Question about Car Audio & Video
Jvc r728bt - Buttons are not functioning
Only the menu button on the deck is functioning when it's held down for a few seconds. The only thing that works is my remote.
MrLard
  • 94 Answers
SOURCE: Faceplate not responding / acting very weirdly
Sounds like a bad connection with the faceplate and the multi connector that the faceplate mates with when closed. check for dirt and bent pins on both connectors. Luck
Posted on May 04, 2007
SOURCE: Dead Buttons
i had the same proplem, inside buttons not working, took unit appart (quite easy). you just need to remember where all the little screws go back into. i need that cable though!! thanx for the part number!! c ya
Posted on Jun 13, 2007
SOURCE: Interface Problems
If you're pressing on the "rotary encoder", then it's you. But if you're not and instead you're just turning it without pressing, you may have a defective unit. Try literally pulling on the thing while turning it. If that avoids triggering the other functions then either you'll have to get used to being gentle, or you need to take it back or send it to Alpine (again, probably just the front faceplate unit needs work...not the whole radio).
Posted on Oct 09, 2007
Lando93
  • 8 Answers
SOURCE: JVC KD-R200 won't power up for more than 5 seconds
Check your wires they might be touching steel around your car mostly look at your yellow and red wires those are the 1' that give it power and light to your radio also check your radio fuse in the back.
Posted on Jun 10, 2009
kenw392
  • 2226 Answers
SOURCE: my Kenwood KDC-BT945U display stopped
more than likely, there may be some bad solder connections inside of the radio.
Posted on Jan 18, 2011
Insignia tablet won't reset to facotry setting
Hold down Volume Up + Power button for about 10 seconds. You ought to release held keys as soon as you see the Android Robot. To enter the Recovery Mode hold down the Power key for a few seconds. From the menu choose "Wipe Data/Factory Reset" by using Volume buttons to scroll and Power button to select options.
Mar 19, 2017 | Tablets & eReaders
Sansui TV/VCR/DVD combo
This solution is provided by one of our experts premtech
Child Lock
Combos
--Should have original remote. Press and hold the power button for 6 to 10 seconds
Combo Model T25208, V-Chip Forgotten Password
If you forget your password, simultaneously press VOLUME down on the TV/VCR front panel and the 0 number button on the remote for a few seconds. This resets the password and you can enter a new one.
Combo Model 13TVR62, V-Chip Forgotten Password
If you forget your password, press STOP/EJECT on the TV/VCR front panel and MENU on the remote simultaneously. This resets the password, but not the limits you’ve set.
Televisions with Parental Lock Feature
If you forgot your password for this feature, press the following buttons on the remote, one at a time. (Note: You must be in the password entry screen) Press, Mute, Display,Clear and Reset, this unlocks parental controls and you can now re-enter a new password.
OR TRY THIS..
Press and hold Menu on the TV AND volume down on the remote for 3 seconds. Nothing will appear on the screen, and the Parental Controls will unlock, and you can re-enter a new password with the LOCK PARENTAL CONTROLS
CTC169AU
Channels that have been locked can be viewed only when the PARENTAL CTRL function is set to OFF. This can only be done with the remote control-it can not be changed with the buttons on the front of the TV.
Therefore, after you turn on PARENTAL CTRL, you simply hide the remote control so that your children can not watch the locked channels. The locked-out channels will remain unviewable even if the TV is unplugged or the channels are autoprogrammed again. The only way to view locked channels is to use the supplied remote control to set the PARENTAL CTRL function to OFF.
The PARENTAL CTRL and the CHAN CTRL functions work hand-in-hand. The instructions below will first tell you how to turn parental control on or off with the PARENTAL CTRL function and then how to lock desired channels with the CHAN CTRL function.
1. Repeatedly press MENU to select SETUP MENU, and then press + or - to display setup functions. Repeatedly press MENU to select the PARENTAL CTRL function. . When this function is set to ON, PARENTAL CTRL is activated and any channels you locked with the CHAN CTRL function will not be viewable. . When this function is set to OFF, PARENTAL CTRL is deactivated and all channels are viewable.
2. To lock channels, press the MENU button to select the CHAN CTRL function. Select a channel you want to lock by pressing CHANNEL up or down. Then press +. The CHAN CTRL setting will change from NORMAL to LOCKED when that channel is locked. To return the channel to NORMAL, press the - button. Repeat step 2 for each channel you want to lock. If the PARENTAL CTRL function is set to ON while you are locking out channels, each channel will go blank as you lock it. When the PARENTAL CTRL function is set to ON and a channel which has been locked out is tuned, the TV will display the words PARENTAL CONTROL to let your kids know you have locked it.
CTC185's
If the front panel function buttons don't work, (menu, ch up/dn etc.) but the functions work normal with the remote, enter the "Channel" menu with the remote and turn "Parental Control" off.
CTC203's
In the event you have forgotten your password, perform the following procedure:
Press and hold for 3 seconds the TV button on the remote while pressing the menu button on the TV.
This procedure will turn off the parental lock and erase the previous password .
Another Possibility To Try For Various Models: If TV's in the Parental mode and askes for a password that's forgotten, Press menu on the TV, select Parental Lock #4 on menu, then with the remote press Mute, Display, Clear, and Reset buttons in sequence.
TX808 Chassis
If Parental Controls have been set and you don't know the password, do this:
Press and hold the volume down and the channel up buttons at the same time for 5 seconds.
Now you can reset the password to 0000, and using that password you can now access the V-Chip menus.
