Question about Marantz SR-5200 Receiver
Missing sub woofer signal i SR 5200 - Marantz SR-5200 Receiver
2 Suggested Answers
dunnbiker
  • 8546 Answers
SOURCE: have marantz sr 4003,
RTFM
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Marantz-SR4003-Receivers-manual/id/23041ag600/t/2/
Posted on May 20, 2011
How to splice a sub-woofer to speakers
Normally the sub woofer is driven by a separate amplifier, unless the main speakers, such as in a pro audio setup have a special LF out set of terminals on the back of the speaker cabinet, in this case there is a hi powered low pass filter, fitted in side the speaker to route the LF energy to a sub woofer. Else you need a line lever LF signal spliter and a power amplifier to connect a sub woofer.
Jan 26, 2017 | Audio Players & Recorders
Trying to hook up a KLH sub woofer, S100ETH, PSW8-100 to a VCR reciever. Reciever has sub woofer connection but does not works on the KLH sub woofer. What is the problem ?
I suggest you go over your receiver set-up instructions. See if you need to set the receiver to acknolwedge the addition of the subwoofer. It should be in your receiver set-up steps. Just as a check, hook up one of your other speakers to the subwoofer lead to see if gets audio signal. I'm guessing the issue is your receiver settings.
Jan 06, 2015 | KLH Audio Players & Recorders
Subwoofer is not playing
It is hard to say. The sub-woofer has its own amplifier, although it is supplied the sound data from the main amplifier. It could have a problem with the battery power circuit (Sub-Woofer Amplifier Connector Pin 6, LIGHT GREEN/VIOLET) or it could have a problem with the GROUND circuit (Pin 2, BLACK/LIGHT GREEN) Or it could possibly not be receiving the signal from the main amplifier (Pin 7, BROWN/ORANGE "+"), (Pin 8, RED/BLACK "-"). Or it could be that either the sub-woofer speaker is blown, or the sub-woofer amplifier is defective.
There is also a "High Audio Mute" circuit that connects between the main amplifier and the sub-woofer amplifier.
Mar 06, 2012 | 2000 Lincoln Navigator
Do you plug the sub woofer outputs to another amp?
Yes, for best results. Your subwoofer should have a seperate amplifier because it has low pass filter that produces low frequency signals. It is done by connecting the sub woofer output to the input signal of the amplifier and then connecting the output signal to the subwoofer speaker terminals. Hope this helps.
Jul 01, 2011 | Car Audio & Video
How to get two M-282's to power one non-powered sub
you can't get 2 amps to drive 1 sub since your amp is not designed to be able to run in mono or bridge mode.
However, what you can try is to reverse the + and - terminal.
The reason is that if the sub is place at a location where the wave cancels out the wave, it'll actually make the entire base go lower.
So sometimes reversing the polarity will have the enhanced effect.
Give that a try.
Also, you may want to consider using the main out rather than the subwoofer out as the sub out may have a filter build in that may actually get in the way of the signal.
Jul 23, 2010 | Onkyo M-282 2-Channel Amplifier
Velodyne sub woofer: Series S Model: VA08BVX10
The volume control pot can be replaced.
Any good quality audio shop or electronics repair shop should be able to fix this.
Nov 17, 2009 | Velodyne SPL-1000 Subwoofer
Sub-woofer Malfunction
sub can be detecting signal from your amp. maybe your amp has some small output when in standby mode. some amps throughput signal from satellite boxes when they are supposed to be off.
try shutting off that signal source as well.
good luck
mark
Dec 28, 2007 | Sony SA-FT1H TV Speakers
Sr7200 LFE (sub woofer) output stopped working
Chances are if The Receiver only has sound in Stereo Direct Mode and all surround modes and Sub out are Inop the DSP (Digital Signal Processing) Card is most likey defective. These boards are not available from marantz (D&M Holdings) and must be Component level repaired which usually is not cheap. If Only the Sub out is not working check setup to be sure sub woofer is set for on. Also If On Screen setup menu does not appear on video monitor Unit may need to be Reset manually which entails discharging a Capaitor on main P.C.B Contact kstahl65@att.net for details
Dec 16, 2007 | Marantz SR-7200 Receiver
Center & sub-woofer problem
The outputs may have died if this is the case you will need to get them fixed by a proffesional
Mar 15, 2007 | Creative Labs Inspire 5200 Computer...
Marantz SR-5200 Receiver Logo
18 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
