Question about Kitchen Appliances - Others
I have a clogged Shark super steamer.
When I press the trigger button down I do not get any steam. I have already tried using a paperclip to unstuck the nozzle, with no luck.
Thank you
  • dmhufman Mar 31, 2009
    no steam when trigger is pressed. Don't see a clog, red light is on, and unit is hot, but no steam.
I have had a Shark Steam Mop for about 8 months now & all of a sudden it stopped producing steam. I was using it this past weekend & it produced steam as usual then all at once it stopped. When I push down on the handle to make the steam, it does nothing. No sound or steam. I have always used distilled water as well. Any ideas? Could it be clogged. The unit doesn't appear to get very warm now either. Thanks!
Posted on Mar 29, 2010
I had the same problem with mine and just fixed it yesterday.
take off the lid
lift the rubber seal and remove the screws
remove screws & black cover where attachments go on
the place that the trigger pushes to push out steam is a goldish colored button made of metal
i tapped mine with a hammer and it works perfectly again
although a 'friend' stole my hose and i can't figure out how to replace it, so mine is pretty useless. i can't figure out how to contact the company.
Posted on May 15, 2009
  • tbear498
    tbear498 Aug 05, 2012
    thanks!!...now mine works great!
  • Rob Cole Sep 09, 2013
    With you both tapping this golden colored button made of metal is attached to a golden nut. when this is loose, you will loose pressure. Titan it up with a spanner "properly". Another reason it may mal-function would be the build up of calcium deposits (which build up fast with "hard" water). I have half filled the main unit with vinegar and left it for about 12 to 15 hours. Plugged it in and let it boil away for about 20 minuites. I then pressed the trigger on the end of the hose and I got some pressure coming out, but not allot. I kept on repeating this until I retrieved the appropriate pressure. It is now fully working. Treat this gadget like your household kettle and it should serve you well..... :-)
Solution #2 is right on, all you need to do is free up the rod by removing the 2 screws in the front and the two on top, use a pair of snap ring pliers to get the odd screw loose. Once it is all open, move back and forth with a hammer and punch, spray some lube and it should be fine. Only use distilled or bottled water and leave the top off when not in use.
Posted on Dec 28, 2009
I am trying to "unclog" a shark hand held steamer. I removed the end cap, pulled off the rubber stopper on the top and removed the one phillips head screw. However, the other screw is different looking...not a phillips head. How do you removed this in order to tap on the metal chamber?
Posted on Nov 01, 2009
Put some C|LR with water and leave it overnight next day it will be as good as newone
Posted on Apr 04, 2010
Here's the website where you can order parts, etc. and a toll-free number:
www.sharkcompany.com
1 (800) 798-7398
Hope it helps!
Posted on Sep 29, 2009
Do you use distilled water?
Posted on Jun 14, 2010
    Problem Solver:
  • 5 Answers
Http://www.sharkvac.com/home.aspx
You can order parts i.e. (replace that hose beautiful685) , technical assistance, etc.
Posted on Jul 05, 2009
  • helen totman
    helen totman Nov 17, 2013
    what a great website! I bought one of these yesterday at thrift shop for $4.00, has all attachments, heats right up but won't spray. (why at the thrift shop I guess:), With all these great questions and answers, I think I know what to do. Thanks!
Shark Super Steamer
The steam generator is defective.
Aug 28, 2016 | Euro-Pro Shark Super Steamer
Gets super hot but steam won't come out.
i have a simular steamer made by a different company. it used to work when i had first gotten it, but i think one time that i had plugged it in for a long period of time without using it has caused the plastic parts under the trigger that releases the steam flow to melt. so now the steamer that i have still heats up really hot but when i try to push the button it does nothing, no steam will come out of it at all... so i think my mistake was plugging it in without using it for too long, making it now inoperable basically garbage. sorry to say
Apr 17, 2014 | Scunci 52067 Handheld Steam Vacuum
Shark steamer wont work. Green button came on and went off. No steam. Have used steamers for long time. What do I need to do?
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it maynot be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the Shark Manuals that you need.
heatman101
hhhk
Aug 17, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Shark steam pocket mop little or no steam.
aHi,
heatman101
a
Jun 04, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
I believe the steam may be trapped in steamer, as it isnt steaming up like usual, just acts like a wet mop. Is is clogged? Maybe because I didn't use distilled wwater?
heatman101
lo
Oct 06, 2009 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Shark Euro pro mop the ligt wont turn on anymore.
my husband fixed my shark steamer by taking it apart and testing it wire by wire .the problem ?a fuse hidden inside the unit..unscrew the screws and get inside the steamer .at the bottom of the steamer there is a gold orange foil looking piece .under that is a small fuse .unless you can find another fuse just cut that one off and rewire the wires together .shark now comes on
Sep 27, 2009 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Kitchen Appliances - Others Logo
8,486 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
