Question about Maruyama Kendo Supply High Quality Cotton Obi For Iaido 350cm 138 In
MARUYAMA CER230 OIL MIXING RATE - Maruyama Kendo Supply High Quality Cotton Obi For Iaido 350cm 138 In
What causes oil and diesel mix in engine
If you have a turbocharge, is not wotking properly allowing the oil to be used as the source of fuel.
Aug 12, 2014 | Cars & Trucks
1999 Johnson 70hp 2 stroke outboard how can I disconnect the self mixing oil tank and premix oil and fuel myself?
the self mixing use variable rate which is much better then mixing it yourself. why would you want to change it?
Mar 18, 2014 | Garden
Engine oil mixing into coolant
The only place, oil and water share a gasket is the cylinder head gasket, oil and water galleries run through the engine block and head via the head gasket. The cylinder pressure will be OK, it's the oil pressure that's putting the oil in the coolant, the gasket has gone between the water and oil galleries or there is an internal crack (unlikely). A coolant pressure test should show it up.
Jan 23, 2014 | 2012 Kia Sorento Base 4dr SUV 2.4L 4-cyl....
I don't know what fuel my leaf blower needs.
Almost every leaf blower uses gasoline mixed with 2-cycle mixing oil. Unless you have a larger, commercial model with a separate oil tank, you'll need to purchase mixing oil and mix it with your fuel. You can find mixing oil at PartsBuggy.com.
Oct 22, 2012 | Echo Garden
What is the mixing ratio for the fuel(fuel+oil)
Hi marius65..
Use the normal mixture for 2 cycle engines
50 to 1 mixture...1 pint of 2 cycle oil to 6 gallons of gasoline
Please rate me
Bud
Oct 03, 2012 | Ryobi 30cc 17" String Trimmer Zrry30530...
Antifreeze mixing with the oil
if the oil is mixing in the anti-freeze and it has a red/redish colour to it then the transmission cooler lines in the rad is leaking and the rad will have to be replaced.if the coolant is mixing with the oil then there is a gasket or a crack in the head or block that is allowing coolant into the oil system.it could be an intake gasket that is leaking.it will have to be checked out.there is more oil pressure than coolant pressrure,there fore a gasket will leak into the oil system in an area were an oil passage is not present.
Nov 09, 2011 | 2000 Buick Century
What 2 stroke oil is recommended for a Piaggio zip 50 2 stroke
Use 2T oil if you are mixing it with petrol.
Regards.
don't forget to rate this.
Jul 02, 2011 | Piaggio MachG LC Motorcycles
Smoke coming from edger muffler
Check to see if you overloaded with the oil when mixing your oil and gas...if it is a 2 cycle.
If it is a 4 cycle then you may have over filled the oil tank, drain some out and try to run again
Please rate me
Sep 18, 2010 | Echo Rapid Loader, Trimmer Head
Water contamination in lub oil.how to identify
most fuel oil mixing occurs at head cylinder gasket area. the area near pistons is most at risk.
Mar 04, 2010 | OTC 7471A CUMMINS DIESEL ENGINE BARRING...
Maruyama Kendo Supply High Quality Cotton Obi For Iaido 350cm 138 In Logo
258 people viewed this question
Top Maruyama Kendo Supply Clothing Experts
treeeee
treeeee
shuyumeng
shuyumeng
Erin Wood
Erin Wood
Are you a Maruyama Kendo Supply Clothing Expert? Answer questions, earn points and help others
