Question about DeLonghi DE500 Dehumidifier
DeLonghi Dehumidifier pump out failure
This model has a pump out feature which has ceased to work. Possible problems are dead pump, pump safety cut off (thermo switch), reservoir level switch to activate pump, or maybe even control circuitry. It appears this item wasn't meant for servicing, as it's not easy to gain access to the innards to probe around. What would you suggest is the most likely cause of failure and have you any thoughts on where to acquire repair parts?
I have the same problem. Very annoying. My suggestion is to go to your nearest dealer and throw the unit through their front window.
Posted on Aug 04, 2007
    New Friend:
My pump also stopped working, and the unit is a mere 2yrs old. I called DeLonghi and they told me to take it to the nearest DeLonghi repair center, which said it would be $120 out of my pocket to repair the pump. I might as well just buy a brand new unit (from a different company).
There are people all over the internet complaining about DeLonghi's pump, seems like it's a prevalent issue that requires a recall by the company. Any others experiencing a pump problem?
Posted on Jul 08, 2014
I fixed my humidity sensor... It wasn't broken.  It was wet.  Take off the panel holding the air filter, and open up the little plastic box (1"x1/2") mounted to the front of the radiator fins.  Mine had a drop of water inside of it.  I dabbed the water with a kleenex, let it dry all day, and re-assembled.  It works fine again.
Posted on Oct 20, 2007
I took mine apart, it had mold/algae in a one-way valve.  When I cleaned out the valve and reassembled, it started working again.  Now my humidity sensor is reading 90% all the time.  This thing is only 18 months old.  After reading this thread, I am also looking for my nearest dealer to throw the unit through their front door.
DeLonghi DD70PE Dehumidifier. Why does pump often stop working and F/P shows an error code until reset?
id be inclined to think that for some reason the pump is taking too long to pump tank out (or it thinks it is ) this would cause the fault you describe and the safety control shuts pump off for fear of a problem
Aug 18, 2015 | DeLonghi Dehumidifiers
My DeLonghi DD50PSC dehumidifies but the pump never comes on. Everything is ocnnected to the continuous draiining using the pump. Suggestions?
A blocked drain tube was the cause of the pump not working issue with this dehumidifier. I removed the back cover (5 screws on back, 1 screw on each side) and cleaned out the accumulated gunk in the small, clear reservoir on the back right. It took a little time using compressed air and pipe cleaners, but the effort ultimately worked.
Jun 14, 2012 | DeLonghi DE500P Dehumidifier
My DeLonghi dehumidifier will not collect water. I have cleaned the filter and have made sure there is plenty of space for ventillation.
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Jun 08, 2011 | DeLonghi Dehumidifiers
My DeLonghi dehumidifier model DE500P is tripping the breake
the motor is tight, (can't turn) lubricate the motor bearings with light machine oil. retest. rust causes this. the motor "tries" to turn, more power is needed, still can't turn, power exceeds safe limits: breaker trips.
Apr 25, 2010 | DeLonghi DE500P Dehumidifier
Delonghi de400p dehumidifier does not work
if comp and fans running your out of freon or the compressor is not pumping more than likely out of freon and that means theres a leak in the sealed system high cost repair
Jul 03, 2009 | DeLonghi DE400P Dehumidifier
Motor will not cut on
check the motor resistance, check the connection to the motor. Thermistor may be cut the connection.
Jun 14, 2009 | DeLonghi DE500 Dehumidifier
Error code E3 on delonghi dehumidifier DH400P
Be Safe or don't do it....
On the side with the lint screen, remove the five screws holding the top panel in place. The sensor that needs to be checked in mounted on the radiator fins. Remove the sensor and 4 pin connector. With a pin, remove the loose fitting housing the "sensor"...a circuit board that "shorts" with condensation...check corrosion and look for component damage on the oft chance the circuit board was damaged by some inappropriate poking or mechanical failure. Reassemble and replace sensor...
For a short life span...or out of warranty and only at your risk (IF have significant other or kids or pets or human DNA... don't do this...) .. guide wire through screen notch and attach to outer screen. Build fortress around exposed sensor and talk to insurance agent for a special rider...seriously be careful.
Did you? Clean screen and GENTLY clean fins of lint, etc....(vacuum's brush head should do the trick...)
Taking all appropriate safety precautions.
Here's the 100,000 (yen) tip....with humidifier unplugged, hold down the power button (green button in lower center) and plug in the appliance.
Watch the LCD screen as it conducts a self test...and wha...lah!.
Should have a working humidifier!
(your welcome).
no really..."de nada". :"don't touch your moustache" "Doye toche moche"(?), "prego".
Apr 10, 2009 | DeLonghi DH40P Dehumidifier
DH400P
I had a similar problem with the pump not working and the water flowing into the main drainage bucket instead. I had to disassemble the housing...not an easy project to reassemble...and found that the pump has its own smaller drainage tank with a float device, a pump pre-filter, the actual pump, then of course, more drainage tubes. The entire pump drainage system of components needed cleaned of accumulated, mucoid, slime! I cleaned the channel in which water flows into the pump's tank...located on the screen filter side of the dehumidifier. Then I moved to the other side of the dehumidifier and cleaned-out the entire pump drainage tank. Note that the pump's drainage tank only empties about 1/2 inch of water each time the pump activates. Thus, there is always alot of water in the pump's drainage tank. Thus, alot of time for slime to accumulate. Next, I cleaned off the float mechanism. I then cleaned-out the pump's pre-filter. Cleaning out the pump's pre-filter was paramount to the pump functioning properly and quietly! I checked that my pump was properly installed and NOT rubbing against its mounting so that it operated quietly. I added fresh water to the pump's tank several times to insure that the pump was working properly and that all slime was eliminated. Finally, I reassembled the housing...not an easy task! My pump now functions like new. All this work had to be done to insure proper function of the dehumidifier's pump system. My dehumidifier is only 11 months old. It is still covered by the one year warranty, but it is too expensive to ship the entire unit, as Delonghi requires you to do at your expense for them to fix it under warranty. You can be assured that I will check for future slime build-up to keep my dehumidifier functioning properly. The dehumidifier works great, it's just that it's high maintenance.
Jun 15, 2008 | DeLonghi DE400P Dehumidifier
Frost, ice on coils DeLonghi DDE50E Dehumidifier
expected? of course! this is not ur solution try draining all the water to the sewerage if u cant try to pump it out with a vacuum cleaner (that can pump water) or a pump then turn on the Dehumidifier every time it frosts turn it off untill it defrosts or u can heat up the basement with a bellower and the Dehumidifier wont frost
Feb 05, 2006 | DeLonghi DDE50E Dehumidifier
DeLonghi DE500 Dehumidifier Logo
1,309 people viewed this question
Top DeLonghi Dehumidifiers Experts
dennis lewis
Level 1 Expert
Are you a DeLonghi Dehumidifier Expert? Answer questions, earn points and help others
