Question about Clarion NAX970HD Navigation System GPS Receiver
Clarion nav system frozen. where is the reset button
CD cracked in half completely! Where can I purchase another?
contact clarion direct on the web and make enquiries of the customer relations people
Dec 25, 2013 | Cars & Trucks
Clarion NZ500 nothing on screen
Clarion ebrake safety bypass without using toggle switch
Clarion has a brake safety wire that has to switch from open to a ground every time you turn on the unit so therefore you cannot just ground the brake wire it has to switch to ground every time you turn on the radio
Aug 22, 2017 | Clarion NZ500 Car Video Player
I got a clarion nx 602, I install it everthing works eccept the navigation system. Say failed to start at first time.
I have the same issue. Started a few weeks ago by locking up the unit while using the nav. Then the nav app will not load at all. Any luck on getting a resolution?
Dec 16, 2012 | Clarion NX602 6.2in DOUBLE-DIN NAVIGATIO
My nook color has frozen screen and won't shut completely down
TRY a hard reset on the Nook if that doesn't work i know of this fantastic site BNTPrice.com that sells them for cheap. i hope this works for you
  1. Press the "n" button to display the quick nav bar.
  2. In the quick nav bar, tap the Settings icon.
  3. In the Device Settings section, tap Device Info.
  4. Tap Erase & Deregister Device.
  5. Stop. Think. Think again.
  6. If you really, really want to do this, go to Step 7. If not, tap the Back button.
  7. Tap the Erase & Deregister Device button.
May 24, 2012 | Barnes & Noble Nook Tablet
Sat nav won't reset. have tried the re-set button. Screen has frozen
If the reset button of your device is not resetting the device and it is still on the frozen screen. Just turn to the back of the device, unlock the battery from the device and remove it. Then you allow the device rest for about 5 minutes then you fix it back in. Plug the device for about 2 hours and power it on. It should work fine after this. Be sure not to turn on too many applications on the device at the same time time, because that could result in the device being frozen again.
You can as well update the software of the device by charging it for about 2 hours, then you connect it to the computer that has its software. That will show if there are recent updates for the device, then you update the software with the latest version. that should take a little while to update. Then install your maps on it, safely disconnect the device from the computer and turn it on. That can also help you solve the problem.
Hope this was helpful. Thank you for using fixya.
Jan 26, 2011 | SNK RAC SAT NAV 200 GPS Receiver
Hybrid navigation/tv package nva9400f
I might be able to help you with this. The Addzest Navigation system you have is similar to the Clarion NAX9500E. I have some bits off an Addzest NVA9400F and I bought a second-hand Clarion NAX9500E sat nav system. I have pdf's of the Clarion system that would enable you to get yours running.
I was able to get my Addzest system running but it is all in Japanese and I don't think you can change the language unless you know more than me. I hit the reset button but still in Japanes.
That's why I got the Clarion system instead and salvaged some of the Addzest leads.
My email is dazliggett@yahoo.co.uk if you want me to email you the user and wiring intructions for the similar Clarion Navigation unit.
It is a pitty that I wasn't able to use the Addzest navigation system but hopefully I can still use the
7" monitor.
If you still have the Addzest equipment I was wondering if you would sell me the lead that connects the 7" monitor to the Navigation sytems as I wanted to use that it as a rear monitor.
Hope to hear from you on what you decide as I haven't had much luck finding a lead for my monitor as the Clarion one is the same size but different pin configeration
thanks
Darren Liggett
Apr 05, 2009 | Clarion Car Audio & Video
Buttons and screen not responding on via michelin x-950t sat nav
stick a pin in the reset hole in the back.that should fix the problem.
Mar 01, 2009 | SNK ViaMichelin Handheld GPS Receiver
Peugeot 406 factory fitted sat nav
If you have the factory fitted nav then this is an integrated system and you will need to get the clarion repaired. If you give me a call I can advise you how to arrange to have the unit repaired 0161 428 2020
Dec 18, 2007 | Car Audio & Video
Clarion NAX970HD Navigation System GPS Receiver Logo
Top Clarion GPS Experts
CheckitRight
CheckitRight
perdue40
Are you a Clarion GPS Expert? Answer questions, earn points and help others
