Question about Western Digital Elements powered by WD 320 GB External USB (WDE1U3200N) Hard Drive
Hard drive My hard drive power up and my computer picks it up and say its installed but I can't find it, it's not playing and it's not on my computer device and I would like to get my picture that are saved the Hard Drive I have is elements MDL; WD500C035 SN; WCAPW5142533 Thank you for your time
3 Suggested Answers
Crankstart
  • 696 Answers
SOURCE: External hard drive fell off table now ''drive not found''
these drives are a bit delicate and do tend to damage easily when dropped. You may just have knocked a cable loose, could have damaged the usb controller board or may have damaged the HDD.
If you're not concerned about warranty, you can slide the shell off of the body of the drive with a little prying around the back edge(around the metal end with all the plugs. It can be put back when you're done but you will likely leave some tool marks on it.
Once you have it open you will see the HDD mounted along the cases length, at one end it has two small cables attached. ensure they are snug, then follow each to it's other end and ensure they are snug, the check the small circuit board running perpendicular to the HDD to ensute the pinned end it securely attached to the larger ciruit board.
Test the drive, if no luck the next step involves buying a new drive enclosure. Go to you local computer store and ask for a 3.5" SATA Hard Drive enclosure. Then finish disassembling the Western Digital, removing the HDD and placing it in the new Enclosure, be careful not to touch the circuit board attached to the bottom of the hard drive.
Once you've installed the HDD in the new enclosure plug it into your computer and power it up. If this works your done, if not the HDD may be finished.
Still if this doesn't work you can send the HDD for recovery to a pro, try Armor-IT Data Recovery in Canada, they have good rates and are listed on FixYa's directory.
Hope this helps FixYa
Chris
Posted on May 11, 2009
YourZEN
  • 820 Answers
SOURCE: I have an elements hard drive MDL:WD5000C035.
Typically, faulty adapters that have a green led or light when having no drive connected, stay on when powered. Once connected to the drive, the power led on the adapter turns off.
Sometimes the adapter can be replaced under warranty.
Select Warranty Check on the site for End User Costumers:
http://support.wdc.com/warranty/index_end.asp?lang=en
Select your country and enter the Serial Number, sometimes near the barcode ( not the model number you mentioned ).
When the adapter is still under warranty you do NOT have to fill in a sheet for an RMA ( Product Replacement form) for the hard drive.
You can make a phone call using the number that is free from charges. Look on this page for your country for phone support:
http://support.wdc.com/contact/index.asp?lang=en
When the adapter is out of warranty, you can look for a replacement in the WD shop. See next site:
http://wdc.custhelp.com/cgi-bin/wdc.cfg/php/enduser/std_adp.php?p_faqid=1378&p_created=1118358612&p_sid=1VgzXjvj&p_accessibility=0&p_redirect=&p_lva=1378&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9MSwxJnBfcHJvZHM9MCZwX2NhdHM9MCZwX3B2PSZwX2N2PSZwX3NlYXJjaF90eXBlPWFuc3dlcnMuc2VhcmNoX25sJnBfcGFnZT0xJnBfc2VhcmNoX3RleHQ9MTM3OA!!&p_li=&p_topview=1
Posted on Mar 24, 2010
Samsung external hard drive
!! You have failed to provide a detailed problem. !!
External hard drives are plug-and-play devices used to store music, video and data files. Once the drive is connected, the computer checks its systems for the appropriate drivers, loads them, and the external drive is ready to use. If the computer does not recognize the external drive, plug it into another computer to ensure the drive is not corrupted. If the drive is good, a few simple steps should help re-enable the drive for use.
