Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
Hard starting loading up with gas in cylinders when it does start it blowes white smoke runs a couple min. than dies wont start for at least 15min.
Float valve in carb is leaking fuel into engine. It ususally gets in the oil,too, when this happens. clean float valve and change the oil. Or put a shutoff valve in the fuel line and close it everytiime you park it (not a good solution but it works.)
Posted on Mar 12, 2009
1995 2500 chevy truck is hard to start once it starts acts like it wont kick off surges and blows white smoke what could be problem?
check for a coolant leak as white smoke indicates burning coolant. it could be a head gasket or cylinder head problem. this can also cause a hard start as coolant won`t burn like gas. to do this you will have to get a head gasket test done.
Nov 03, 2014 | Cars & Trucks
Blowing white smoke, stalls after starting, lack of power, bad gas mileage, idols high
Blowing white smoke indicate that your burning prestone in your cylinder. Probably a hed gasket tht is craked and leaks into your cylinder , if not than it's a craked head or block again leaking into a cylinder. have you car checked for a leakdown test of your cylinders.
I bet you'll find where your prestone is leaking.
Feb 24, 2014 | Vehicle Parts & Accessories
Smoke coming out of engine
White smoke? Coolant is getting in the cylinder and the white smoke is really steam. Sounds like you have a blown head gasket. Bad news is that it needs to be replaced...good news is that the inline 6 cylinder engine is one of the easier head gaskets to replace. I've never replaced a head gasket but did it on my Cherokee just three months ago. If you tag your parts and pay attention how they are taken off you can do it. The other option is to replace the engine as they are pretty cheap to get. Good luck.
Jul 28, 2013 | 1990 Jeep Cherokee Limited
It blows white smoke out the tail pipe when i start it
You must have a leaking engine cylinder head gasket. Have a local shop confirm this for you as it is a very expensive repair.
Jul 17, 2012 | 2003 Chevrolet Cavalier
After starting car it sputters and white smoke from exhast. I drive the car for 5 min, sputtering the whole time, and turn it off - will not start until it is cranked and gas pressed for couple min. Then...
White smoke is usually from water and water will make the car splutter. Did you get water in your tank at some time. If you have water in your fuel, you will have to drain the tank and refill with good fuel. The engine will run fine once it is hot but if a lot of water goes into a hot cylinder it can cause a lot of damage.
Apr 01, 2010 | 1998 Oldsmobile Intrigue
Car smokes, wont stay running
You most likely blew a cylinder head gasket.
Aug 16, 2009 | 1989 Nissan Maxima
Husqvarna 323L gas trimmer runs & starts great but looses power after 10-15 min and if you give it gas it dies. let it cool and it runs great for another 10-15min. trimm has less than 5 hours
You have a clogged gas cap. Try this: The next time you run your trimmer and it starts to die, loosen the gas cap. It should start running again. It sounds too good to be true, doesn't it?! Well, give it try. Clear the breathing holes form debris, or buy a new gas cap.
Jim
Jun 07, 2009 | Husqvarna 28cc Gas Line Trimmer
Hard starting smokes white like gas is getting into cylinders
White smoke in a small engine is oil. Oil in the cylinder will create too much pressure for the engine to achieve compression. Make sure the engine is not getting fuel into the oil and thinning the mixture (literally smell the oil... gasoline and oil smell nothing alike, if it smells like gas, it is). If this is the case, the carb is leaking fuel into the engine, thinning the oil and causing the oil to leak past the rings into the cylinder head, through the valves and, from there, into the exhaust to burn off. Black smoke indicates a direct fuel issue in a small engine, white is oil based.
Mar 11, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
190 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
