Question about Garden
Gas coming out of muffler
I have replaced the carburetor and fuel solenoid. After the mower starts there is gas coming out the muffler due to excessive gas being dumped into the intake.
  • Gene Brown Apr 21, 2013
    It is a brand new carburetor!
  • 7,482 Answers
Hi gbrown_monah
Sounds like you have dirt/debris in your caburetor jets,fuel passages
Check/Clean/Replace your Air Filter, a dirty air filter can make your engine run to rich with fuel.
Note: ALWAYS USE COMPRESSED AIR TO CLEAN YOUR JETS AND PASSAGES, VERY IMPORTANT.
Note:Before you disassemble the carburetor:
Write down on a piece of paper and or take a picture of how the linkage attaches to your carburetor for later reference when you go to reinstall your carburetor.
Mark each piece with a awl, or some kind of sharp instrument that will make an alignment scratch before you disassemble the carburetor into separate pieces.
That way you will know which way it goes back together when you reassemble it.
Sometimes you can get by with priming the carburetor or by using a very small shot of starting fluid and letting it run a few times like that, and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Be sure to check your fuel tank for water and dirt/debris, if there is water/debris then you need to clean your tank.
Check you fuel line/s condition...after a while they will degrade and need replacement.
Check/Clean/Replace your fuel filter if you have one.
When you remove your fuel lines from the carburetor be sure to make a drawing or take a picture of how the lines are connected to the carburetor.
Also a good time to take a picture for later reference for reassembly.
If the mower is over a couple of years old, then I recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
The diaphgram may look good and flexible, but it can be deceiving and not act as a fuel pump as it should because it has become too hard and will cause hard starting,start and run and shut off, etc.
When you clean your carburetor, I recommend that you use a laquer thinner type cleaner to clean and dissolve the laquer build-up in the float and needle jet passages.
Be sure to remove all plastic and rubber parts before using the laquer thinner because it can dissolve the plastic parts and render them unuseable.
Be sure to use COMPRESSED AIR to blow out all the fuel and air passages.The higher air pressure is needed to blow some of the trash/debris from the fuel or air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Keep in mind that the float (if you have one) for the carburetor must be level when you go to reassemble the carburetor or follow the instructions you get with the carburetor kit, or you could also ask the parts man that you get your kit from.
When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their original position before you started.
Once you have your carburetor cleaned/rebuilt that should solve your problem.
Please take time to rate me
Bud
Posted on Apr 21, 2013
SOURCE: Toro walk behind model 20025 Gas running through the carburetor
Carb. float must be stuck open. First if you have no fuel in the tank it must all be in the crankcase.Drain the oil and refill and also check the carb as the float has to be sticking open. Hope this will help you. Donnyb60
Posted on Mar 18, 2009
slohry
  • 87 Answers
SOURCE: I need an owners manual for a Sears Blower/Vac Model #517.797940
Have Mod and ser #'s available
http://www.searspartsdirect.com/partsdirect/index.action?sid=PSHx20080129x00001
Posted on Apr 10, 2009
SOURCE: Gas Leak
Use Rectorseal pipe dope on the threads (avail at Home Depot)
Posted on Jul 30, 2009
backwoodsctr
  • 169 Answers
SOURCE: I have a Stihl BG55 Blower Gas comes out of muffler.
you have a piece of trash/debris under the inlet needle of the carb and or a welch plug has come out, ive seen this many times on zama carbs, if its within warranty bring it back to your service center for a new carburetor.
Posted on Nov 18, 2009
SOURCE: I have a poulan pro bvm200 leaf blower, was
the bvm 200 model has a 25cc piston and ring the rings are infamous for getting clogged and baked into theyre seat,this creates a compwesion problem and it will not start,gets fuel spark but without compresion it'll just not run or start,if careful you can remove the piston soak it with ring atached in carb cleaner and get it springy again or replace the ring with a new one it has a 1.353 (34.38)mm bore and a ring thikness of .061 hope this helps
Posted on Nov 04, 2010
Parking brake, lawnmower won't start.
  1. Out of GAS: It sounds crazy, but it happens!
    Make sure you check your fuel level each time before you fire up your mower.
  2. Stale Gas Leads to Clogged Carburetor: How long ago did you fill up your gas tank? And how old was the gas you used?
    Gas only has a shelf life of about 30 days because of the ethanol it contains. If you have old gas in your tank, the ethanol may have caused corrosion and clogged your carburetor.
