Question about Cameras
Manual for varta trio compact charger - Cameras
Wall charger replacemnt
Go to amazon.com and search "Trio Stealth G2 charger"
or, if you can't wait
check the OUTPUT voltage and amperage on the old charger (for example, it could say: "5.0 VDC --- 1000 mA" (that means 5 volts, 1000 milliAmp), and find a standard charger with same voltage, and same or higher amperage.
Dec 21, 2015 | Trio Stealth G2 7 inch Tablet with 8GB...
Trio Quad Core Tablet will not charge
Either the charger or the battery is faulty, from the sound of your fault description. If the tablet will turn on and run normally when the charger is plugged in, then the problem most likely lies with the battery. If it will not run even when the charger is on, then the charger is most likely the cause of the fault. If your tablet is still under warranty, either problem should be repaired free
Jan 01, 2015 | I-INC UniK Trio AXS 3G with Wifi 7.85"...
Where can I buy a charger for my trio stealth g2 tablet?
I was able to use my cell phone charger when my Trio Stealth Tablet charger stopped working. I would suggest first trying to use a basic cell phone charger before going out and spending lots of money on a charger "specifically" for a tablet.
Jul 11, 2014 | Mach Speed Trio Stealth G2 Tablet -...
Why my trio stealth g2 wont turn on
If it isn't charged it will not turn on.
Make sure the charger is working. Use an AC/USB charger.
Other than that it's broken.
Use the extended warranty you purchased when you bought the tablet.
May 03, 2014 | Mach Speed Trio Stealth G2 Tablet -...
Charge trio g2
Hi Jennifer,
Battery error or charger error.try with new charger or usb cable.
if you have warranty you have no problem and go for warranty.
regards.
nuwan
Jan 10, 2014 | Mach Speed Trio Tablets & eReaders
Trio Tablet
here is a link that explains and gives u some options
Apr 27, 2013 | Machspeed Trio DROID-7C Tablet
1 of my trio BT 1500 keeps beeping I have fitted new batteries
Try it in another charger as it sounds like it's not charging, solutions, clean battery terminals in phone, clean terminals on charger, swap chargers
Mar 28, 2013 | BT Hudson Plus 1500 Trio Dect Cordless...
How do I place 2 batteries in charger instead 0f 4?
Hello. Just place the two batteries together at the far left, or at the far right to charge them.. Just do not place them in the middle, or with an empty space between them. here is a link to the instruction sheet for your future reference http://data.energizer.com/PDFs/chdc_instructions_english.pdf
Nov 17, 2009 | Energizer NiMH Compact AA/AAA Battery...
BATTERY SPECS FOR A JEEP GRAND CHEROKEE 2.7 DIESEL WHAT IS THE CORRECT BATTERY SIZE
Exide 031SE Exide Excell Car Battery (EX22) £76.79 Numax 069 Numax Car Battery 12V 68AH £55.99 Exide 069SE Exide Excell Car Battery (EX69) £76.79 Optima Optima Red Top RT S 4.2
(8002-250)
(BCI 34) RTS4.2
£149.05 Varta Type 069 Varta Asia Car Battery 12V 70Ah
(Short Code: E24)
(Varta DIN: 570 138 057 or 570 413 063)
(8002-250)
(BCI 34) RTS4.2
(Short Code: E24)
(8002-250)
(BCI 34) RTS4.2
(Short Code: E24)
here are some batteries that will work . you can find equivilants to what ever your dealer carries .. :
exide 031se (EX22)
exide 069SE (EX69)
Numax 069 12 v 68AH
Optima RT S4.2 (8002-250) (BCI 34) RTS4.2
Varta type 069 12V 70AH (E24)
Oct 14, 2009 | 2003 Jeep Grand Cherokee
Cameras Logo
122 people viewed this question
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
