Volume knob broke off sony walkman - Audio Players & Recorders
Sony walkman volume
spray 90% rubbing alcohol from a spray bottle into the volume button area push the button reapeatedly or, turn the knob back and forth then: let it dry for about an hour then try to use it the control should be clean and working again.
Dec 03, 2013 | Audio Players & Recorders
The volume knob from my right computer part Rev A00 broke off. Computer model Dell dimension 2400. Can I get a replacement knob and where?
Sounds like you broke the volume control knob for your speakers (Likely A215s)
Best bet, new pair of speakers as they don't sell replacement parts for the speakers themselves
Apr 24, 2010 | Dell Dimension 2400 PC Desktop
Sony NWZ B135F Walkman won't disconnect
  • In mac open Disk Utility
  • Select the volume named WALKMAN
  • Hit UNMOUNT
  • Disconnect the player
The trouble is that the player doesn't respond to the comand EJECT in this process a loop started unmounting and seconds later mounting the volume again.
Hope this helps
Jan 06, 2009 | Sony Walkman Video NWZ-A815 Digital Media...
W880i not ringing or message alert
Ok, Might seem like a daft question but is it on silent?
I'm guessing you chekced this already but it's easy to miss.
The first thing to check is whether it will make any sound at all - this is a good guide as to whether the speaker is broke or just settings are wrong. Being a Walkman phone you might have some tunes on it so see if they play. Do this through the walkman/media player feature as apposed to the ringtone area.
If they play then you know it's still working and some settings need changing. If not your speaker might be broken.
If the speaker works then you need to check the ringer volume. this can be done from MENU/SETTINGS/SOUNDS&ALERTS/RING VOLUME - this then needs to be set using left and right to go up and down.
After this is set test call the handset to see. If still no luck change the ringtone to another tone - something built into the handset preferably - might be a faulty tune. If still no luck check the the number calling the handset has not got any sound preferences - i.e. no tune when call received. If still no luck it might be broke...
hope this helps some what...
Mar 15, 2008 | Sony Ericsson Walkman® W880i Cellular...
Battery Life Problem
Broke, but you can Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware.
Wizard.
Jul 06, 2007 | Sony Network Walkman NW-A3000 MP3 Player
 Grubhead
Grubhead