TV's (Made by Daewoo or possibly Apex, ie. GE model 24GP653)
The factory default pass code of 6688 is also the override code, in case the owner forgets their pass code. If that doesn't work, another place in the owners manual says to push Function and Mute on the remote at the same time. Function is the top right button.
Jun 28, 2008 | Sansui DTV2760 27" TV
Tip
Service menu codes jvc
I provide this information for those that are qualified and trained to do TV repair work. Entering or making changes in service mode by untrained persons can cause significant and permanent damage to your television. If you are not qualified to service your television, please DO NOT ENTER these service menu codes.
-Press the {MENU} button and go to the User Menu screen, make sure
that the indicator (arrow) is pointed and highlights the "Picture Control".
- The buttons on top of the remote are set to TV & VCR respectively.
- Set sleep timer to "0" minutes and while it is displayed, simultaneously
press the {VIDEO STATUS} & {DISPLAY} buttons.
- The main service menu will be displayed with choices #1 through #9.
- Press one of the corresponding number keys to enter that menu.
- Use the {CH+} {CH-} buttons to navigate within a menu.
- Use the {VOL+} {VOL-} buttons to change the values.
- Use the {MUTING} button to memorize the changed value.
- Use the {BACK} button to exit the service menu.
Turn the TV on.
Using the remote control:
- Press the {INFO} & {MUTE} buttons at the same time.
- The Service Menu will be displayed
- Use the number keys to select the category.
- Use the {VOL+} {VOL-} buttons to enter the category.
NOTE: Some models don't have category selection.
- Use the {CH+} {CH-) buttons to select item to be adjusted.
- Use the {VOL+} {VOL-} buttons to change values.
- Press the {INFORMATION} button to exit.
Turn the TV on.
# Press {DISPLAY} & {PIC MODE} buttons at the same time.
# The Service Menu will be displayed
# Use the number keys to select the category.
# Use the {UP} {DOWN} buttons to enter a category.
# Use the {LEFT} {RIGHT} buttons to select items.
# Use the {UP} {DOWN} buttons to change values.
# Press the {DISPLAY} button twice to exit
# Press the {MENU} button.
# Select "Clock Set".
# Set clock to 3:21 AM and press "Start Clock".
# While a "Thank You" message is displayed on screen, press the {MUTE} and {MENU} buttons.
# The Service Menu will come up.
# Use {UP} {DOWN} to select items.
# Use {LEFT} {RIGHT} to change values.
# To exit, turn the TV Off.
on Apr 29, 2015 | JVC Televison & Video
JVC kd-r210 flashes and won't power up?
Sub
You need to look through the JVC KD-R210 manual.
A JVC Dealer / Installer may have seen a similar problem & suggest remedy.
Jul 14, 2014 | JVC Kd-r210 Car CD/ MP3 Player
Resetting without going to the menu for a vizio m220nv
Get into the Vizio TV service mode
There are to options to get into Service mode:
Option 1:
Turn the Vizio TV off.
Press and hold the CH + & CH - buttons on the TV.
Then press and release the POWER button on the TV Vizio.
Release the CH+ & CH- buttons.
Now press the MENU button on the remote.
You should get your regular menu up, but with a "F" in the bottom right corner of the menu (This if for factory reset).
Press and hold the MENU button for few seconds.
The Service Menu will be displayed.
Option 2:
Turn off th Vizio TV.
Press and hold the CH+ & CH- buttons on the TV Vizio.
Then press and hold the POWER button on the TV.
Keep all three buttons pressed for few seconds.
Feb 18, 2013 | Vizio M220nv 22-inch Full Hd 1080p Led Lcd...
Locked rca tv and don't have remote
Without its remote control you can't unlock this TV. If you have the remote control, the proceedings are:
Most RCA sets use a four digit code to control the v-chip. The code reset is different depending on the model. Try each number until you find the one that works for you.
1. Hold down the MENU button on the remote and VOLUME DOWN button on the TV it's self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
2. Hold down the 0 (zero) button on the remote and the VOLUME DOWN button on the TV itself at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
3. Hold down the MENU button on the front of the TV and the TV button on the remote at the same time for at least 4 seconds. 4- Hold down GO BACK button on the remote and MENU button on the front of the TV at the same time for at least 4 seconds.
  1. Hold down EJECT button on the front of the TV set and the MENU button on the remote at the same time for at least 4 seconds. Depending on the model, one of the methods should unlock the V-chip. Now, if desired, you can change the settings on the V-chip by going to the MENU and going to PARENTAL CONTROLS, or on some sets, going to MENU and then going to TV SETUP, then to V-CHIP SET.
Sep 14, 2012 | RCA Televison & Video
RCA LCD TV locked up.
Aug 12, 2012 | RCA RCR312W Remote Control
RCA Truflat TV 27F522T is completely locked both manually and remote do not work. Was working manually but after checking menu for block accidently FPA locked not can't turn on tv at all.
You must have its remote control to unlock this TV. Try to make your remote control get repaired, and check these.
Jun 28, 2012 | Televison & Video
Downloaded manual for Kenwood KDC-MP528, but instructions for setting clock time is sketchy, and can't get " clock adj." to come up, no matter in what sequence I hit instructed buttons....
Try putting the radio in standby mode and then hold the menu button in for a few seconds. Once you enter the menu, use the am or fm buttons to scroll through the menu. Then hold the seek up or seek down for a few seconds until the clock flashes, You should then be able to use the am/fm buttons and seek up and down buttons to set the hours and minutes. Once you have the time set, press the menu button again.
Aug 03, 2011 | Kenwood KDC-MP528 CD Player
Car Audio & Video Logo
281 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
