Question about HP LaserJet M1120 MFP All-In-One Printer
Double side printing HP LaserJet M1120 MFP
I can't print double side, since I installed OSX Lion. Does anybody know this problem? I couldn't find any solutions in the internet.
  • HP Master
  • 1,679 Answers
Hi Franziska,
HP has not yet released Driver software for your MAC LION however there is a solution for this.
In order to print 2 sided ( duplex printing ) you need to install drivers and it is possible by doing Apple Update.
The link below will give you more details information of how to install the drivers.
MAC LION Driver Update
Once you have done the Update and installed the drivers, you will find the Printer name in Printers list.
Click on Printer Utility and under Layout you will find options to choose 2 sided printing
Regards,
Sean
Posted on Apr 23, 2013
  • Franziska Limacher Apr 23, 2013
    Thanks Sean. Finally I know why it doesn't work. =) But your link doesn't work. Can you perhaps post it again? Thanks for your help! Regards, Franziska
  • ONE-Touch-Solution
    ONE-Touch-Solution Apr 24, 2013
    It could be mistake from me as the link did not open. This link should be helpful::>>http://h10025.www1.hp.com/ewfrf/wc/docum...
SOURCE: SCANNER ERROR 20 of HP LASERJET M1120 MFP
PRINTER: HP DESKJET M1120 MFP DISPLAY SCREEN SAYS; "SCANNER ERROR 20"...
ANY IDEAS HOW TO FIX?
MANY THX!
Posted on Feb 04, 2011
  • 8 Answers
SOURCE: printer prints double sided only even though set for single
This is cause duplex printing option is enabled in the driver. If you have win XP, go to control panel and then printers & faxes.
Right click on your LJ P2015 printer driver and click on properties.
Click on the tab 'Advanced' and then click Printing Defaults.
Remove the check mark for 'Print on both sides' under the 'Finishing' tab.
Click Ok and Ok again.
Posted on Nov 24, 2008
  • 1894 Answers
SOURCE: Laserjet M1120 mfp does not print on legal page properly
go to printer settings and change the settings according to the paper size of your page.
Posted on Feb 08, 2009
leroyal
  • 2120 Answers
SOURCE: HP LaserJet 1320's will not print
It is looking for paper in the tray 1 assembly
Posted on Feb 21, 2009
leroyal
  • 2120 Answers
SOURCE: Double-sided printing on HP Laserjet 3330
Reinstall the driver..
Posted on Mar 05, 2009
Filter Failed
if this printer support Mac operating than u can print from Mac otherwise not possible.
Jul 12, 2013 | HP LaserJet M1120 MFP All-In-One Printer
My HP LaserJet M1120 MFP will not print if the network cable is plugged in
Mar 15, 2013 | HP LaserJet M1120 MFP All-In-One Printer
My HP laser jet M1120 MFP is repors error message when printing
Re install the tonner and then go to Printer & Faxes settings and delete the all kinds of pending documents and the go to print a new document and after taht send me the result...........what is happening.
Oct 01, 2012 | HP LaserJet M1120 MFP All-In-One Printer
I'm using a HP LASERJET M1120 MFP. But every time I turn on the machine the screen says "Scanner Error 20". How to fix it up? Thanks!
The printer received more data than can fit in available memory.
You might have tried to transfer too many macros, soft fonts, or complex graphics. Press GO to print the transferred data (some data might be lost). Try to simplify the print job or install additional memory.
Hope that helps!
Feb 28, 2011 | HP LaserJet M1120 MFP All-In-One Printer
My Hp Laserjet M1120 MFP showing message "Scanner Error 6"
switch off the printer, then remove all cables connecting to the printer but just the power cable.
-then press and hold the *(start/symoble) and 5 button togather and turn on the printer.
-continue holding the button till you see "perment storage init" displayed and releas the button.
-then at a given point of time the printer will ask you to change laguage,time,date etc.
if this does not sort the issue service is required
this is work on 3055
so i think this work on your printer
Jan 04, 2011 | HP LaserJet M1120 MFP All-In-One Printer
My HP M1120 MFP laser printer reports a 'no print cartridge' message even I INSTALLED NEW ONE WHAT IS THE REASON
There would have beena jam on the printer.. Just take out the paper and then reseat the Cartridge to have it worked...
It worked for me..
Nov 18, 2010 | HP LaserJet M1120 MFP All-In-One Printer
Lazer jet M1120 MFP scanner error 22
Hey I'm using a HP LASERJET M1120 MFP. But every time I turn on the machine the screen says "Scanner Error 20". How to fix it up? Thanks!
Nov 03, 2010 | HP LaserJet M1120 MFP All-In-One Printer
Scanner error 6
Problem for HP LaserJet M1120 MFP All-In-One Printer Scanner error 6
Feb 22, 2009 | HP LaserJet M1120 MFP All-In-One Printer
Laserjet M1120 mfp does not print on legal page properly. But it prints on A4 size paper properly
Feb 08, 2009 | HP LaserJet M1120 MFP All-In-One Printer
HP LaserJet M1120 MFP All-In-One Printer Logo
144 people viewed this question
Ben Johnson
