Question about Car Audio & Video
Why does the auxiliary input device message randomly come on radio and disrupt the music for like three seconds then switch back?
3 Suggested Answers
mixmaster
  • 626 Answers
SOURCE: switching on the auxiliary input
According to the manual, the AUX input is an optional accessory.
Check to see if the RCA jacks are labeled. I believe they are pre-outs only.
Best of Luck.
Posted on Nov 12, 2007
  • 42874 Answers
SOURCE: I have the Jensen VR 185 Radio. It has an Auxiliary Input that appears to be left and right RCA connectors. Is there any way to use this for connecting an IPOD or similar digital device?
You can get an adapter that has a mini stereo plug on one end and RCA plugs on the other
Posted on Feb 26, 2013
My Pioneer radio the DEH-2460R has on the back the white and the red cabel plug in, but i can't seem to activate the aux function is this possible with this type of radio?
That's not an auxiliary input, it's an output. Pioneer units that have an auxiliary input use a 3.5mm mini jack, not RCA jacks. Your model does not have an auxiliary input, or any way to add one..
Aug 28, 2015 | Pioneer DEH-2460R CD Player
Tip
LG ENV as a touch connecting to an additional input
<p>You can use the 3.5 mm headphone jack on the Touch LG ENV to an audio device via an auxiliary input. If the audio cable is connected, the phone automatically updates all sounds cable. Then you can play music from the music player devices, such as car radios and systems external speaker. The 3.5 mm audio jack is a stereo connection, and is the audio standard for many electronic devices. <br /> <p><br /> <p>1. Connect one end of the audio cable to the 3.5 mm headphone jack on the Touch LG ENV. <br /> <p><br /> <p>2. Connect the other end of the cable into the auxiliary input device you are connecting. <br /> <p><br /> <p>3. Change the input of your audio device to take extra. Car radio, press the AUX button. See the device manual for specific instructions. <br />
on Aug 05, 2011 | Cell Phones
Can I connect a flash drive to logitech s715i?
The inputs are the Apple port (on the top) for iPod or iPhones, and the Auxiliary input for other digital music devices. You will need a 3.5mm headphone cable. The auxiliary input is located located just above the power connector on the back.
If you have a musical device that uses flash memory, then Yes you can. If however if you are reffering to a USB type of flash memory, there is no port for that.
May 18, 2014 | Logitech Audio Players & Recorders
Rear auxiliary input source select
Unfortunately, the input on the rear of the stereo are Bus inputs. You must use a controller to use those inputs.
May 13, 2013 | Sony XR-CA600X Cassette Player
Digital input glitch, switches randomly from analog to digital.
what connections do you use for the device you are listening to, and what device are you listening to when this happens. you should use either an analog, or a digital connection to a device, but not both
Mar 08, 2013 | Technics SA-DX930 Receiver
I need a wiring diagram for the IPC in a 2004 Cadillac Deville. Trying to troubleshoot a U0155 OBDII code. The symptom is that my climate control display only shows LED's intermittantly. All of the...
Do you know what U code's are for ? How did you pull this code ? There is no U0155 , U code's start at
Diagnostic Trouble Code (DTC) List
DTC
Diagnostic Procedure
Modules
U1000
DTC U1000 and U1255
Audio Amplifier, Cellular Telephone Module, DDM, DDSA, Digital Radio Receiver, DIM, EBCM, ESC, FPDM, HVAC Control Module - Auxiliary, IPC, IPM, LMDM, LRDM, MSM, PCM, Radio, Remote Playback Device CD Changer, RCDLR, RIM, RMDM, RRDM, SDM, Steering Column Module, Theft Deterrent Control Module, VCIM, Window Switch - Front Passenger w/armored car
U1016
DTC U1001-U1254
Audio Amplifier, Cellular Telephone Module, DDM, DDSA, Digital Radio Receiver, DIM, EBCM, ESC, FPDM, HVAC Control Module - Auxiliary, IPC , IPM, LMDM, LRDM, MSM, Radio, RCDLR, RIM, RRDM, RMDM, SDM, Steering Column Module, Theft Deterrent Control Module, VCIM, Window Switch - Front Passenger w/armored car
U1040
DTC U1001-U1254
IPC, PCM, SDM
U1056
DTC U1001-U1254
EBCM, PCM
U1064
DTC U1001-U1254
Audio Amplifier, Cellular Telephone Module, DDM, DDSA, Digital Radio Receiver, DIM, EBCM, ESC, FPDM, HVAC Control Module - Auxiliary, IPC, IPM, LMDM, LRDM, MSM, PCM, Radio, RCDLR, Remote Playback Device CD Changer, RIM, RMDM, RRDM, SDM, Steering Column Module, Theft Deterrent Control Module, VCIM, Window Switch - Front Passenger w/armored car
U1065
DTC U1001-U1254
DDM, DIM, ESC, FPDM, IPC, LMDM, LRDM, VCIM, HVAC Control Module - Auxiliary, PCM, Radio, RIM, RMDM, RRDM, VCIM
U1066
DTC U1001-U1254
DDM, FPDM, IPC, IPM, PCM
