Question about Vehicle Parts & Accessories
How do I reset the check engine light on my 2009 Volkswagen Jetta
    Problem Solver:
  • 17 Answers
Find the OBD|| DLC (data link connector) and clear the code with a scan tool. Most auto zones or o Rielly auto parts will scan and clear codes for free. The connector is usually located under the dash on the drvers side. VW sometimes put them in center council below radio. VWs are usually a purple or green plug
Posted on Apr 19, 2013
2009 jetta brake like on dash is coming on and beeping
Could be a bad or misadjusted e-brake switch.
Mar 29, 2016 | 2009 Volkswagen Jetta 2.5
I have a 2003vw jetta the epc light is on and the will not come out of park nor the stop lights come on,I have already changed the brake switch and still won't work..
EPC light should have nothing to do with the shift interlock,(EPC is traction control) should be a small cap or plug on the console, near the shifter that has the interlock disengage button,usually done with a key,check shift interlock in the owners manual.
Oct 04, 2015 | Cars & Trucks
Why has my 2009 VW Jetta that lost all lights on the right side?
U WILL NEED TO REPLACE THE E-BOX!!THAT IS THE FUSE BOX LOCATED AT THE ENGINES COMPARTMENT!!
Apr 29, 2015 | 2009 Volkswagen Jetta 2.5
Horn not working in door opener in volkswagen jetta tdi 2009
pull apart and lightly clean push pad reassmy if still dont workreplace
Oct 25, 2012 | 2009 Volkswagen Jetta
I have a warning light that came on today, looks like an engine but is lit solid not flashing, I checked the fuel cap and it is fine, should I stop driving it?
Maybe. did you check the oil, coolant level. automatic transmission fluid? The check engine light will come when your vehicle needs a major service; such as, Now, this an example, OK. Like change coolant, change the automatic transmission fluid, or change differential fluid, or it just needed 3 month, 6 months, 12 months service check up at the dealship. It could tell you even to rotate the tires.
When the check engine light comes on. you vehicle needs some type of preventive maintenance done to this Volkswagen Jetta. You need to get it check out and have them reset the check engine light. GB...stewbison
Sep 09, 2011 | 2005 Volkswagen Jetta
2006 2.5 Jetta amber engine light is on...vehicle is running fine...suggestions? anyway of resetting this? Thanks
You have to use a engine fault code scanner to check for codes and reset the cars computer. The scan will tell you what is wrong and whether it is a serious problem that needs immediate attention.
Jan 20, 2011 | 2006 Volkswagen Jetta
Check engine light
the best way is with a scan tool
Apr 22, 2009 | 1998 Volkswagen Jetta
Dash lights on and clock resets. 2003 Jetta
To fix the clock and the odometer I just had to make sure there was a fuse in both places 11 and 15. I have a standard trans and one place I thought was for auto trans instrument panel lights. But both must be there. The engine check light also went off but the airbag light is still on. I was wanting to avoid going to the dealer, but I might have to so they can reset that.
Apr 10, 2009 | 2003 Volkswagen Jetta TDI
Vehicle Parts & Accessories Logo
120 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
