Question about GE JGBP28SEHSS Gas Kitchen Range
Oven will not turn off
I hava a GE Gas Kitchen Range oven and it will not turn off. It will heat for about 10 minutes and maybe turn off for about 1-2 minutes before lighting up again. This continues all day.
  • 640 Answers
It sounds like the pilot could be restricted and not heating the thermocouple completley,or the t-couple is weak.is there ant drafts hitting the oven?
Posted on Aug 05, 2007
SOURCE:
Why doesMy GE gas range broiler and oven not ignite?
When my oven had this problem it turned out that the ignitors for both the oven and broiler had gone bad - yep, both of them. You can tell when an ignitor is bad if it doesn't glow as the oven is started.
I posted some pictures here (I think my answer is #10):
Check out this solution to the GE Profile Spectra JGBP90 Gas Kitchen...
Of course the design of your oven might be different but I suspect the repair would be very similar. Regardless, check to see if the ignitor is glowing.
Jul 08, 2014 | GE Profile Spectra JGBP90 Gas Kitchen...
Xl44 GE GAS RANGE OVEN WONT WORK, RED LIGHT IN
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
czvb
May 09, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
Describe your GE Profile Spectra XL44 Oven
My GE Profile Convection Microwave Oven will beep and display a F2 for no apparent reason. What is this?
Mar 09, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
About six months ago, my GE XL44 gas range (purchased Dec 2002) started showing signs that it's not maintaining the oven temp I set. I tried running the self-clean cycle, but that didn't change anything....
heatman101
Dec 28, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Ge gas oven not working
thermocoupler needs to be replaced...
Dec 12, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
I have a GE Profile Gas Range with a double oven. The bottom oven takes 20 minutes to warm up to 300 degrees. Is this normal? I was told the bottom oven is electric, which I haven't used electric in years,...
my oven does the same thing. i do not believe that the oven is electric though. the only electric part on my oven is the control board. if the oven was electric it should heat up much sooner than that,
Apr 14, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Turned on self clean on my GE Spectra JBP24B0B4WH Range
Hello Cliff Hendershot,
One USA manual ... said turn off power for 10 minutes
(sounds reasonable after looking up cost of control board)...
USA websites are not responding to your number.
Closest I could get was to a $78 (us dollar) control panel
>> ((IMPORTANT PART ... has a video that shows repair))
http://www.appliancepartspros.com/ge-oven-control-t09-wb27t11312-ap5177950.html
I could NOT get a good READ on your JBP24... page 8
So I attached a JBP19 (below)... Page 12.
The most COMMON reason to FAIL after a cleaning cycle
is your OVEN CONTROL is "off normal"
(You still do not have your MANUAL MODE restored).
Normal = "AUTOMATIC" LIGHT Off (NOT LIT)
Check your "oven controls"
else
Oven elements do break during routine use...
Check both roast & bake elements for continuity.
GE JBP19 Owner Manual Usingthe Oven
Carnac the Magnificent
Jun 08, 2017 | GE Profile Spectra JGBP90 Gas Kitchen...
Temperature control
sounds like a bad bake ignitor(uneven heat,long cook times, long preheat times, perhaps even gas smell while cooking)
Sep 29, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
GE JGBP28SEHSS Gas Kitchen Range Logo
101 people viewed this question
Top Kitchen Ranges Experts
Ismael Rodriguez...
Steve Allison
Steve Allison
Archie Ferrarini
Archie Ferrarini
Are you a Kitchen Range Expert? Answer questions, earn points and help others
