Question about RCA 27F634T TV
Problem with RCA TV Model 27F634T
It made a popping sound, the screen turned green, then shut off. Now when I turn it on, I get loud static sound for a few seconds then it shuts off. What is the most likely problem?
    President:
  • 2,992 Answers
You almost certainly have a bad picture tube. The green screen was from one of the elements inside shorting out. The static sound you're hearing is the high voltage arcing out through the end of the picture tube to other parts inside the set. It's more economical to buy a new TV than to repair this one.
Sorry to have such good news, but this is one of the ways a picture tube can go bad, and it happens quite often.
Posted on Mar 11, 2009
Rca F35720SB makes popping noise then shuts off
It may be arching from the flyback. If you are familiar with tv's remove the plastic case plug it in and turn it on and see if you can see anything visual happening. Make sure not to touch anything and keep a safe distance when inspecting.
Oct 30, 2012 | RCA 27F634T TV
LCD HDTV turns off, displays lines & static w/ loud noises
check in your manual and follow instructions on updating the software. you download the file to computer then move it to a memory stick (USB), then simply insert it into the tv
Mar 01, 2010 | Televison & Video
RCA model 27F634T
on that one ive had the button board causing problem--remove board--spray wd40 on buttons--push buttons a few times--wipe off bwd--reinstall bwd
Sep 16, 2009 | RCA 27F634T TV
Loud clicking noise and nothing on screen
Maybe your TV is shutting off the power due to a shorted out backlight bulb.
Nov 17, 2008 | RCA L26W11 26 in. HD-Ready LCD Television
TV randomely turns off
it may just be a static buildup from the dust.
open the tv and blow it out with a air compressor.
if that doest not work then the circuit may be overloading.
remember it stores a charge for days.
Feb 17, 2008 | Philips 30PW9817 30" TV
TV will not come on
How old is this TV?
Sounds like it has high voltage failure.
(If you hold your hand on the screen when you try and turn it on, do you feel the static? )
Unless the set is over 10 years old, I would overhaul the high voltage circuit. Should cost under $200 at a shop.
Jan 03, 2008 | RCA 32F531T 32" TV
RCA 27F634T
Have you tried to access the menu features and tried to retune the stations on digital, or are you hooked up for analog.
If you don't know about what i speak, give me a yell. jr@excel.net I believe my remote sensor card is bad. While this might explain why you can't turn yours off, it would not explain the blank picture. If the menu does show, i would think the picture tube is O.K. if the menu does not show, there are some other things to look at.
Dec 29, 2007 | RCA 27F634T TV
32 RCA makes popping sounds
It needs a new FLY BACK transformer. That is what you are looking at. The origionals are not made for the set any longer but insist on having a generic on installed by a local TV shop. I just put one into a RCA 31" and it works nice. Don't throw away the TV. Get it fixed. MAKE SURE YOU INSIST THEY USE THE GENERIC ONE! THEY DO WORK!
Sep 15, 2007 | RCA E13320 13" TV
Television will not turn on
look on the rear of the set and find out what chassis in your set.
Aug 30, 2007 | RCA 32V550T 32" TV
RCA 27F634T TV Logo
191 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