Switch the power button to "off." Disconnect the power cord from any extension cords or power strip, then re-seat the power cord into the hard drive. Connect the cord directly into an outlet and power up the drive. If the drive is powered and still not working, check the data cable. Power down the hard drive and disconnect the data cable from the computer. Wait 30 seconds to one minute. Reconnect the data cable and power up the drive. If the drive is not detected, power down the hard drive and connect the cable to a different port. Power up the drive. If the drive is detected but not working, check for a missing driver. Click on the "Start" button, right-click "Computer" and select "Manage." Enter your administrator password if requested. Select "Device Manager" and double-click "Disk Drives." Right-click the yellow exclamation point and install the missing driver. Close the Device Manager. If the drive is detected but not working check to ensure it has an assigned drive letter. Disconnect all devices connected by USB cables from the computer. Reconnect the drive's data and USB power cables directly into the computer. Click on the "Start" button, right-click "Computer" and select "Manage." Enter your administrator password if requested. Click on "Disk Management," right-click the external hard drive, click "change drive letter and path," and click "Add." Assign a drive letter. Avoid using A, B or C (C is usually assigned to the computer's internal hard drive). Click "OK" close the window. If the drive is detected but not working, check whether the drive is in sleep mode. Disconnect all devices connected by USB cables from the computer. Reconnect the drive's data and USB power cables directly into the computer. Click the "Start" button, right-click "Computer" and select "Manage." Enter your administrator password if requested. Select "Device Manager" and double-click "Universal Serial Bus Controllers." Double-click the first instance of "USB Root Hub" or "Root Hub." Check for the hard drive. If the drive is not visible, move to the next instance of "USB Root Hub." Continue checking each instance until the hard drive is located. Once located, click the "Power Management" tab and uncheck the "Allow computer to turn off this device to save power" box, click "OK," then close the Device Manager. Power the computer down, wait 30 seconds to one minute, and power the computer back up to ensure the drive is detected.
Jan 29, 2013 | Samsung G2 Portable External HX-MU064DC/...
Clickfree 1028wi not showing on my computer
Switch the power button to "off." Disconnect the power cord from any extension cords or power strip, then re-seat the power cord into the hard drive. Connect the cord directly into an outlet and power up the drive. If the drive is powered and still not working, check the data cable. Power down the hard drive and disconnect the data cable from the computer. Wait 30 seconds to one minute. Reconnect the data cable and power up the drive. If the drive is not detected, power down the hard drive and connect the cable to a different port. Power up the drive. If the drive is detected but not working, check for a missing driver. Click on the "Start" button, right-click "Computer" and select "Manage." Enter your administrator password if requested. Select "Device Manager" and double-click "Disk Drives." Right-click the yellow exclamation point and install the missing driver. Close the Device Manager. If the drive is detected but not working check to ensure it has an assigned drive letter. Disconnect all devices connected by USB cables from the computer. Reconnect the drive's data and USB power cables directly into the computer. Click on the "Start" button, right-click "Computer" and select "Manage." Enter your administrator password if requested. Click on "Disk Management," right-click the external hard drive, click "change drive letter and path," and click "Add." Assign a drive letter. Avoid using A, B or C (C is usually assigned to the computer's internal hard drive). Click "OK" close the window. If the drive is detected but not working, check whether the drive is in sleep mode. Disconnect all devices connected by USB cables from the computer. Reconnect the drive's data and USB power cables directly into the computer. Click the "Start" button, right-click "Computer" and select "Manage." Enter your administrator password if requested. Select "Device Manager" and double-click "Universal Serial Bus Controllers." Double-click the first instance of "USB Root Hub" or "Root Hub." Check for the hard drive. If the drive is not visible, move to the next instance of "USB Root Hub." Continue checking each instance until the hard drive is located. Once located, click the "Power Management" tab and uncheck the "Allow computer to turn off this device to save power" box, click "OK," then close the Device Manager. Power the computer down, wait 30 seconds to one minute, and power the computer back up to ensure the drive is detected. Hope this helps.
b>
Jan 24, 2013 | Click Free 1028WI-PB-R | Clickfree C2 1...
Pc does not recognize external drive
b>
Jan 07, 2013 | SmartDisk Verbatim 96867 2 TB External...
Imation 1TB USB external Hard Drive .....unrecognized in Windows Both in windows7 and XP.
