Question about Sony Str-De575 Stereo Receivers
Sony STR-DE575 connected to 220V
Hi I am a lucky owner of the Sony STR-DE575 receiver. I bought it in 2004 in the US. However, currently I live in Europe, where obviously we have different voltage. I have been using a proper adapter to convert the voltage.... till the last February. When accidentally I have connected it directly to 220 V. Well, my wife did it, to be more precise. The receiver blinked only, as he wanted to say 'Goodbye'. I have brought it to the repair shop but they told me that since it is a US product the parts that have to be replaced are not available here. They told me that the main circuit board has to be replaced and the standby transformer (I am not sure if I translated those terms correctly). Here come my questions: Do you think it is worth to fix it? Where can I get the mentioned above parts? and what are the proper technical terms describing them? Any kind of help is greatly appreciated. bets regards from Poland Przemek
    Genius:
  • Sony Master
  • 1,054 Answers
Doubt the main pcb needs replacing, but the standby transformer would definitely go in that situation. Standby transformer wouldn't be that expensive, but no way to say that it's the only thing that is bad. It is also soldered in, so you would need to know how to do that to replace it, or bring it to someone who could. If you're staying long-term in Europe, it might just be better to buy something local so as to not run into this problem again.
Posted on Apr 19, 2013
  • Sri Kumar
    Sri Kumar Apr 23, 2016
    I just replied above.. Standby transformer was the problem. So fixed myself and its working fine now. Thanks for ur response..
It happened to me also. i hooked my STR-DN1050 into 220V which is supposed to support only 120V. being my first big electronic gadget i didnt notice this. so eventually i managed broke my AVR. i have some trouble shooting knowledge so i managed open the cabinet and i saw there's a 125V/8A fuse blown up. so i thought thats a simple fix. so i got 5fuses of 125v/8A from ebay USA. i was unable to find it in india. i replaced it and turned the power on with 120V stepdown transformer. still its not powered.
so i decided the problem is extensive. so i started to deep dive what the standby PWB does. i got a multimeter and checked the voltage at the input of the main transformer, the reading was 0. that means main transformer is not getting the AC voltage.
before the main transformer there's a relay then some other circuits
then an another small transformer. i opened the relay plastic housing with little brakage and looked into it. the relay looked fine.
i checked the voltage input to the relay but there's no voltage to driver the relay. actually this is the relay which drives the AC power to Main transformer. now i tried to manually active the relay, suprisingly the power fed to AVR and showing the display and other things. so its confirmed the all other circuits fine.
now the problem is voltage across the relay. this voltage is given by a small standby transformer. i checked the voltage across the transformer which showed zero. remember i checked the voltage across the transformer directly on the PCB so if there's a short in rectifier circuits then its hard to measure the voltage.
my next step is to check the transformer in open circuit and check the diods. i will update the results. Pls someone guide me on this trouble shooting.
if my standby transformer is faulty where i can get it or what is the alternate idea. i beliive its 120v/5v transformer. if i am unable to get it can i change it with anyother transformers?
Posted on May 29, 2015
  • Sri Kumar
    Guys, oops i forgot to update my problem.
    Good news.. As i mentioned. I desoldered the transformer off the standby PCB and fed 120v power to it to check if there's any output of 9v(required ti drive the relay). Yeah the culprit is that transformer. There's is no output from it. So i tried to but the same part from sony supplier. But those suppliers only supplies to the authorized technicians. So i thought i could rewind the transformer coil or to check any fuse inside the transformer. As i suspected there's a fuse ans which blown up by the high voltage i gave it to audio video technicians and fixed the problem he charged only Rs.220(~4$). Soldered back and boom.... My AVR back to life. Around 8month its working without any problems..
5 Suggested Answers
  • 63 Answers
SOURCE: Sony STR-DE705 question
yes you can use a step down converter,but remember to use a higher rating converter.if your receiver need 100w ( or 1A )then you need a converter at least give 150w ( or 2A ).
Posted on Aug 06, 2007
rogrrabbit
  • 986 Answers
SOURCE: I HAVE A SONY STR-KG700 5.1 SISTEM, AND SOON I`LL
I would just buy a transformer for the unit 220 to 120. That way when you move back your good to go.
