Question about Microwave Ovens
MY intellocook LG microwave is new, have used it only for a week. it makes sounds like furniture is being moved when m cooking..what to do?
I am using the microwave only twice a day that too for 15 mins each time. It makes a lot of noise, and the noise has increased over two days. I am scared it will blast..!!! please help
  • 43 Answers
SOURCE: Vibrating noise when cooking
In order to try to set your mind at ease I will have to explain the Basics on how a Microwave Oven Functions.
When a Microwave Oven is set to COOK ...START. It cooks at 100%. There is no lowering of the heat as with a Range ( Cook Top) Control. So in order to do the other things such as DEFROST, WARM, or anything other than 100% COOK. A COOK ON- COOK OFF system was utilized. To DEFROST, the Microve COOKS at 100% for 30% of the TIME, then IDLES for 70% of the TIME. COOK ON 30% of the TIME, COOK OFF 70% of the TIME = DEFROST This is why you can hear the CYCLE. More power is required during the ON CYCLE, thus the lower vibration. The Vibration occurs when the High Voltage Transformer is turned ON ( COOK ON).
The VIBRATION seems to have got louder with age. This is somewhat normal as there is a vibration from the High Voltage Transformer present every time the Microwave is used. screws and other metal parts seem to get loose with this vibration. There is no solution, unless you can tighten EVERY screw, nut, and bolt in the unit.
Sorry!
Posted on Feb 03, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: Setting time on Panasonic NN-CD748B microwave
Panasonic's UK site is here and you can choose Support, then search for spares, servicers, downloads and contact info.
Posted on Jan 09, 2009
MicrowaveSvc
  • 9047 Answers
SOURCE: Frigidaire microwave making noise and blue sparks
Quite often this is due to grease or food particles stuck somewhere in the cavity of the oven or stuck on or behind the waveguide cover.
They are often held in place by a plastic rivet.
It can be fragile, and the metal edges of the oven behind it can be sharp, so be careful!
The cover and the metal behind it should be cleaned with a mild, non-ammonia cleaner.
If the cavity metal of the oven is chipped or charred, it will have to be sanded smooth and clean and dried thoroughly.
Then you can apply some high-temperature appliance paint, available from places like Wal-Mart, Lowe's or Builder's Square.
If your waveguide cover is burned, it will need to be replaced. It provides important protection for the magnetron.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Posted on Jun 02, 2009
SOURCE: Microwave turned on but nothing inside to cook, so now it's dead!
Put him up for adoption before he burns down your house.
Posted on Jan 29, 2010
SOURCE: GE Profile XL 1800 Microwave overheating?
ge spacemaker XL1800 (JVM 1870BF02) doesn't heat, lights, turntable works.
Posted on Mar 08, 2011
Glass tray turntable makes noises when heating food
Hi, the rollers on the support mechanism has residue, try cleaning the rollers and the track it follows, should resolve the sound problem
Jan 05, 2015 | LG LMH2016ST 2.0 cu. ft. Over-the-Range...
Microwave stays on after the cooking time. Motor keeps running and product continues to cook unless you open the door or unplug
sounds like your timer switch is faulty what make and model is it
if its a cheap make and model bin it and buy a new one
this is potentially dangerous and could go on fire (DO NOT USE FAULTY ELECTRICAL EQUIPMENT )
Jul 30, 2013 | GE JVM1790 Convection / Microwave Oven
My microwave/convection oven will not heat up, but the lights and clock work
Hello
Look to see if the microwave power cord is securely plugged into a live power outlet. The power cord cannot be loose for proper function. Move other appliances to a separate outlet if possible.
Replace or reset the circuit breaker or fuse if blown or tripped.
Unplug the microwave and wait several seconds before plugging it back in to reset.
Make sure there are no current functions in use. Press "Clear/Off" to cancel any other settings or programs already in progress.
Select a new cooking program and then select "Cook Time." Make a time selection and press the "Start/Pause" pad to begin cooking.
Oct 04, 2011 | Microwave Ovens
My LG over the range microwave makes a rattling noise when I am cooking. The sound is not there is the item I am microwaving is heavy.
This may sound a bit nuts, but remove the glass tray and support ring. Clean the wheels and ring. Also clean the glass and microwave surface where the wheels run. Any tiny bit of debris will stop the wheels from turning, and make a rattling noise.
If that doesn't help, you may need a new turntable motor.
Feb 26, 2011 | LG Over-the-Range Microwave
MC-767W-WS LG intellocook microwave oven showing E-10 message only. What does represent and what is to be done. Amitabha Pal
microwave oven MC767W LG has not working it stop automatically after few min. showing 10.1 error
Sep 14, 2010 | Microwave Ovens
Loss of all power when trying to cook/defrost
The cost of repairing the micro wave will out cost the replacement value. If its new then use gaurrantee for replacement
Sep 03, 2009 | Microwave Ovens
LMVM1935SB - Over the Range LG - fan keeps coming on, beeping
The fan will come on if you are cooking below and the area gets hot.... is this when it happens? Sometimes random beep could be a power blip... not long enough for a reset of all things electrical
Apr 19, 2009 | LG LMVM1935 Convection/Microwave Oven
MMV1153BA brand new, less than 2 weeks
The magnatron may need replaced..(this is what makes it cook)
Dec 10, 2008 | Maytag MMV1153A Microwave Oven
Microwave not cooking
I would say you have a bad door switch or door switch mount, or your door is loose or out of alignment.
But since it's new, and under warranty, I would contact Goldstar (LG) customer service to have them repair it free.
Contact LG at 1-800-243-0000 or http://us.lgservice.com
We're happy to help and we appreciate your thoughtful rating of our answer.
Feb 28, 2008 | Microwave Ovens
Oven turns on by itself when boiling water on stove!
Sounds like a mis-aligined, or defective door switch. I would suspect defective.
Jan 22, 2008 | LG LMV1650ST Microwave Oven
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
