Question about Swingline Cartridge Electric Stapler - 69001
How to fix a staple jam
Staples jammed
3 Suggested Answers
SOURCE: We have a Swingline 690
I had the same problem with my 690. This is what worked for me.. I simply pulled out the staples from the cartridge a little further than the suggested tear-off point, and the machine was able to start working. Hope this helps!
Posted on May 10, 2011
caroldon
  • 17130 Answers
SOURCE: how do I remove a jammed staple?
All you need is to use a thin sharp wire rod to push the damaged/cramped pin out of the hammer. You can achieve this only if you can have such a tool , remove the lid to get access, manually turn aside to relieve the presssure on the damaged pin, remove the cartidge and replace after the pin is removed. You can also slightly tap to get the pin released from the jammed position.
Posted on Oct 25, 2011
How do you fix staple jam?
You may have to open up the stapler to expose the loading area then look for staples (or staple fragments) jamming the nose. It may be necessary to resort to pliers to remove the bits.
Aug 09, 2014 | Bates Power Arm Extra Heavy Duty Stapler...
Bostitch b8e
There could be a piece of a broken staple jammed in the stapling mechanism. I checked mine and there are two screws on the bottom that can be removed to expose the interior. The broken staple jam occurs often with mechanical staplers so the electrics probably have similar failures.
May 29, 2014 | Office Equipment & Supplies
Staple is jammed
Open the area where more staples are inserted, remove the staples, then find the jammed staple. You'll probably have to wrench it out with pliers. Then insert the good staples and try again.
Dec 28, 2013 | Tools & Hardware - Others
Someone loaded regular staples into our Swingline 45 Optima now it will not work when loaded with the correct staples.
Using the wrong or style ofstaples, overfilling the machine and stapling through too-thick materials can causeOptima to jam. Now follow these steps: 1. Holdthe base down as you lift the top of the Optima stapler to access the stapletray. 2. Removeall the staples from the tray so that you have access to the jammed staple. 3. Turnthe stapler upside down and shake it to clear out staples you can't reach withyour fingers. 4. Gripthe jammed staple with the needle-nose pliers and, while holding the staplersecurely, pull it up. 5. Twistthe staple until it breaks into two pieces if it will not pull straight out.Pull out the two individual pieces. The Optima stapler line bySwingline is designed to be jam-free when Optima premium jam-free staples areused. Using another , style or brand may cause frequent jamming. Hope thiswill help you. Good Luck.
Jul 21, 2011 | Office Equipment & Supplies
A staple jammed in the moving part (driver?) when using to staple. How do I clear the jam?
first remove the the spring loaded rod that keeps the staples in place and tight, if you can see any part of the jammed staple , grab it with pliers or vice grips and pull it out any way you can , might be more than one staple jammed too, turn stapler upside down to dump out any loose staples and debris , keep working until she frees up , if you still cant get it out might have to loosen screws up that hold it together, a little light lubricant will be good for it too . then load it back up with staples and put tension rod back in, i always try to keep it full of staples at all times ,like when it gets 2/3 empty , fill it up, this will ensure good tension on the business end of the staples!!
Feb 05, 2011 | Heavy Duty Arrow Ht30 Light Wire Hammer...
I HAVE A SWINGLINE STAPLER AND IT JUST STOPED WORKING CAN YOU HELP ME TO FIX IT THANKS
When a stapler stops working it is because it has jammed.Try to open it by pulling on the silver bottom part while holding the top black part there is a release on the bottom.Press the release at the back and unload staples.You should see jammed staple in feed,clear it them.Reload with new **** of staples.It should now function.Use a pin or paper clip to clear pull out jammed staples.
Jan 04, 2011 | Office Equipment & Supplies
My etfx50 arrow staple gun jams, what can I do to fix this problem?
There is a screw and nut at the feeding end of the gun that allows you to remove the guide and get to the jam. Make sure it is unplugged and prepare for the firing mechanism to eject the jammed staple. Otherwise, a pretty simple maneuver. Wish Arrow would have included such in their owner's manual.
Nov 30, 2010 | Aerobie Arrow Etfx50 Staple Nail Gun
My arrow staple gun jams every few staples even thought it has a ''jam proof mech''
no sutch thing as jam proof hehe.
just squirt some oil in the gun and you should be good to go.
Nov 10, 2009 | Arrow T50P ARROW STAPLE GUN
How to repair jammed arrow electo matic staple gun
You'll have to disassemble it. There is probably a staple lodged in the "hammer" mechanism on the business end of the stapler.
Often, these staple are very difficult to remove -- a very small flat-tip screwdriver and needle-nose pliers usually work best.
After you get all the jammed staples out, lubricate all moving parts with something akin to 3-IN-1 machine oil. This should prevent future jams.
Charlie
Aug 20, 2009 | Heavy Duty 648967 Arrow Electric Staple...
How to remove jammed staples in staple gun?
Take out the small bolt that is secured with a nut at the back of the gun (at the end where you feed the staples) -- then drop the inset. Now you have access to the jammed area. Clear out jammed staples and put the stapler back together. Easiest way is to hold the nut and turn the bolt from the other side.
Jun 16, 2009 | Arrow T50P ARROW STAPLE GUN
Swingline Cartridge Electric Stapler - 69001 Logo
42 people viewed this question
Top Swingline Office Equipment & Supplies Experts
Paul Bade
Stitch85
Level 1 Expert
Are you a Swingline Office Equipment and Supply Expert? Answer questions, earn points and help others
