Question about HP Pavilion dv6000t Notebook
Dead batter covered by maxassurance?
I have an HP notebook and when I first bought it I purchased maxassurance with it, so if my batter is totally dead will it be replaced by office max?
  • HP Master
  • 4,806 Answers
Hi there.
Yes it is covered because its hardware, software however is not covered. If the machine is still under a year old then it is covered by the manufacturers warranty. Check your policy or phone them up as i'm 99% sure that insurance covers all hardware so they will replace the battery for free.
Good luck and thanks for using FixYa!!
Posted on Mar 11, 2009
I have hp 6910p with broken lcd so i disassampled the lcd then i connected external monitor then turned on the laptop power led is on and red speaker light is on but laptop is not working there is only...
broken as in cracked, or just dead, define the word broken please..
eternal VGA monitor use that set of words to be clear.
the HP command Fn+F4 must be used to turn on the VGA jack
(internal,external,both , auto) 4 choices on mine.
lost the manual>? those key strokes are covered there and more.
if the Latop PC is dead, and FnF4 fails on any External monitor (
no text at all means dead.)
then next remove the silly old large battery first, this is always first.
not new LCD panel.
then new coin cell, RTC coin cell, dead, makes BIOS go nuts.
and screens too.
what is next turn it on, does the fan blow air. or dead silient it must
or there is no power. the CD tray is dead?
try a new AC power pack? now. at this point in the process
keep that nasty huge battery out until the PC run good again.
win
there are more test, if you had said the fan is dead,
bios dead, and the coin cell new. answer be totally different.
it be power diagnosis time
Jan 16, 2018 | HP Compaq 6910p Notebook PC PC Notebook
If my battery for my HP laptop is dead, should the computer still operate with the AC adapter?
yes, it will operate with the AC adapter . But I suggest you consult HP for a battery replacement. If you bought this below 1 year of purchase, I believe you are entitled for a 1 year warranty. But just the same, it will turn on the laptop with the AC adapter connected.
Aug 30, 2010 | HP Pavilion dv6000z Notebook
I bought a new batter for my hp dv1000 ,but i can not get it to charge. it say that it is charging but stay on 0% what am i doing wrong? someone said that i need to change the bin.
I had a problem with my power supply that broke wires at the connector for the box. They tend to kink their or at the computer and fray inside the rubber. I had also purchased a new battery.
May 27, 2010 | HP Pavilion dv1000 Notebook
My v2000 will not come on at all? I have it plugged in with the adapter and it's like there is no power to it at all?
check power supply adaptor and batteries if they are supplying enough power, if you can borrow a power adaptor and spare battery try replacing them with one your notebook has.
if it works then your adaptor and batter are out, normaly if the adaptor stops working the battery would have died down too as you would have not noted till the notebook totally died down.
Dec 07, 2009 | HP Compaq Presario V2000 Notebook
Bought new power cord for pavillon dv 1000 and
If the laptop runs on batter but cannot run on the AC adapter, you have a broken DC Jack. If you laptop cannot power up with the battery or flash low battery indicator, you laptop is dead.
Oct 30, 2009 | HP Pavilion dv1000 Notebook
I removed my battery and guess my cmos battery was dead now i just get center light when plugged into ac, can not get anything to power up
cmos battery being dead will not cause this issue. you can actually remove the cmos batter and power the unit on fine. your issue sounds like it more motherboard related. check this link to see if you qualify. others have qualified for this motherboard replacement. i have sent many laptops in for no power/no video/no boot issues
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01087277&lc=en&cc=us
good luck!
Ruben
Jul 19, 2009 | HP Pavilion dv6000z Notebook
Cracked HP laptop LCD
under warranty if it is a defect from manufacture or if you bought extended warranty from retailer, some policy's cover damage. Only covered if policy is still within time of purchase.
If it is not covered it will be cheaper to replace computer than repair.
You can search here for warranty from manufacture.
http://welcome.hp.com/country/us/en/support.html
Hope your covered. Please rate if this fixed you. Good luck!
Mar 09, 2009 | HP Pavilion dv6000z Notebook
Ram upgrade = computer will not load
First check out the RAM you had prior. If it is DDR or DDR2 then it needs to match exactly. If you go to the HP website and type in your model number they can tell you what RAM is compatible. If it matches what you bought and its not working then the RAM is bad and needs to be sent back.
Please rate this solution and thanks for using FixYa.
Jan 06, 2009 | Compaq Presario R3000 Notebook
Notebook is not powering up
You have a fairly common failure of teh power plug on the motherboard. You can get a replacement for less than $100and have it installed locally for about the same price if you are not comfortable doing it yourself.
Motherboards are available here:
http://search.ebay.com/search/search.dll?from=R40&_trksid=m37&satitle=evo+n610c+motherboard&category0=
Aug 04, 2008 | HP Compaq Evo n610c Notebook
EVO n600C NOTEBOOK battery not charging.
1. Check the socket u pluged it in
2. have the charger tested for continuity.
Mar 14, 2008 | HP Compaq Evo Notebook N600c
HP Pavilion dv6000t Notebook Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