Posted on Jun 14, 2009
Merlinblaise
  • 10 Answers
SOURCE: No sound at all when headphones are plugged in
Hi, I apologize in advance for not offering a solution. Have just trolled through the handbook (on-line) for anything that might offer a clue. It takes both high and low impedance units so that's cool. They say to use the phones to assist with speaker issues and there's nothing to suggest that any of the settings affect them. Depending on the impedance the volume levels can change a fair bit so I guess you've cranked it up to check. The fact that they turn off the speakers doesn't add a lot, it can often be a simple mechanical switch in the socket when the plug is inserted. Does the 'speaker off' indicator come on when you plug them in. The only other things I'd suggest is both try another set of phones regardless and the other is reset all the sound settings to factory and see if that has any affect. Else you likely have an issue with the phone interface circuitry.
Posted on Jan 05, 2012
palaboy
  • 5807 Answers
SOURCE: Speaker Imedance Matching - Sony STR DE 997 receiver with 120Watts - 8 ohms output with Benz 6 ohms..Tower Speakers
hi pawanh75,
thanks in advance for a very informative setup that you have.
Here are some of possible mods , only if you like and can DIY
( or have someone to help you )
• Using a 6 ohms impedance for an 8 ohm impedance amp clearly
denotes that it heats up the output stages.
(please forgive my very technical words)
• One way to lessen the heat is to install a blower .
Use a 220V blower on top of the receiver.
( air should be in going up direction ).
• Before I proceed further please indicate if having the speaker
connected and having a zero volume , and just letting the receiver
in an "On" state deliverately produce heat on the receiver, or just
when the volume is at medium to high level.
If it s running hot at zero level with speaker , please post.
If it is running hot even without speaker, post also
• It may also helps , if you have a powered subwoofer ( for the low's),
and set settings on your receiver to "small"
Let me know what you find to help you further.
Posted on Sep 12, 2012
Sony AVR STR-DN1040 didn't support 220v and broke
in some devices bring a swich for 220 and 110, the problem is that you connected in a line of 220, and We will probably be hurt the transformer internal fuse, you have to open it to bypass it or change it after that you have to protect the device with unfoco in series just in case you have a short.
Sep 07, 2013 | Sony STR-DN1040
Sony STR-DE575 5.1 Channels Receiver I have power to everything but I am getting ZERO sound. Is this something that is fixable or do I just need to replace my receiver?
Have you looked in the manual? Basic speaker setup with test tones will certify the basic hardware. Then onboard FM. Then add the compexity of external and digital sources.
Aug 26, 2011 | Sony STR-DE575 Receiver
I have a Sony AM/FM Receiver Model # STR-DE575. It shut off when I was listening to it, and now wont turn back on. When I push the button there is a little "click" noise inside and that is it. ...
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'nekkid'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections at the speaker as another possible root cause for intermittent shutdown.
Aug 23, 2011 | Sony STR-DE575 Receiver
How do I hook the STR DE 575 up to my tv?
Usually if you have a Cable or Satellite box, you would hook up a Fiber Optic or Digital Coax cable from the Sat/Cable box to the Sony Receiver. Then for HD, an HDMI cable or componet cables from the Sat/Cable box to the TV
Dec 18, 2008 | Sony STR-DE575 Receiver
My reciever does not work
Power Amp IC gone in your set, replace it.
Jul 30, 2008 | Sony STR-DE575 Receiver
Patio speakers
connect them to the front left and right outputs.connecting them to the sub-woofer will give poor sound because it only pick's up bass sounds during playback
Oct 29, 2007 | Sony STR-DE575 Receiver
Unable to hear dvd audio when dvd playing on Sony STR-DE575
Hi The first thing to do is disconnect the red and white audio cables from the back of the receiver, and plug them directly into the tv. If you then have sound from the DVD, then you have eliminated the possability of no audio coming out of the DVD player. If the DVD player checks out fine, then I would try plugging the jacks into another aux input on the receiver, and select that and see what happens. Also, if there is a "tape monitor" button on your Sony, make sure it is turned off. I'll assume the receiver has sound from other functions, so it would be rare for one of the inputs to just stop working, (but certainly not impossible), I'm not familiar with that model, and normally I would say it could just be a dirty selector switch, but since you mentioned having a remote, then switching between inputs is done by the microprocessor, not a physical switch, so if you cannnot get sound through using another input, then it could be expensive to repair. Hope this helps, and good luck!
Apr 30, 2007 | Sony STR-DE575 Receiver
Sony Str-De575 Stereo Receivers Logo
146 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
