Question about HP Officejet 5610 All-In-One InkJet Printer
No computer connection for printing - HP Officejet 5610 All-In-One InkJet Printer
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 23 Answers
Uses a standard USB cable you should be able to find at a local store or like this
Posted on Apr 22, 2013
Can't print. Lexmark has an x by offline
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer (if USB connected)> reboot your pc > unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer (if USB connected). Then try to print again once the computer fully recognizes the USB connection or when the WiFi light on the printer turns solid green (if WiFi connected.).
If that doesn't help, try the steps below:
  1. Disconnect the USB cable connecting the printer from your computer.
  2. On your computer, go to Control Panel > Printers and Faxes.
  3. Delete the Lexmark print object.
  4. Reboot computer.
  5. Re-brick your printer by pulling out the power supply - black box where the power cord is plugged into on the back of the printer, and re-plug after 30 seconds.
  6. When the printer turns on, reconnect it to the computer.
  7. Wait until your computer fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, try to print a document to verify that the problem is fixed.
Mar 10, 2012 | Lexmark X6150 All-In-One InkJet Printer
MFC_5840CN Will not print, not showing
Typically, a Brother machine stops printing, because the connection between the computer and the Brother machine is lost. There are multiple reasons for a lost connection.
  1. The Brother print driver is Offline.
  2. The Brother printer driver is not set as the default printer driver.
  3. The computer, not the monitor, connected to the Brother machine is set to go into sleep or standby mode. When the computer goes into sleep or standby mode, the connection between the computer and the Brother machine is lost and needs to be re-established.
Follow the steps below in order to re-establish the connection between the Brother machine and the computer:
  1. Verify that the Brother machine is connected with a USB cable and is not on a network.
  2. Verify the power cord and USB cable are securely connected. If the USB cable is loose on either end, disconnect and reconnect the cable securely. Test the machine by trying to print. If the machine does not print, go to STEP3.
  3. Cycle the power of the Brother machine by unplugging the power cord from power outlet, wait approximately one minute and plug back in. Once the Brother machine displays the date and time after plugging it back in, test the machine by trying to print. If the machine does not print, to Step 4.
  4. Reboot the computer connect to the Brother machine and then try to print again.
Apr 01, 2008 | Office Equipment & Supplies
How can I fix printing hesitation on my lexmark x5495
  4. Reboot computer.
You may also try to update your printer driver by visiting the Lexmark website at http://bit.ly/hsBChY. Select your operating system, download and execute the file.
Feb 16, 2012 | Lexmark X5495 Printer
Not able to print
  4. Reboot computer.
Jan 25, 2012 | Lexmark X8350 Print, Scan, Copy and Fax...
Lost connectivity after power outage
If this is a printer WITHOUT WiFi or bluetooth - and you have it connected to another computer (Print Server) via a USB cable - you need to make sure you can see that computer from the other computer you are printing from. Use the network explorer - if you can see the computer and the printer you should be able to print to it.
Sometimes, it may be secured with a password. I found if I can map a shared drive from my laptop to my print server then I can print again. So see if you can see the printer and printer server computer from the other computer. If so you may need to add that printer again to you printer list.
May 01, 2017 | Zonet ZPS3611 Print Server
The setup wizzard does not see the print server
Is your print server and the computer connected to the router with the Ethernet cable. if not then connect both the print server and computer to the router with the cable.
then try it.
you can press the reset button on the print server for 5 to 10 seconds and you will get a print out ( printer should be connected to the print server).
on this print. you will find the IP address of the print server.
try to open the print server set up interface of the print server.
Click Here for more information.
Oct 05, 2009 | Computers & Internet
Switching from copy to print from computer
If you look carefully at the printer you'll note that there is no button for "Print" and the reason for this is that all the other functions are for using the printer as if it wasn't connected, nor needed a computer.
All your printing functions that DO use a computer require you to interact with the printer via the computer.
In short, to use the printer from the computer you'll need to make sure you've installed the correct drivers (see your installation CD or the Canon website) and then plug the printer in using a USB cable connection to your computer. If the computer recognises the printer you'll then be able to print.
In a nutshell if your printer is connected and drivers installed properly it doesn't matter what your printer has selected on the printers own control panel, you just print :)
Hope that helps.
Feb 13, 2009 | Canon PIXMA MX700 All-In-One InkJet...
HP 7210 all-in-one is having trouble printing. At best, will print just the first inch or so of the document---at worst, prints only a few symbols at the top, or prints a meaningless barcode-like pattern,...
It was a connectivity problem between the computer and printer. I had recently switched from a direct USB connection to a non-powered USB hub. Apparently, routing through the hub resulted in an inadequate, inconsistent connection between the computer and printer, so print jobs were garbled or only parts of the page were getting printed. Switching the USB cable back to a direct connection between the printer and computer completely resolved the problem.
Dec 02, 2008 | HP Officejet 7210 All-In-One InkJet...
Computer not recognizing print server
If you connect your printer directly to your computer, were you able to print? Make sure that there is no firewall enabled in your computer (Double check windows firewall or any personal firewall, that could have been enabled).
Jul 12, 2008 | Linksys PrintServer for USB with 4 port...
HP Officejet 5610 All-In-One InkJet Printer Logo
Seeker5211
Seeker5211
