Question about Eyemax Hx-08 H.264 Security Dvr System 8ch Video 240 Fps Iphone, 3g Bare-bone
Beeping CCTV My eyemax CCTV beeping all night . Can't view any camera online. There is Internet connection . I don't have any knowledge about technical . Can someone help.
My CCTV is showing hacked on the cameras. How do I reset my password
Your CCTV is connected via an Internet connection.
I'll recommend to isolate the network devices from the Internet before continuing.
This is covering only basic steps, I recommend to get the instruction manual for the CCTV and read it.
  1. Enter the administration section of the CCTV recorder/DCR/NVR by entering your admin account name and password.
  2. Go to the admin setup of the CCTV. Search for overlay and verify if the hacker inserted text on the overlay feature, if you don't use overlay, disable it.
  3. Then check each camera name tags in the admin section. Change the text if it was hacked.
  4. Change the password for the CCTV DVR/NVR/Camera, I bet it was never changed. Write the password down and store it in a safe place.
  5. Last option: If you can't find the place do a factory reset of the DVR/NVR/Camera. (Do make a backup before a factory reset to an external device if possible).
  6. Once the factory reset is done, you will have to reconfigure the recording options for each camera.
  7. Last point after the factory reset, change the admin password.
Are there other devices sharing the Internet connection with the CCTV?
If this answer is YES, then check them for hacker breach.
  1. I'll recommend to increase the security on the Internet Router.
  2. Any device sharing the Internet with the CCTV should be checked for breaches and made secure.
  3. Speak to your ISP and ask for assistance if you have a fixed IP address to your CCTV system. Ask them for advice. Layer 7 routers are more expensive but more secure.
  4. Load all updates for any devices!
Get an IT security expert to assist you with the breach if necessary.
Sep 29, 2017 | The Home Security
How do I set up remote live viewing on my I pad
you will need a compatible application(iCamViewer) to connect it to your camera or camera server for iPad and that allows you to configure streams and IP settings as as well as your username and password to access the camera.
If you are using static internal IP address so you have to do Port Forwarding Setup.
more technical help http://www.cctvcamerapros.com/iCamviewer-iPhone-App-Setup-Instructions-s/393.htmand router configuration http://www.techsupportrouter.com/support-for-d-link-router.html for your CCTV routers
May 07, 2014 | Computers & Internet
CCTV DVR RECORDER
Have one did the same, tried to boot up when powered up, then started beeping. Found bad hard drive, replaced all ok.
Feb 23, 2014 | Ganz DR4NC-160 DVR DIGITAL VIDEO RECORDER...
Cctv dvr beeping
Shut it down reboot it's saying that one of the cameras is not functioning correctly if this don't solve it then check all power supply's to each camera
Feb 06, 2014 | Swann Communications DVR4-Pro-Net...
I have a sentient cctv dvr from Maplin I can view it on my phone at home which is fine I wanted to know if I can view camera footage when I'm not at home etc. at work
Yes you can definitely view your CCTV footage on your mobile phone at your work via internet. Sentient CCTV DVR basically is a night vision camera. You must know the IP of the camera and IP Video server. Connecting your phone to CCTV camera via the protocol you can view the CCTV footage's in your phone. Night vision cameras are used for surveillance purpose. I would prefer cctv camera with ir illuminator for good image quality in the night time that will clear footage quality in my phone.
Recently many new applications have also being launched by security cameras with a view to solve problem you mentioned.
Jul 05, 2013 | Home Security
Rear view camera instalation
Mount the camera on the back and the monitor in the front. Run the necessary wires and connect it to the power supply.
Feb 24, 2013 | Rear View Safety Rear View Night Vision...
Why is my speaker making a beeping noise
It may due to fellow problems:
1. device interface
2. Input and wires
3. Some popping noises have to do with internal components of speakers systems that can only be fixed by those with advanced knowledge of the technology. If the above methods don't work, consider hiring a technician to diagnose your system.
Aug 13, 2012 | 2006 Kia Sorento
I bought 2 outdoor CCTV.camera RV537B with night vision. one of the unit has not functioning properly on night. i tested it by covering the photo cell that switch the LED lamp which is ok but it seems to...
I think I answer you question--when?? Take the good CCTV camera and hook it up to monitor. Then hook up the CCTV camera and turn it on. Point the working CCTV camera at the bad camera that is turn on. Now, look at the monitor which is working with your operational camera. Look at the bad camera while it on, and see how many IR LED's you can see on the bad CCTV, while it turn on. You should be able to the IR LED glowing red. If not, then there is a problem with bad CCTV IR LED's. Short wire, no power to the IR LED's. stewbison
Jun 24, 2011 | Optics
Kidde CO alarm keeps beeping every 15-20 seconds. How do i fix it
Try changing the batteries and cleaning it.
If that does not do the trick, you have to get it serviced/repaired.
Cheers
TeaCii
If you own website, add live support almost free
Real security guard to watch your cctv for $1/day
Mar 30, 2010 | Kidde Nighthawk Combo Gas/co Detector
How to setup up my cctv cam to sonicwall tz170
If your camera is connected to DVR then do the port redirection on your firewall so that you shall view the cameras from internet, If your camera is directly connected to network using RJ45 simply do the port redirection to IP address of CCTV camera.
Nov 19, 2009 | SonicWALL TZ170 (01-ssc-5740) Firewall
Eyemax Hx-08 H.264 Security Dvr System 8ch Video 240 Fps Iphone, 3g Bare-bone Logo
59 people viewed this question
Top Eyemax Computers & Internet Experts
David Payne
David Payne
Are you an Eyemax Computer and Internet Expert? Answer questions, earn points and help others
