Question about Gateway Profile 3 PC Desktop
I have a gateway profile 3 the cpu fan wont come on it gives warning fan absent or broken and wont to go no farther.
  • 1 more comment
  • ernie30_99 Mar 11, 2009
    thanks for your reply. i pluged in another fan same type still nothing , plus the exhuast fan isnt working ether,i have pluged both fans cpu and exhuast into other motherboard they work any ideas thanks ernie still get warning cpu fan absent or broken
    Scholar:
  • 54 Answers
First make sure that the CPU fan is properly connected to the motherboard. There is a connector on the motherboard that is usually labeled CPU_FAN.
If the fan is properly connected, but isn't working, a replacement can be purchased for a reasonable price. Check with Gateway or your local computer supply shop and they will be able to help you find the right fan assembly for your CPU.
Hope this helps. Please take a moment to rate this solution. Thanks.
Posted on Mar 11, 2009
  • RSBennett
    RSBennett Mar 13, 2009
    Check to make sure that all of your power connectors from the power supply are properly connected to your motherboard. On most newer motherboards, there is a 20-pin connector that supplies power to the MB, and an additional 4-pin connector.
    If all of your power connections are secure, and your fan is working properly when connected to a different motherboard, then it is safe to say that the motherboard itself is faulty and needs to be replaced.
My gateway i-3 nv79 runing w7sp1 has a bad habit of shutting off with no warning ... downloaded coretemp and it seems like it is is overheating for no reason ... i can just be reading e-mail and it wi
Overheating When the CPU overheats then it will shut down (i.e. thermal overload) and won't boot up again until it has cooled down. If this is the problem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are clogged with dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make sure the vents are clear and dust free. Use a small brush and can of compressed air to do this.
Dec 24, 2012 | Gateway Computers & Internet
Gateway m255 laptop cpu fan wont let me boot up
open your laptop up and make sure the fan cabels are in correctly if not push them in if that dosen't work get a new fan for it
Jun 15, 2012 | Gateway M255-E Notebook
Magnets broke my computer
probably did a number on the memory or the cpu or even drive time to replace some parts
go to www.gateway.com and enter model number then look for memory and cpu sales options.
good luck and keep that pc away from magnets next time
Jun 13, 2012 | Gateway Profile 3 PC Desktop
Gateway ML6732 Laptop Fan warning
I would replace the fan right of the bat, it has a high failure rate, also remove the heatsink to check the thermal grease is not hard, if it is, remove with rubbing alcohol and paper towel along with the processor, then apply fresh compound to both and assemble.
May 19, 2012 | Gateway M Computers & Internet
When i open my pc this message displayed and the computer stop the cpu fan is absent or broken
The CPU fan has obviously failed. You should be able to source a replacement from a good computer shop. Worth trying a warranty replacement from Gateway though.
Jun 12, 2010 | Gateway Profile 3 PC Desktop
Gateway profile 3 has power but wont turn on
Make sure that the IO cable is properly connected. To make sure disconnect the cable and reconnect it again.
Jan 13, 2010 | Gateway Profile 3 PC Desktop
Ijust replaced the cpu fan and now the computer won't boot - it just flashes the gateway logo
make sure that the power reqs for the fan are the same as one you replaced and make sure that the new fan is the same prong (3 or 4). Also make absolutely sure you plugged the new fan power supply inti the CPU fan slot
Apr 15, 2009 | Computers & Internet
Gateway Profile 3se cooling fans don't start every time.
The Internal Fan On the cpu is always on correct? If so the external fans come on when the tower case has a temp higher than 85F. This is perfectly normal
Apr 03, 2009 | Gateway Profile 3 PC Desktop
My computer wont go to windows xp when started up and it doesnt even go to any type start up screen
hi gllwymiller;
1.check all your connections
2.check monitor and cpu power
3.when you power on your cpu, do you actually hear the fan turning or see your power led light up?
4. what OS are you using?
5. Feel the rear fan or your CPU, is it blowing out air?
get back to me :)
Jul 01, 2008 | Gateway Computers & Internet
Monitor keeps shutting off
it is a "CPU THERMAL SHUTDOWN"
Make sure the CPU fan is working. If there are any other fans on the motherboard, make sure they are working.
Make sure the case fan(s) are working and that there is no obstruction to the airflow into and out of the case.
Your CPU fan may be broken and you will need to buy another one.
Was this solution helpful? Show your Appreciation by rating it:
Feb 10, 2008 | Gateway FPD2275W LCD Monitor
Open Questions:
Toshiba Laptop doesn't start up. Black screen [Solved] -Dataalign Toshiba as a brand has continued living up to the expectations of its customer for nearly three decades now, by maintaining the high quality of its products with the help of delivering a combination of useful software and attractive hardware in a package, which is required for providing the needed technological expertise. With laptops becoming an indispensable and integral parts of our lives, it is important that companies today equip their laptops with all the advanced technologies along with a sleek and stylish design for that attractive feature that would add to its plus point. Our Toshiba technical support team members are available all the time on our Toshiba Support number +1 888 784-9316 and are highly adequate in resolving issues related to Toshiba printers. The fact that everyone today knows about Toshiba Support brand and most people who have tried Toshiba products like them, makes them one of the most reliable in case of printers especially. Toshiba makes business portable laptops, with highly durable features of being sturdy and long- lasting for use in all walks of life. Most laptop owners would agree to the fact that Toshiba products are designed to provide quality portable solutions and highly acclaimed for their bullet-proof build value. But with time, users might face issues with Toshiba Customer Care like any other laptop band and these issues can be prevented from causing any severe damage to the laptop by accessing resolution from our technically specialized team members, who are available on our +1 888 784-9316. Issues faced by Toshiba customers: Toshiba Backup BIOS update issues Slow Performance Office and outlook setup Wifi and Internet Issues Audio & Video Issues Startup and Boot problems Windows updates Windows 10 upgrade issues Computer Tune-up Issues Virus Removal Issues Data Backup, Transfer and retention issues All these issues and many more, concerning Toshiba users are directly and efficiently resolved by our technically knowledgeable team who can be Reached 24/7 on our Toshiba Contact- +1 888 784-9316.
Jun 23, 2018 | Toshiba Computers & Internet
See all Gateway Profile 3 PC Desktop Questions
Gateway Profile 3 PC Desktop Logo
206 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
