Question about Panasonic PanaFax UF-490 All-In-One Laser Printer
Panasonic PanaFax UF-490 Problem with Drum Unit
Our office fax told us to replace the Drum Unit which we have dutifully done. However it is still telling us to replace said drum unit. We have attempted taking out the drum unit, turning off the machine and replacing it once more all to no avail. The fax has now started claiming that it has a document mis-fed or a document jam frequently even when it has no paper jammed in it at all.
    Problem Solver:
  • 10 Answers
For manual setting.. when replacing the drum unit.. press function 7 thend scroll down select maintenance then scroll donw select drum unit then press 2 to clear the usage.then press 1 for yes.
jamming or misfed?
try to check the drum unit you install.see if the drum not installed properly. turn off and on the unit
Posted on Jan 30, 2008
You have to type a code in to tell it that the drum has been changed. Page 16 of the manual. Function 7 8 SET 2 SET 1 1
Posted on Sep 10, 2007
SOURCE:
Warming up error code 2 2 hours warming up my machine bizhub 600
Sir/Mam,
Have you had the developer and drum replaced recently, or does the screen say Replace PC Drum? There are certain house chores the copier does before "Ready to Copy" it is waiting for them to get done, so that equals "Please Wait". One big item is making sure the developer and toner are properly mixed inside the image unit underneath the drum or next to it depending on the series. Might want to have the developer replaced and drum/cleaning blade normally done all together, then run the F8 procedure/Developer Charge, and make sure the counters where cleared. Did you recently replace the drum and the developer if so did you clear the counters for the drum and developer, FIRST? IF not then the copier thinks the new drum and new developer are old. The copier works on the counters that is how it knows it got a new drum and developer. Get new developer and a new drum and have it installed correctly. Counters are clear before the unit is yanked out of the machine, then you remove the image unit/drum unit replace the developer/drum and cleaning blade. (DO NOT USE A VACUUM CLEANER WHEN REPLACING THE DEVELOPER static electricity can destroy the sensor located below the developer unit. Then reinstall and RUN F8/Developer Charge. Make sure the fax line and Ethernet cable is removed can't print anything until the F8 is run. Or you will start all over again with new developer and a new drum.
Sep 25, 2018 | Konica Minolta bizhub Office Equipment &...
Konica minolta bizhub 601 warming up option donot show ready to copy
Sir/Mam,
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Apr 19, 2018 | Konica Minolta Office Equipment & Supplies
My bizhub 350 still says please wait even the fuser unit & lamp is ok. how do i reflash firmware?
Sir/Mam,
Feb 02, 2017 | Minolta bizhub 350 Black and White Copier
Konica minolta 710 is stuck on "now warming up" I can scan but not print.
Sir/Mam,
Aug 18, 2016 | Konica Minolta Office Equipment & Supplies
When want a copy ,it says ready to copy but won't. ?
Sir/Mam,
Apr 30, 2016 | Konica Minolta Bizhub C350 Digital Copier,...
Bizhub minolta 600 and 750
Have you had the developer and drum replaced or does the screen say Replace PC Drum? There are certain house chores the copier does before "Ready to Copy" it is waiting for them to get done, so that equals "Please Wait". One big item is making sure the developer and toner are properly mixed inside the image unit underneath the drum. Might want to have the developer replaced and drum/cleaning blade normally done all together, then run the F8 procedure and make sure the counters where cleared. Did you recently replace the drum and the developer if so did you clear the counters for the drum and developer, FIRST? IF not then the copier thinks the new drum and new developer are old. The copier works on the counters that is how it knows it got a new drum and developer. Get new developer and a new drum and have it installed correctly. Counters are clear before the unit is yanked out of the machine, then you remove the image unit/drum unit replace the developer/drum and cleaning blade. (DO NOT USE A VACUUM CLEANER WHEN REPLACING THE DEVELOPER static electricity can destroy the sensor located below the developer unit. Then reinstall and RUN F8. Make sure the fax line and Ethernet cable is removed can't print anything until the F8 is run. Or you will start all over again with new developer and a new drum.
try this site for developer and drum as a start
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Apr 21, 2014 | Konica Minolta Bizhub C454 Color Copier
Toner for fax machine 2920
If your machine is a Brother Intellifax 2920, it does take a TN-350 toner cartridge. Maybe you were wanting to replace the Drum Unit instead, DR-350. I'll bet this info is useful, yes?
Jul 03, 2009 | Brother FAX-2920 Plain Paper Laser
Office Fax is telling us to replace drum unt.
Look at the sticker on the machine to get into Maintenance and clear the drum count. I think it's Function 9 set.
instructions should have been in the drum box.
Feb 24, 2009 | Panasonic PanaFax UF-490 All-In-One Laser...
Brother 2820 fax machine
THE DRUM AND THE TONER CARTRIDGE IS IN SIDE OF THE MACHINE.OPEN THE COVER AND YOU WILL SEE THE DRUM CARTRIDGE,TTAKE OUT THE DRUM UNIT. ITTELLS YOU ON THE DRUM UNIT THE NUMBER DR    IT IS SOLD IN OFFICE DEPOT OR OFFICE MAX OR STAPLES, MAKE SURE THAT YOU ONLY USE BROTHER PRODUCTS. GOOD LUCK BROTHER SR TECH
Feb 02, 2009 | Brother IntelliFax-2820 Laser Fax
Replaced drum fax 2820
Hi, #'s 6, 7 and 8 below explain how to reset the drum indicator.
Hope that helps...
Lbcoaster
How do I replace the drum unit?
Description:
Follow the procedure below to replace drum unit.
CautionDo NOT use flammable substances or any type of spray to clean the inside or outside of the machine. Doing this may cause a fire or electrical shock.
spray1.gif Caution
    Just after you have used the machine, some internal parts of the machine are extremely HOT! Never touch the shaded parts shown in the illustration.
  1. Open the front cover and pull out the drum unit and toner cartridge assembly.
Caution
    To prevent damage to the printer from static electricity, do not touch the electrodes shown below.
  1. Hold down the lock lever on the left and pull the toner cartridge out of the drum unit.
Note
    • Discard the used drum unit according to local regulations, keeping it separate from domestic waste. Be sure to seal the drum unit tightly so toner powder does not spill out of the unit. If you have questions, call your local waste disposal office.
    • Wait to unpack the new drum unit until immediately before installing it. Place the old drum unit into the plastic bag.
  1. Unpack the new drum unit.
  1. Reinstall the toner cartridge into the new drum unit. If you put it in properly, the lock lever will lift automatically.
all-ug-16.gif Caution
    To avoid print quality problems, DO NOT touch the shaded part shown in the illustration.
    If you accidentaly touch the shaded part, wipe the surface with a dry lint-free soft cloth.
  1. Install the drum unit and toner cartridge assembly in the machine.
  1. Press Options.
  1. To confirm you are installing a new drum, press 1.
  1. When the LCD shows Accepted, close the front cover.
Related Models FAX-2820, FAX-2910, FAX-2920, MFC-7220, MFC-7225N
Aug 02, 2008 | Brother IntelliFax-2820 Laser Fax
Panasonic PanaFax UF-490 All-In-One Laser Printer Logo
307 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
HEMANT GROVER
mahesh y.h
mahesh y.h
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
