Question about Faultless Naples Polished Brass Lever Privacy LYE701B-F
Faultless door handle won't open
Door won't open
Driver side door won't open from outside
Remove door up hosting & check lock link could be removed from the out side handle.
Feb 22, 2013 | 2006 Scion tC
Door latch
see this causes and fix it. God bless you
Open Lever If the microwave door won't open the open lever might be broken. This part can be replaced separately.
Door Spring If the microwave door won't open the door spring may have broken. The door spring is located inside the door and keeps downward pressure on the door hook.
Door Latch If the microwave door won't open the door latch might be broken. The door latch is inside the microwave. The door hook, which is part of the door, engages with the latch to keep the door closed during operation. If the door latch or actuator breaks the door may not open.
Door Hook If the microwave door won't open the door hook might not be releasing properly. The door hook is installed inside the door and normally releases when the door is opened. The hook is made of plastic and will break over time. When this happens it will need to be replaced, it can't be repaired.
Button Spring If the microwave door won't open the button spring might be broken internally. The button spring can be replaced.
Button If the microwave door won't open the button might be broken internally. The button can be replaced.
Handle Actuator If the microwave door won't open the handle actuator might be broken. This is a plastic part which can become brittle over time. This part is connected between the door button and the door latch assembly.
Oct 15, 2012 | Samsung SMH9187 Microwave Oven
Help inside door handle for toyota corolla won't open
you need remove the door panel maybe you have only a loose pull wire between the look door or door handle
Aug 27, 2012 | 1989 Toyota Corolla Sedan
Changed door handle but door still won't open from inside
which door is it cos rear doors have a kiddy lock-when you work the handle can you feel any resistance,as if the handle is actually connected or is it 'floating' ?
Jul 06, 2012 | 1998 Toyota Corolla
Door won't open
You must have popped the door rod off.
Mar 03, 2018 | 1996 Chevrolet Suburban
Outside door handle won't open door
replace bar linking inside with outside handle undo handle remove square bar inspect both parts replace which ever is worn or broke
Apr 06, 2012 | 1990 Jaguar XJ6
97 Mercury Mountaineer driver side door won't open. Outside handle flops around; inside handle won't open door
Try a slim jim first, down the side of the window. Or AAA or locksmith. If no luck, remove the seat first. Find the screws and bolts around the door handle and arm rest. Most Ford's have screws around the outer side of the panel. I don't believe your's does. The panel lifts or pops off. Once the panel is off, you can reach down and open the door. Just a note. I have done some to where the panel came out in pieces.
Mar 14, 2012 | 1997 Mercury Mountaineer
1999 aurora front door won't open from outside with either remote or key won't open from inside with handle
If you can't open the door you can pull the corresponding seat to gain access and remove the inner door panel
Oct 29, 2011 | 1999 Oldsmobile Aurora
I need a diagram of the locking mechanism in my 2001 nissan sentra so that i can use a slim jim to unlock the passenger side door.
I don't have a diagram of the door but if you slip the slim Jim in over the top of the outside door handle it should catch on the latch bar. If you are doing this because the door won't open from the interior handle or the outside handle the problem most likely isn't the lock. The way that handle connects to the release it is held in place with a piece of plastic that breaks fairly easy. If that piece breaks the interior door handle won't activate the unlock function when pulled and you will have a heck of a time getting the door opened so you can get inside the panel to do the repair.
Oct 05, 2011 | 2001 Nissan Sentra
Faultless Naples Polished Brass Lever Privacy LYE701B-F Logo
Top Faultless Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Faultless Hardware and Accessory Expert? Answer questions, earn points and help others
