SOURCE: sharpen the cutting blades
You really can't sharpen them...you have to buy new ones.
Posted on Jun 24, 2010
How can I do adjustment of cutting width elna overlock machine
to change how much fabric is cut you need to move the cutting blade either left or right, this overlocker is one of the first so I think this process was pretty manual, ie using a screw driver to release and reposition the right hand blade.
it may be worthwhile buying a manual for this while you still can get them, this model was released back in 1987 in UK. Instruction Manual Elna L1 Serger
Feb 27, 2015 | Elna Sewing Machines
Why does fabric get caugh on the roll hem devise when over locking
this sounds like an overlocker/serger machine you are using? if the fabric is catching on the overlocking tongue it could be a number of factors, have you lifted the top cutting blade out of the way and forgot to put it back into place? That would be my first thought, the top and bottom blade move against each other cutting the fabric. Rolled hemming usually requires the blade to be set on about 2, or middle of its setting range, the stitch finger is pulled back out of the stitching area, top looper thread is loosened off and bottom looper thread is tightened up, resulting in the top looper thread wrapping around the edge of the fabric and pulling the cut edge down under within the seam, forming the rolled hem.
May 13, 2014 | Elna Sewing Machines
Brother overlocker
Hi there
Please can you help. I bought a second-hand brother M14-B551 overlocker. The needle broke and i am now battling to thread . Where can i get some help.
Jan 13, 2014 | Sewing Machines
I have a Singer Ultarlock 14U34 and need to know how to adjust the stitch width.
You can download a manual from this link
http://www.singerco.com/uploads/download/664_14u34b,234b.pdf
Check page 16, changing the seam width is done by moving the cutting blade left or right and using only one needle. So if you want the narrowest seam, use the right needle only, remove the left one, and move the blade as far left as you can. Your manual says to turn machine off at the wall for safety, many overlockers will have a motor cutout when you open the front covers, but its good practice to turn off too. Then you put pressure against the upper moveable blade and swing it up out of the way and make adjustment to the lower fixed blade with a screwdriver in your kit (some overlockers it is a knob you move to move the blade position).
And reverse for a wide stitch, use left needle for 3 thread wide seam, and move the blade far right.
You can also use the 4 thread seam where you use both needles and trim up narrow but the seam will be heavier than a three thread.
Each time you make changes to the amount of fabric being trimmed, you may need to finess the upper and lower looper tensions to ensure the seam is tensioned enough to just meet on the cut edge of the fabric. This is the norm for overlockers, each fabric will behave a little differently so you need to test stitch and adjust a little. Your manual will explain this process too.
Sep 05, 2011 | Singer 14SH654
When sewing with the brother serger 1034d, loops of thread stick out beyond the fabric-it is not nice and close like it's supposed to be. the settings from left to right are: 4,4,3,3. this is what my...
Can you wind the lower cutting blade to the right to cut less fabric and therefore fill out the stitching? On most sergers the lower blade position can be adjusted sometimes with a little knob or dial. You need to raise the top blade out of the way first, usually you put pressure onto it to release the spring holding it up against the lower blade, then swing it up to do this. Then wind the adjustment on the lower blade and move it to the right to cut less fabric then test serge. Your manual should give you more specific information on this and should be your first 'go to".
I would adjust my looper tensions to suit the fabric and width of the stitch I'm trying to achieve so yes, the settings you've been given are average tensions but its okay to vary these too. From left to right, I'd set 4, 4, 4, 4 and test serge again and see if this pulls the looper threads in against the fabric if moving the blade hasn't tightened up the stitching.
Sergers are more variable than a straight stitch sewing machine so its okay to move tension knobs a bit, just turn each a half number each time you adjust, then test serge and look at the stitch formation. Your needles tension should be fine at 4, leave them alone.
I'd suggest if you can find one, go to a "Getting to know your serger" type class as there is lots of techniques such as seaming on a curve, turning right angles, both inside and outside and making rolled hem edges that are very helpful serger skills to learn along with making adjustments and troubleshooting. Or go to you-tube and search some of these techniques for videos. Also www.sewing.about.com is a great sewing resource and Debbie has pages on sergers/overlockers here too.
When I'm starting a new dressmaking project I will spend 10 mins on the overlocker/serger, changing the thread colour to suit the garment, then test serging and adjusting the stitch tensions to suit the fabric. I have 4 cones of thread each in white, black, beige, grey, pink and pale blue and these threads will give a suitable finish on most fabric colours and prints. Then there is wooly overlocker thread, this is a fluffy thread that you can use for rolled hems as the thread relaxes once stitched and "fills" out the closely stitched edge covering the rolled fabric edge and is another whole area of fun to try out.
Often I'll just use a three thread to neaten the raw edges of a seam I will press open. Or I will assemble a whole knit garment using the four thread stitch, so much faster then stitching seams, then neatening. Jersey knits and sergers are made for each other.
As an aside the D on your machine model would denote "differential feed" too - briefly differential feed is adjusting the amount that the two feed dogs move under the foot and means you can "hold back" the fabric as it is stitched (0.5), or "stretch" it out (1.5 or 2 setting). Really handy for loose weave fabrics that stretch as you serge them, you can compensate using the differential feed setting. And in reverse, you can create a "lettuce" or wavy edge by turning the differential feed up.
I hope that this helps you out with your Brother 1034D and hasn't just confused you. Good luck.
Aug 01, 2011 | Brother 1034D Mechanical Sewing Machine
What is the settings for rolled hem using your overlocker
You haven't specified your overlocker make and model but some parts of the set up will be the same; you still need to consult your machine manual to find out the changes needed to the foot. Bernettes have a little switch near the blade that you flick to change how the stitch forms so it rolls.
You need a 3 thread overlock with the right hand needle (I'm assuming you have a 4 thread lock) turn the stitch length down to 0.5 so it is very closed up. And there is usually a little thread finger on the foot that needs to be changed or a switch you flick to move it back.
Then lower the tension down on the upper looper so this thread goes over the edge to the underside and tighten up the lower looper dial so this thread lies against the needle stitch.
Move the blade to the right so the fabric is cut wider than the seam that the threads are forming so the cut edge rolls underneath and is encased in the threads.
It is best to use wooly overlock thread on at least the top looper so this "fills" in the rolled edge.
If you visit you-tube and search using "Rolled Hem" or Nancy Zieman you should find some helpful videos too.
Apr 25, 2011 | Sewing Machines
May 12, 2010 | Sewing Machines
I want to know which knob I use to make the stitching narrower
there are generally two variable controls .. one adjusts the stitch length (distance between stitches measured in stitches per inch) ... the second is stitch width .. that adjusts how far the zigzag moves left and right .. thats usually just a number from 0 to 10 or so .. 10 would be maximum width .. 0 would be used for straight stitch ..
so you need to adjust the stitch width control to make the stitching narrower .. the controls are called different things on different brand sewing machines .. if you have the brand and model number then there may be instruction booklets available ...
Jan 04, 2010 | Sewing Machines
Sewing Machines Logo
75 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
