Question about Xerox Phaser 8550DX Laser Printer
Fault message comes up after the printer is powered on
An error message comes up and says the following;
Fault
37,008.44:3232
www.xerox.com/office/8500_8550support
I tried to plug it into an alternative power source and that didnt work, can you help?
    President:
  • 2,072 Answers
That is a print head fault. Most likely the print head itself has failed.
Posted on Mar 11, 2009
Hi!Can you help me resolving error code 092-315 for xerox7225?
Can you verify the error code? 092-315 does not appear in the error code site. See link below
How To Search for a Fault Code WC7220 / WC7225 Fault Code Page
To search on a fault code, enter one code at a time. The codes will be displayed on the Touch Screen.
Fault code format: A 3-digit number, followed by a 3-digit number. For example, 010-352.
Viewing Fault and Alert Messages on the Control Panel
When a fault or alert condition occurs, a message will be displayed on the Control Panel to inform you of the problem. Alert messages inform you about printer conditions, such as low supplies or open doors, that require your attention. Fault messages warn you about printer conditions that prevent the printer from printing or degrade printing performance. If more than one condition occurs, only one displays on the Control Panel.
To view a complete list of active fault and alert messages:
  1. Press the [Machine Status] button on the Control Panel.
  2. Select the [Active Messages] tab.
  3. Use the Down arrow and select [Faults], [Alerts], or [Faults & Alerts].
  4. To view details, select a fault or alert.
Viewing the Fault History on the Control Panel
When faults occur, they are logged in to a fault history file by date, time, and fault code. Use this list to identify trends and resolve problems.
To view the fault history:
  3. Select [Fault History]. The screen displays the number, date, time, and image count for each fault code.
The following table represents the system area as represented by the first 3-digits of the fault code:
Chain Description 303 Communications Error 305 Duplex Automatic Document Feeder (DADF) 310 Fusing 312, 313 Finisher 371 - 375 Paper Tray Feed 377 Sensor / Interlock Fault 391 Drum Cartridge / Waste Toner
http://www.support.xerox.com/support/workcentre-7220-7225/support/enus.html
Mar 07, 2016 | Xerox Office Equipment & Supplies
Scanner error 02
Go To Below official Epson Printer Page For Your problem, Product Status Messages Hope It's resolve all Your Printer Problem,
Or Still having Problem Then follow Us For
Epson Printer Support
Apr 13, 2014 | Epson Office Equipment & Supplies
U 60
U60: Job Offset Home Position error. Job Offset does not reach home position.
  1. Cycle the printer's power.
  2. If the problem persists follow the procedure below.
Check the following for evidence of fault or damage: Home Position Sensor Adjuster. Home Position Sensor. SNS Harness: is there any damage or misalignment? The rest of my steps can only be done in Technician's Service Mode and should only be done if you are qualified to service this machine.
Mar 29, 2014 | Xerox Phaser 7400/N Printer
Hi all, here is my problem with the Xerox
If the finisher is louder than usual, the rails on the eject assembly need to be cleaned and greased.
Sep 16, 2013 | Canon PIXMA MP130 All-In-One InkJet...
When I try to scan or print a message comes up telling me to ck power and usb connections. I have unplugged and restarted computer 4 times and still have problem
It could be a communications error message, the printer is not communicating with the computer.
  • Disconnect and then reconnect the USB cable.
  • Disconnect and then reconnect the printer power cable.
  • Restart the computer.
  • Remove and reinstall the printer software
  • If your printer does not function properly or communication error messages appear when using your printer, you can remove and reinstall the printer software.
    1. Click Start®Programs or All Programs®Dell Printers®Dell Photo AIO Printer 962®Uninstall Dell Photo AIO Printer 962.
    2. Follow the instructions on the computer screen to remove the printer software.
    3. Restart your computer before installing the software again.
    4. Insert the Drivers and Utilities CD, and then follow the instructions on the computer screen to install the software.
    If the installation screen does not appear:
      1. In Windows XP, click Start®My Computer.
    In Windows 2000, double-click My Computer from your desktop.
      1. Double-click the CD-ROM drive icon. If necessary, double-click setup.exe.
      2. When the printer software installation screen appears, click Install or Install Now.
      3. Follow the instructions on your screen to complete the installation.
    Communications error message
    The printer is not communicating with the computer.
    Dec 06, 2010 | Dell 962 Photo All-In-One InkJet Printer
    SCANNER ERROR
    Message comes with Printer Scanner Error 6
    Turn Off Then on
    Jul 21, 2010 | HP LaserJet 3055 All-In-One Printer
    Hi In our office Konica Minolta C250 ,it show message mulfunction. error:- c0206
    C-0206 relates to tray 3.
    With the copier turned on do the following
    Open paper tray 3, remove paper, close tray, open then shut front door, load paper into tray 3 - hey presto!!
    If the fault comes back you could have paper stuck behind the tray or have a defective lift up motor.
    Regards
    Taminol
    May 13, 2009 | Konica Minolta bizhub C250 All-In-One...
    Error 1201 Lexmark x4250
    The definition corresponding to this error message is this: "The print carrier stopped before all of the data was used."
    To resolve this issue, please do the following:
    1. Power the printer off.
    2. Remove all cables from the back of the printer.
    3. Reinsert the power cord.
    4. Switch the printer back on.
    5. Check the operator panel to see if the 1201 error message is displayed.
    6. If the error message returns, the printer could be defective. Contact Lexmark Customer Support for further troubleshooting and warranty options.
    Thank you
    Nov 03, 2008 | Lexmark X4250 All-In-One InkJet Printer
    5500
    This error message indicates that a problem occurred with the scanner. To resolve this error condition, do the following:
    1. Turn off the printer, then disconnect the power cord.
    2. Wait 30 seconds, then connect the power cord.
    3. Turn on the printer.
    May 13, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
    Error Message: 0xc18a101
    The Ox error you are describing is an issue being seen in quite a few hp printers. The only known fix is to try is while the printer is turned on unplug from power source. Unplug the power cord from the back of the unit as well and hold the power button down for 5 seconds to drain any remaining power the printer may be hanging on to. Wait another 30 seconds and plug the cord into the unit first and then directly into the wall - not a surge protector or power strip.
    After you have plugged it back in if the error message comes back up then it is a fatal error within the printer. Call hp and see if they have any upgrade units available - usually refurbished but they come with a 1 yr warranty and are significantly cheaper than buying a new unit from the store. They will also take your unit and pay to have it returned to go to an environmental recycling facility.
    Feb 20, 2008 | HP Photosmart C6180 All-In-One InkJet...
    Xerox Phaser  8550DX Laser Printer Logo
    125 people viewed this question
    Top Xerox Office Equipment & Supplies Experts
    Michel
    Xeroxrep
    Level 1 Expert
    Philip Hughes
    Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
