Question about MSI RS482M4-ILD Motherboard
Im using RS482M4 mother board my problem is that it freezes wen i connect the HDD and dvd rom
    Renaissance:
    An user who is expert in 3 categories / brands.
  • MSI Master
  • 2,226 Answers
Http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?DetailID=39&MenuID=24&LanID=0
Posted on May 21, 2014
3 Suggested Answers
  • 1126 Answers
SOURCE: problem to attach sata hdd
http://www.msi.com/index.php?func=downloaddetail&type=manual&maincat_no=1&prod_no=173
Hope this guide helps.
Posted on Jul 09, 2009
joecoolvette
  • 5660 Answers
SOURCE: how to connect power swicth on MSI RS482M4-ILD Motherboard
http://www.xpcgear.com/msirs482m4.html
The front of your computer is the Front Panel.
The area of contact pins on the motherboard, that the main wires from the Front Panel go to, is the Front Panel header.
What you need is a Front Panel header pinout.
Looking at the photo in the link above, the Front Panel header is AT the bottom corner.
Motherboard mounted in the computer case, the header of pins all the way to the Right, and Bottom, is the JLPC1 header.
The JLPC1 header is used for board level debugging by MSI, and is not used by the consumer.
[Two rows of pins. Third one from right missing, Top row ]
The header to the left of JLPC1 is the JFP1 header.
Front Panel Header. {Junction Front Panel 1 }
Two rows of pins.
4 across the Top row, 5 across the Bottom row.
The pins are numbered EVEN across the Top row.
The pins are numbered ODD on the Bottom row.
Starting from the Left side of the motherboard going right;
on the Top row,
Pins 2, 4, 6, and 8. There is NO pin 10.
Starting from the Left side going to the right; on the Bottom row,
Pins 1, 3, 5, 7, and 9.
A) Pins 1 and 3 are for the HarDDrive activity LED. (Light)
Pin 1 is for the Positive ( + ) wire.
If the HDD LED is dim when operating, switch the two wires around.
B) Pins 5 and 7 are for a Reset switch, IF a Reset switch is used.
C) Pin 9 is N/C. Not Connected.
D) Pins 2 and 4 are for the Power On LED.
Pin 2 is for the Positive ( + ) wire.
If the Power On LED is dim when the computer is on, switch the wires around.
E) Pins 6 and 8 are for the Power On switch.
MSI Support > RS482M4-ILD > Manuals download page,
http://www.msi.com/product/mb/RS482M4-FD--ILD--IL--L.html#/?div=Manual
Scroll down
Under Download click on E7191v1.2.zip
Click on the country nearest yours
A small window will come up on the right -
Opening E7191v1.2.zip
Make sure there is a green dot, in the small circle to the left of - Save File.
If not, click in the small circle.
Now click on OK.
A small window will come up on the left. In the wording at the top, tells you where the file will download to.
It may have Desktop, or My Documents, or Downloads, in the wording.
[Or if you are using a version of Win Vista or Win 7:
Desktop, or Documents, or Downloads ]
Windows XP:
Desktop: The file will be on your desktop screen
My Documents: Click on Start, then on My Documents.
Downloads: Click on Start, then on My Documents. DOUBLE-click on Downloads.
Win Vista / Win 7:
Desktop: The file will be on your desktop screen.
Documents: Click on the Windows logo button, then on Documents.
Downloads: Click on the Windows logo button, then on Documents. Click on Downloads.
In the next window go all the way to the left, click on Extract all files.
At the bottom of the next three small windows, click on Next, next, and Finish.
In the last window DOUBLE-click right on - E7191v1.2, next to the red Adobe PDF icon.
There is your Motherboard Manual, in PDF file form.
Regards,
joecoolvette
Posted on Jul 19, 2012
D101GGC mother board makes long beeps and fail to boot up. I removed rams, dvd rom, floppy drive, hdd and finally removed the cmos battery for a minute and put it back. it failed to boot up. But once I...
The fact that the board is making a long beep is usually a sign of a memory problem. This may be the RAM has failed (try with one stick at a time or some new RAM ) But, it could be more serious- The memory controller can also cause the same problem. This can be on the motherboard or part of the processor. Your motherboard is now obsolete as there have been at least 2 new CPU sockets released since. You motherboard is old and so the problem is most likely to be a failed onboard memory controller. But, try the RAM first if the fault remains I would suggest a new board. Sorry!
