Question about HP xw4600 Workstation - 1 x Intel Core 2 Duo E6850 3GHz - 4GB DDR2 SDRAM - 1 x 160GB - DVD-Writer PC Desktop
I'v an hp xw 4600 workstation PC , I connected an extra hard disk via sata cable on the M.b. directly .. after i rebooted and removed my hard everything started going wrong , first a msg said 16
I tried removing the battery but all in vain
  • HP Master
  • 5,660 Answers
Whoa! Wait a minute................
Let me see if I have this straight................
You plugged an additional SATA harddrive into the motherboard.
(Via a SATA data cable)
THEN you removed the original harddrive?
Post back in a Comment to clarify
Regards,
joecoolvette
Posted on Apr 19, 2013
SOURCE: xw 8200 workstation no work, red light and beeping
check this link regarding the beep
Posted on Nov 15, 2008
Kiranbala
  • 91 Answers
SOURCE: HP Compaq d530 SFF PC Desktop. Black Screen and Cursor blinking..
Try to enter in to BIOS by restearting the notebook (Pressing F2 function, if the notebook enters in to bios then no need to worry. after theat i suggest you to reinstall the notebook to original factory settings dy the recovery disks.
Posted on Mar 07, 2009
RyMS
  • 63 Answers
SOURCE: HP Media Centre PC 7250 can I add a hard drive?
Here's a step by step guide for that HP 7250 model on HP's website about how to replace, or remove/add the Primary and Secondary Hard Drives (which pictures that help).
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00639696&lc=en&dlc=en&cc=us&product=1118243&rule=29389&lang=en
If your computer did not come with a second hard drive, you can install a second hard drive that you attach to the bottom of the inside of the computer tower.
Posted on Mar 30, 2009
SOURCE: computer doesn't see new secondary hard drive
There is no option in the bios to enable sata. It appears that the sata ports are just for decoration (hence hp using IDE)
Posted on May 29, 2010
  • 356 Answers
SOURCE: HP dc5100MT motherboard
Hi. I believe there's an ATA-to-SATA converter/adapter/dongle available. Try checking with bestbuys' and hope you find one.
It should look something like this:
http://www.monoprice.com/products/subdepartment.asp?c_id=104&cp_id=10407
Good Luck!!! ^_^
Posted on Jun 06, 2010
My hp xw4600 workstation beeps red light blinks on off
read the code the blink codes tell the story,
red lights where,
1: power button LED green? (can be red) and beeps
2: Monitor LED lamps?
3: caps lock on keyboard blink.
4: is the COIN cell dead? 2.9v to 3.3vdc good, lower volts is bad , as most are this old !!!
http://www.pcdied.com/intel-magic/xw4600.html
the service manual covers all this! ever heard of HP and there REAL pages,,???
why not read that?
(do the fans all spin, if not PSU is dead.
PSU fan is first. does it.
CPU fan , huge fan on heatsink must spin.
the stock GPU card has no fan (ASUSc card but mine does. at ATI card.as fan right on the express 16 card.
does the DVD drive eject work.
if any of the above fail the PSU is bad.
but we strip off all loads from the MOBO
to prove its not some part shorted. first.
the front LED on this PC has flash codes
mine flashes in sleep mode, or w10 power off.
w10 never turns power fully off, it uses hibernate to turn off, (unless i cure that, ask)
the factory manual starting on page 111 cover this.
fully.
i own this beast so .....
code 2 red is overheated.clean the PC and all fans.
code 3 red, processor errors CPU.
code 4 PSU dead or shorts on load buses of same.
we call them power rails, we bench test the PSU
or read page 111 , how.
code 5 = GPU RAM failure, this PC has on board, GPU chip only X16 slot card, replace it. or the DDR2 rams are bad.
code 6 = GPU card bad.
code 7= BIOS ROM, put in a new coin cell first.!!!