  3. Clogged fuel filter: The purpose of the fuel filter is to filter out all of the sediment from the gasoline.
    This filter can get clogged up from normal sediment, or from stale gas containing ethanol.
    The lack of proper fuel flow to the carburetor will prevent your mower from starting.
    If this is the case, the fuel filter will need to be replaced.
  4. Dead Battery: Batteries typically last a long time, but there isn't always a warning sign that it is going dead. Check your battery with a voltmeter to see if it's lacking juice.
    If you have a 12V battery, the voltage should read very close to 12V. If it's less, your battery may not have enough juice to start the mower.
  5. BAD STARTER SOLENOID: If you turn the key in your ignition, and hear a clicking sound, it is probably your starter solenoid.
    If you notice this clicking, your best bet is to install a new starter solenoid.
  6. DISCONNECTED DIRTY SPARK PLUG: Did you recently perform maintenance? Maybe you left your spark plug wire un-hooked! Be sure to check this out, this is a quick and simple fix.
    Your spark plug could also be dirty or damaged. Spark plugs are cheap, so try replacing your spark plug.
Jun 10, 2018 | Cars & Trucks
Carb seems to allow fuel to drain from gas tank when not running - pumps it out the muffler when starting
Your fuel needle in the carburetor is not closing out, float in the carburetor bowl needs to be adjusted. . What's happening is that the float needle isn't sitting in the seat all the way causing the fuel to continue to flow and naturally the gas has no where else to go except out of the carburetor itself.
Oct 05, 2015 | John Deere Garden
A lawn mower that gas comes out of the exhaust.
It sounds like the float in the carburetor is stuck in the open position.This will allow fuel to flow through the carb and out the muffler.
May 04, 2015 | Garden
Troy bilt troubleshooting
Your carburetor is probably gummed up and dirty, or float in carb may be bad. The float shuts the needle and seat off and stops flow of gas into the carburetor. If it's gummed up or float is bad or dirt in the bowl of carburetor etc. it will not shut fuel off and gas will just keep flowing and get into engine. Will run out muffler and also possibly into crankcase(engine oil). Check oil for over full condition and if it has strong gas smell. Good idea to change it anyway.
Aug 15, 2014 | Garden
I have a gvc 160 honda motor on a troybuilt lawnmower. It is brand new. Went to start it for the first time and it shoots gas out of muffler and wont start,
Hi rick2624...
You have a stuck fuel inlet needle valve and it is allowing gas to flow thru the carburetor right into the cylinder and out your muffler.
You have a choice to make...
1. Remove the carburetor and clean it of the trash/debris around the needle.
2. Tap the carburetor with a small hammer around the bowl area and sometimes this will free a stuck needle valve.
3. Return the mower to the dealer you bought it from if still under warrenty.
Free answer...Please take time to rate me
Jun 20, 2011 | Honda Garden
Bought this lawn mower.It was sitting for two years and now it won't start.
first things first:
1) make sure that the kill for the magneto/coil is breaking contact( it is on the side of the mower,follow the cable down from the red bar)
2) gas to carburetor
3) spark to plug/s
4) gas to cylinder/s
pull plug and try starting mower, observe spark plug for spark and fuel coming out of cylinder/s. if spark no gas, then check to see if it getting to the carburetor, if it is then it is the float and seat in the carburetor and will need to be cleaned/replaced/rebuilt. Or just simple pour gas into the carburetor and try starting if it starts then it is the fuel line, carburetor. Hope this helped Tim
May 22, 2011 | Garden
Have troy bilt riding lawn mower engine is not getting gas through carb. what is the solenoid thats attached to the carb?
That is the fuel solenoid that allows gas to get into the carburetor when it starts up. The fuel solenoid opens up when the key is turned on to allow fuel into the main jet of the carburetor.
go to www.precisionope.com, you should be able to find an Illustrated parts list on the engine.
Sep 28, 2009 | Troy Garden
Murray riding mower 12.5 hp briggs & stratton spitting oil & gas out of carb & muffler when trying to start
Drain oil... it is full of gasoline due to a bad float pin and rubber gromet in your carb. When your float pin and gromet fail, gas just keeps flowing into your carburetor, eventually flooding your motor with gas and oil mix.
Jul 07, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
101 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