Apr 17, 2013 | Computers & Internet
I have changed the motherboard from Intel to Gigabyte(GA-G32M ES2L) since then the problem of my pc freezing while playing games started. My configuration is Processor:Pentium D...
1) Make sure that your Power Source is giving enough energy to the new Mother Board and make sure it's compatible.
2) Make sure that the new Mother Board is compatible with all of your current hardware, you can check this in the webpage from the Mother Board Company.
3) Check the voltage requirements for the Mother Board, check the BUS speed of the Mother Board and compatibility with the transfer speed of each of your current hardware.
4) It's never recommended yo change only a Mother Board since usually there's going to be problems with the rest of the hardware if it wasn't changed, if the problem persists, you'll have to buy new hardware that is compatible with your new Mother Board.
5) If you know how a BIOS works and how to configure one, you could also check the configuration in the BIOS, not sure it will work but it's worth a try if you know what you're doing.
May 27, 2011 | Computers & Internet
Trying to install on windows 7
um, more information would be nice.... im assuming you are trying to install the OS its self?
1) when you boot, go to your bios options (usually f8 or f12, it says when you turn your computer on)
2) go to the boot order menu and move the CD-rom/ DVD-rom drive to boot before the hard drive (sometimes denoted as hdd)
3) place the cd in and reboot your system (after saving the changes!)
note: some motherboards have the boot menu as an option (usually f2, but it depends on the mother board manufacturer). if you see that, you can pick that option instead of the bios menu, and it will give you the choice to boot from your cd drive!
May 08, 2011 | Computers & Internet
My dvd does not appear in my computer or device manager
Check the SATA/IDE connection and make sure it is securely connected to the mother board and the drive, and that the power connector is securely connected to the drive. If you cannot see the drive in the BIOS, then you have a bad drive or bad connection on the mother board.
Feb 11, 2010 | Compaq Presario 700 Series DVD-Rom Drive...
Sata dvd rom cause the computer to crash, is it because its plug in to the wrong plug in on the board or the sata on the motherboard isnt the right one im trying to install a sata rom on a gateway 5474,...
on pata ,flate data cable use in long connerter . on sata cable we use thin and flatcable join in n small squire port. some bord have both type port we can use diffrent port in same time . but port should be good. i think there no chance to join different connecter joining. we look seriously. in any coonater we saw cuttin g shape or male female shape. power cable of smps which join in hdd/cd room may be lose when we join any part it can be short so connecting any cable before we do switch off or pullout powercable.
Nov 05, 2009 | SuperMicro LiteOn SSC-2485K - Disk drive -...
Hoe to install the mother board
first install the processor. then the mother board places in the casing. screw it up. then add ram, hdd, dvd rom. at last connected the power cable, restart cable, hdd light, power light.
Jan 20, 2009 | Intel CELERON 2.66Ghz CPU AND MOTHER BOARD...
DVD Rom will not run?
MAY BE FOLOWING PROBLEMS
1. Check your power dvd sofgtware, if present then uninatll, then install its again.
2. check connectivity to hard mother board.
3. check in OS.
Mar 27, 2008 | Televison & Video
CD ROM DETECTION PROBLEM
LEAVE YOU hard drive on primary master port on your main board set as master or single drive ( IF YOU HAVE A STATA HARD DRIVE THEN DONT WORRY ABOUT THAT PART)
SET YOUR FIRST DRIVE AS MASTER
SET THE SECOND AS SECONDARY
use the jumber in the back of the drive to set them the propper setting is labeled on the drive it self
Connect them to the secondary port on your motherboard
so you should have
HARD DRIVE - MASTER OR SINGLE *jumper settiing* connected to the primary port on your main board
DRIVE 1 = MASTER *jumper settiing*
DRIVE 2 = SLAVE *jumpersetting*
connected to the secondary port on your mother board
IF YOU HAVE A SATA HARD DRIVE FORGET THE PARTS ABOUT HARD DRIVES ABOVE
i assumed you had a IDE hard drive
JUST USE THE SETTINGS FOR THE DRIVES and it should work :)
Dec 25, 2007 | Samsung (SH-M522C/BEBN) CD-RW/DVD-ROM...
MSI RS482M4-ILD Motherboard Logo
57 people viewed this question
Top MSI Computers & Internet Experts
vsri9
David
David
Matthew Spark
Matthew Spark
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