Code 8= BIOS, always do nee COIN cell first.
code 9 = cant boot hdd, hdd bad or software gone, or corrputed, PC can now boot to a linux live CD or USB stick proving now PC is ok,
only hdd and OS suspected now. code 9
coin.
http://www.pcdied.com/intel-magic/slots.jpg
page 111 is here, 24/7 !
http://h50146.www5.hp.com/lib/doc/manual/workstation/hp_workstation/WS_UG_xw4600_STRG_453080-001_screen.pdf
Sep 01, 2017 | HP Computers & Internet
WHY MI PC HP WORKSTATION XW6000 DO NOT TUR ON
Check first the power cable if it's properly plugged in, and if it's connected to a power bar, remove it from there and connect it directly to the power outlet
Jun 11, 2014 | Compaq HP Workstation xw6000 PC Desktop
Where and how to wire motherboard intel 775
You should be able to get the pin outs and connector specifications from the HP website for that workstation model. Go to the service manual and it will have detailed information on what you need.
May 20, 2014 | HP Workstation Xw4100 PC Desktop
Xw 4600 917-front audio not conntect
old post , error 917, sure, all do that when....
P23 wired cable fell off(or loose, its keyed)
or wrong panel used, (hp makes many , only 1 works here)
the offical, service manual covers all POST errors
and is still free, to see at real HP at any time.
Hit F1 and PC will boot ok, even with that error.
see p23 here.... front_audio jack, bottom left mobo.
Apr 22, 2014 | HP xw6600 Workstation with 650W 80 PLUS...
Hi i bought WD 320 gb sata /8mb hard drive - the cable ribbon on my dell 4600 does not plug into it! do i need a different cable yes
Generally speaking, we have two types of hard disk interface. IDE (the old one with ribbon cable) and SATA (with a 1cm strip like cable).
As your new hard disk is SATA, you need a SATA cable to connect it to you PC.
Below are a few images which would help you.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Sep 23, 2011 | Western Digital WD Caviar Blue WD3200AAJS...
Sata hardisk is not working "usb not recogenised"
Connect hardisk directly to computer without usb
go to start > run > cmd
type chkdsk /p enter
it will fix your problem
remove hardisk via safe remove
and connect via usb cable
Jul 29, 2011 | Conrad WD HDD 250GB SATA 35" WD2500AAJS...
I have a pavilion 7110Z and want to relace my hard drve.First I have to remove the old one. How do I get to it??
Its a easy thing you can do it.
1.Open your PC cashing.
2.Remove power and SATA /ID cable from your old Hard Disk.
3.Then remove it from your pc.
4.Add new Hard disk.
5.Connect the power and SATA/ID cable to your new Hard Disk.
Work done.
Thanks for using FixYa.
May 25, 2011 | HP Computers & Internet
My fujitsu laptop recently had a new hard drive installed in it ,but i want to transfer the data i have on the old hard drive that was removed from laptop to my new hard drive. I bought the all in one...
The Coolmax adapter is an USB hard drive adapter that can connect various types hard drives to your computer. This is used for testing and and transferring data to and from hard drives connected to the computer via the computer's USB port.
This Coolmax USB hard disk adapter can connect a 2.5-, 3.5- and 5.25-inch IDE or SATA hard disk to a PC. The black adapter box connects the hard disk, while the secondary power plug/adapter powers the drive. In the case of smaller notebook or SATA disks, the power cable is plugged directly into the adapter (as opposed to straight into the IDE hard disk).
The red USB cable, meanwhile, can be used to power hard disks directly from the host PC's bus via another USB port.
Connect the hard drive to the adapter as detailed above, power up your computer and plug the Coolmax USB cable into the conputer's USB port. The computer will detect and see this as an external drive, most likely as a E drive (the next drive letter that is available). Click on this drive and open to open the folder/s where your data is stored then select the folder/s and/or data and copy them, then open the hard drive on the computer and paste the folder/s and/or files onto the new hard drive.
Sep 29, 2009 | Fujitsu Siemens Computers & Internet
HOW upgrade the system and what can we upgrade?
Contact HP regarding a lease program. They will provide all new systems to your company, send technicians like myself to transfer all the data from the old machines to the new machiness, set them up inside your company, and pay you for your old hardware.
May 01, 2009 | HP xw4600 Workstation - 1 x Intel Core 2...
HP xw4600 Workstation - 1 x Intel Core 2 Duo E6850 3GHz - 4GB DDR2 SDRAM - 1 x 160GB - DVD-Writer  PC Desktop Logo
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
