I have a Mitsubishi big screen tv model vs-60603. It will turn on then off. can someone help?
I have seen older posts on here for the solution. do you know where i would be able to purchase STK 392-570?
I have a 1998 Mitsubishi VS 60603/ 873G projection television receiver. the picture is not sharp anymore, appears cloudy, what is the problem?
Mitsubishi Electric Customer Phone Number Shortest Wait Best Support
How to Fix Cloudy Spots in LCD TV Screens eHow
Dec 16, 2014 | Mitsubishi Televison & Video
We lost power to the Mitsubishi Big Screen Television Model # VS-60603. I can't get the picture in a picture to shut off and I can't get the other options that use the TV to work such as the Wii, DVD...
IF SET will not go to inputs (they do not show) this model (circa 1998) does have a OPTION menu to do a hard reset with the Mitsubishi remote.
I have the information. Confirm model and I will tell you how to attempt this.
If this told you something you did not know, rate this solution and comment here and I will tell you how.
SD TECH
Sep 16, 2010 | Mitsubishi VS-60603 60" Rear Projection...
Can the front screen of the projection tv be replaced? This one has two big slits down the front. 1999 Mitsubishi Big Screen Tv
i had the same problem with my old tv there is a plastic pane that was badly scratched on mine i had it replaced if there is material behind that that is tore i wouldnt see why it couldn't as long as it is the same texture and thickness preferably the same call your local tv shop to see if there is a special order for the same material
Dec 21, 2009 | Mitsubishi VS-60603 60" Rear Projection...
How do you to turn off the pip feature on a Mitsubishi VS-60603 tv remote control?
hello on the remote control the should be a button half black and half white this is the pip button good
luck
shaun
Oct 03, 2009 | Mitsubishi VS-60603 60" Rear Projection...
Big screen won't work
also a color wheel that has gone out ..replace it.
May 20, 2008 | Mitsubishi VS-60603 60" Rear Projection...
Lost the remote to my mitsubishi big screen tv
Just bought a new remote for my VS60603, then main board goes bad upon moving to new location. Never used it. Interested in purchasing it? Email tomasg01@msn.com.
Apr 21, 2008 | Mitsubishi VS-60603 60" Rear Projection...
Mitsubishi VS-60603 60 in pink spot
I have seen this before, and I can only describe it as a flaking of the phosphorus coating in one of the picture tubes. If you can, remove the back such that you can take a flashlight and look down into the 3 picture tubes. If you see any flaking or dark spots in the phosphor, there will be a spot on the screen missing that color. Unfortunately, this is not repairable, as all 3 tubes would need to be replaced (like replacing all 4 car tires when one is completely bald) and that would cost more than a new TV.
Jun 06, 2007 | Mitsubishi VS-60603 60" Rear Projection...
Televison & Video Logo
14 people viewed this question
Top Televison & Video Experts
Electro Med Services...