Jan 07, 2013 | Imation 1TB Cartridge (IMN27957) Hard...
HOW DO I KNOW THAT MY HARD DRIVE IS CONNECTED
b>
Dec 21, 2012 | Buffalo Technology (HD-PE320U2/WH) 320 GB...
External drive not picked up on computer
External hard drives not only provide additional storage space on a computer system but also allow data to be conveniently transported from one computer to another.
These drives typically plug right in to a port on the computer and function without any additional setup; however, if you are running into trouble where your external hard drive is not being detected, you must troubleshoot the situation to determine why the drive appears to be missing.
Check the USB connection running from the hard drive to your computer.
If the USB cable is not seated securely in the port, the computer will not detect the external drive.
Disconnect the USB cable from the computer and plug it into a different USB port. Occasionally, a USB port will fail to function with some hardware and changing the USB connection may correct this issue.
Switch from a USB to a Firewire cable connection, if possible.
The USB port on the hard drive may have died; if so, changing to a Firewire connection will resolve this issue.
Install the driver for the external device from the installation disc provided with the product. Older computer systems may require you to manually install this driver.
After inserting the installation CD, follow the prompts from the installation wizard to install the driver on your computer.
Restart the computer.
If you connected the external drive while the computer is powered down, it may not recognize the device when you turn on the computer.
After restarting the computer, connect the external drive to the system.
The drive should now be detected by your operating system.
Connect the external hard drive to a power source and then plug it into your PC computer using a USB or Firewire cable.
Log on to your PC computer using an account with administrative privileges.
Open the Start menu and click on the "Control Panel" icon.
Open the "Administrative Tools" folder and then double-click on the "Computer Management" icon.
Select "Disk Management" from the list of options on left side of the window.
Right-click on the drive you want your computer to recognize and select "Change Drive Letter and Paths."
Select a drive letter for the external hard drive to be recognized as and click "OK."
The drive will now appear in My Computer.
Hope this helps.
Nov 22, 2012 | Samsung G3 Station Desktop External Drive...
Playing itunes music on pny usb
did you sync iTunes with your flash drive ?
Launch iTunes.
Connect your media player with SanDisk memory card installed to your computer through its USB adapter.
Wait for the player's device icon to appear in the iTunes Source pane.
Drag and drop music titles from the library pane directly onto the device icon.
The music will sync onto the player's SD storage.
hope this helps
Oct 04, 2012 | PNY 2GB Mini USB Flash Drive W/Ready Boost...
How do I install CNM Core 120GB portable Hard Drive USB2 0 on my laptop?
The hard drive is plug and play, no software is required. All you have to do is plug the hard drive into a USB slot. If it doesn't work then you know the hard drive is bad and you would have to get another one.
May 28, 2011 | Computers & Internet
Western Digital HDD I need softwear to install WD5000G032
Their is no software for it, nor their is any requirement for any software to use this device, its a plug and play device like a flash drive. Just make sure you turn on the power for this thing before you connect the usb cable to it and then to the computer and you will see a device poping up if you have the My Computer window open up. If it does not come up then it means your new device is bad, simply get it replaced.
May 04, 2010 | Western Digital My Book Essential Edition...
I have recently bought a HITACHI SIMPLE DRIVE 1.0 TB DATA STORAGE and it had no disk and no manuel and i cant seem to install. I also searched the internet and have found no software to help me...any...
if its an external hard drive then and you want to install the hard drive on your computer, you have to install the BIOS on it and then install the OS you want on it also. this will make the hard drive able to be used by your computer.
if its a portable hard drive, then just use the control panel of your computer to find the device, normally any plug-n-play device is usually recognised and installed automatically by your computer.
cheers.
cheers.
Aug 15, 2009 | Hitachi 120 GIGABYTE SATA MOBILE STORAGE...
Western Digital Elements powered by WD 320 GB External USB (WDE1U3200N) Hard Drive Logo
205 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
