Question about LaCie 320GB Lacie D2 HD Sata II 7200RPM 8MB Usa SATA II Hard Drive
My lacie hard drive is not showing on my laptop.
I took it together with my laptop to PC World where I bought the laptop and when it was tested on a desktop there it did not show up either.Is there anything I can do to rectify this?
  • innovisiongh Mar 12, 2009
    It worked! thank you very much.
    Scholar:
  • 77 Answers
Try and see if the device is detected/found in Computer Management.. To acces computer management: click Start, click Run and type in compmgmt.msc.. If is device is found in there format your drive and then it u should work as usual
PS: Please rate this solution
Posted on Mar 11, 2009
  • dahonogzerah
    dahonogzerah Apr 15, 2013
    device is not recognized in my laptop, help?
Blue light come on when plugged into laptop but does not show on laptop
this drive is mainly a Network drive. To use it with the USB, if you have a PC, you will need drivers that can be downloaded from LaCie. If you have a MAC, there are no way to use the drive with USB.
If you have a Router at home, connect the drive to it with an Ethernet cable and then use the LaCie Network Assistant to access it. It is easier.
Regards,
Jan 17, 2011 | LaCie Ethernet Disk mini USB 2.0 External...
I bought a few years ago a Lacie d2 safe hard drive with AES Encryption (with biometric fingerprint sensor). Currently not my Toshiba desktop or IBM laptop pick up the hard drive when I switch it on. The...
Hi... Problem with your external hard drive, pc don't recognize it...
it possible you have bad sector in your disk drive, or your usb cable is not responding.... the best way to find out open your box then take off our hard drive and install it into a pc and see if the hard drive work... or you box it self the controller inside our external box maybe damage,
Oct 20, 2010 | LaCie External USB 2.0 500GB 7200 RPM 500...
LaCie Big Disk 500GB not showing up
1. the usb connector in the PC may have a broken board contact needs soldering or replacement.
2. there may be a broken USB cord to the external usb drive
3. the electronic controller in the USB case may not be working.
4. A new case may be needed with a new controller.
Jul 08, 2010 | LaCie Big Disk Extreme 500 GB Hard Drive
Lacie 320gb external harddrive which was connected to an eMac and is now connected to an Acer laptop. I've reformatted it as NTFS and it shows up in disk management as healthy but does not appear in...
The drive letter and USB port are not inherently tied together. you can give it a drive letter as long as nothing else is going to use that letter inherently, and be fine. Did giving it "F" work?
Aug 28, 2009 | LaCie Hard Disk 320GB with Hi-Speed USB2.0...
Lacie RUGGED 250GB not recognized by my PC
I think the migration assistant (in the utilities file in your application folder) can transfer files direct via USB.
Jan 23, 2009 | LaCie Design by F. A. Porsche 160 GB Hard...
Is my LaCie External USB 2.0 500GB fried/dead???
You're not missing any step at all, because with SATA hard drive if its really working your computer should
automatically detect it and since this hard drive suddenly stop working there's a possibility that its already
fried but if you want you can try this hard drive again to a different computer and if still not detected by
second computer its already dead.........
Nov 07, 2008 | LaCie External USB 2.0 500GB 7200 RPM 500...
External hard drive
500Gb Lacie D2 Quadra with the same problem of flashing led and not mounting on the desktop (Mac G4 Mirror), traced to the power supply (57w) going down on power, both 12v and 5v supplies are available but the main power to run the drive drops to below an adequate output, hence the clicking and whirring evident from the drive with simultaneous flashing led.
Testing with another Lacie power supply (250Gb D2) this time a 34w unit got the drive up and running, however, and this is the reason for this post, this lower power PSU failed a week later whilst waiting for a warranty replacement from Lacie (5 weeks and still waiting for the new PSU from them. they have no stock)
Message for all Lacie D2 users, check the power supplies first, test with another Lacie PSU, do not run the drive on a lower rating (34w) PSU it will fry it and leave you with another failed power supply.
If you are in a tight spot use the temporary power supply to move your data to another drive and get the correct 57w power supply before running the drive again.
Don't do as I did assume any Lacie power supply will run any Lacie hard drive, they won't, fortunately I had a second back up, but am 2 drives down and no new PSU's available to buy anywhere.
Try and purchase another spare 57w power supply, something all D2 users should do for long term security, as these do not seem to be very reliable and getting warranty support from Lacie on these is currently impossible.
The lack of 57w power supplies from Lacie and its distributors across the world is surely a warning to be noted!!!!!!
Buyers beware!
Aug 08, 2008 | LaCie External USB 2.0 500GB 7200 RPM 500...
My pc can't see the lacie hard drive
remove and return it again to the usb port? or maybe your enclosure has a problem?
Mar 11, 2008 | HP Pavilion dv6000z Notebook
Lacie 1TB external hd won't mount!
check wires connecting them together first, ok?
then, turn off the LaCie, connect to your MacPro, and then turn on the drive..
that should show as a mounted drive.
need printer drivers update?
Mar 09, 2008 | LaCie Big Disk Extreme with Triple...
Lacie 250 gb hard drive isn't recognized on computer
Controller got smoked when cable unplugged, take in if ya need the files off.
Nov 04, 2007 | LaCie (300728U) 250 GB Hard Drive
LaCie 320GB Lacie D2 HD Sata II 7200RPM 8MB Usa SATA II Hard Drive Logo
244 people viewed this question
Top LaCie Computers & Internet Experts
Raj Patel
Tony
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