U1088
DTC U1001-U1254
IPC
U1096
DTC U1001-U1254
PCM, SDM
U1128
DTC U1001-U1254
Audio Amplifier, Cellular Telephone Module, Digital Radio Receiver, Remote Playback Device CD Changer, VCIM
U1129
DTC U1001-U1254
Radio
U1130
DTC U1001-U1254
Radio
U1137
DTC U1001-U1254
Radio
U1144
DTC U1001-U1254
IPC, Radio
U1151
DTC U1001-U1254
Radio
U1160
DTC U1001-U1254
IPC, RIM
U1161
DTC U1001-U1254
IPC, RIM
U1162
DTC U1001-U1254
IPC, RIM
U1163
DTC U1001-U1254
IPC, RIM
U1164
DTC U1001-U1254
DDM, Digital Radio Receiver, DIM, FPDM, IPC, LRDM, MSM, VCIM, Radio, RIM, RRDM, Steering Column Module
U1165
DTC U1001-U1254
DDM, FPDM, LRDM, RRDM
U1176
DTC U1001-U1254
IPC
U1192
DTC U1001-U1254
IPC, PCM
U1255
DTC U1000 and U1255
U1300
DTC U1300, U1301, or U1305
U1301
U1305
The data link connector (DLC) allows a scan tool to communicate with the class 2 serial data line. The serial data line is the means by which the microprocessor-controlled modules in the vehicle communicate with each other. Once the scan tool is connected to the class 2 serial data line through the DLC, the scan tool can be used to monitor each module for diagnostic purposes and to check for diagnostic trouble codes (DTCs). Class 2 serial data is transmitted on a single wire at an average of 10.4 kbps. This value is an average; class 2 uses a variable pulse width modulation to carry data and depending on the message it may operate faster or slower. The bus will float at a nominal 7 volts during normal operation. Each module can pull this lower during the transmission. The bus is not at battery positive voltage or ground potential during normal operation. When the ignition switch is in RUN, each module communicating on the class 2 serial data line sends a state of health (SOH) message every 2 seconds to ensure that the module is operating properly. When a module stops communicating on the class 2 serial data line, for example, if the module loses power or ground, the SOH message it normally sends on the data line every 2 seconds disappears. Other modules on the class 2 serial data line, which expect to receive that SOH message, detect its absence; those modules in turn set an internal DTC associated with the loss of SOH of the non-communicating module. The DTC is unique to the module which is not communicating; for example, when the inflatable restraint sensing and diagnostic module (SDM) SOH message disappears, several modules set DTC U1088. Note that a loss of serial data DTC does not normally represent a failure of the module that set it.
Your best bet ,take it to a qualified repair shop.
Jan 01, 2018 | 2004 Cadillac Deville
Just want to know how to get my mp3 phone to play music through the stereo
Depending on the phone there is a cable available for this, some phones also have a FM transmitter device (sold separately) that you tune your radio into it and can play songs from the phone. Most Nokia phones simply need a 2.5 or 3.5mm headphone jack to 2xRCA Cable, this will plug into the Auxiliary inputs at the back of most stereo systems.
Apr 05, 2011 | Car Audio & Video
Is it safe to dock an iPhone 3GS on the GPX CI109 eventhough it says that it's not optimized for this device?
Yes, it is completely safe; however, some functions might not work such as charging your device. Most likely though you will be able to perform all regular functions and be able to play music through the clock. None of this will affect, hurt, or damage your device.
Mar 25, 2011 | GPX CI109 Clock Radio with Dock for iPod ...
I have a Panasonic SA-PM31 stereo system with two auxiliary input methods: the first appears to be a common auxiliary cable input which says "phones." The second is a two cable input system...
The corect input for your ipod is another one who's name is "auxiliary" The "phones" input is dedicate only for pick-up, or another device who had to output a very small level signal. Your ipod have a high power level on output because he is amplified for a good level sound on your earphones. So, you can serious damage your Panasonic SA-PM31 sound system when input a too high level signal on "phones input" Phones is for unamplified audio signals like pickup signal direct from the head wires, or casette deck signal direct from the head wires. Gross (unprocessed) signal.
Dec 12, 2010 | Audio Players & Recorders
AUX inputs
Turn the ignition key to on or accessory position, turn the stereo off, then hold the function key for a couple seconds, the stereo will turn on and you scroll through the menu with the left and right arrow buttons and change settings with the up and down buttons
Feb 25, 2007 | Pioneer DEH-P6800MP CD Player
Car Audio & Video Logo
135 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
