Question about Dryers
My ceiling fan fmy143 cannot do a speed from 2 to 3, it still run very slow
The fan can switch on but the running very slow. remote no problem, can use.
    Genius:
  • 1,617 Answers
Check your capisator. That's the little black box with wires going to the pull chain switch. If it looks like it's expanding or smells like it's burnibg then it needs to be replaced.
Posted on Apr 20, 2013
SOURCE: Hampton Bay Ceiling Fan At Slow Speed
I recently replaced my hampton bay fan for the same reason (slow at all speeds) and discovered scorched and melted capacitors and wiring inside the fan. My suggestion is to stop using fan and replace immediately.
Posted on May 11, 2008
worldvet
  • 859 Answers
SOURCE: Trying to replace 3 speed ceiling fan switch
The black goes to the L connection the others are a guess. You can do this two ways. Connect the colored wires in any sequence and then see what switch sequence give you high and lowest, the other one will be medium. Once you determine that, mark the wires with a piece of masking tape as high, medium and low. Otherwise you connect them, turn power on and use a multimeter to see which color gives you the highest voltage and which gives you lowest. Since you aren't comfortable using live wires and a meter, go with the first option and use the process of elimination to find the wires giving you the speeds you need to find the highest and lowest. Next, you need to determine how your switch sequence works. First pull has to give you highest speed. so you may end up wiring them in reverse if your first attempt is backwards. There is a reason the first pull needs to be highest, it powers up the motor so you can then chose a lower setting. A low setting first will over tax your motor and wear it out eventually as it has to work harder at first.
Let me know if you need further clarification and perhaps this is all you need to get fixed.
Regards,
Worldvet
ps I checked on the Internet of a wiring diagram and I bet you did tok all to no avail.
Posted on May 27, 2008
  • 4 Answers
SOURCE: harbor breeze ceiling fan
Your voltage is probably too low, probably a bad wire or source. Let me know if it worked.
Or take a look at the link given here... http://www.ceiling-fan-wizard.com/harbor-breeze-ceiling-fans.html
Posted on Nov 21, 2008
johnny5846
  • 379 Answers
SOURCE: ceiling fan remote will not turn on light
common problem , i went to home depot and bought a new remote for my hunter fan , and it worked again , salesman was very knowledgeable and helpful . thanks. explain the problem to him , he can help .
Posted on Dec 30, 2008
SOURCE: Hamilton Bay Remote Control Ceiling Fan
Rempte light comes on but does not activate fan or light?? thanks
Posted on Apr 22, 2009
My fan is running slower than before.
You probably have a bad capisator. That's a black box with wires going to the pull chain switch.
Apr 03, 2013 | Hunter 52" Ceiling Fan With Light And...
On its own went from low to high speed and can't slow it down
Windings in the motor shorted out or the switch shorted out.
Sep 11, 2012 | Hampton Bay Ceiling Fan. Altura 68 in....
My hunter remote control ceiling fan doesn't go real fast. the highest speed is what a normal fan would do on medium. is there a fix?
if you have pull chain switches in addition to the remote control, your pull chain switch may be set to Medium, which would make the fan run on a maximum of medium speed.
May 16, 2010 | Hunter 52" Ceiling Fan With Light And...
It only runs in low speed. Has remote
make sure that the pull cords have not been pulled and set to low speed, it should be set at the fastest speed and slowed down by the remote.
Oct 27, 2009 | Hampton Bay 28206 Lazerro Bronze Ceiling...
My ceiling fan isnt working right
dont you have a three position pull switch on the unit like a three-way light bulb or if you have a remote controlled fan it should have it on the remote control
Sep 24, 2009 | Encon Industries (78018) Ceiling Fan
HUNTER ceiling fan remote works with fan but not light
Unfortunately, you either have a faulty reciever or remote. A replacement will cost $30-$40 at homedepot2.gif. And it doesn't matter which is faulty because you can't purchase them seperately anyhow.
Sep 08, 2009 | Hunter Fan Co. 60 In.Brushed Nickel...
Ceiling fan only operate in slow speed, the medium/high not work
either you do have a defective running capacitor, or fan motor,or try lubricating the fan bushing.
Aug 06, 2009 | Dryers
Hampton Bay ceiling fan - will not reverse
It sounds like the direction switch has a broken connection on the "reverse" side.  Should be an easy fix (but you might need a soldering iron).
Dec 07, 2008 | Kitchen Appliances - Others
Ceiling Fan only spins 1 speed
assuming you havent messed about with the wireing it can only be the pull cord switch fault or the motor is on its way out
Jul 25, 2008 | Dryers
Aug 10, 2007 | Hampton Bay 52 In. White Redington...
Dryers Logo
287 people viewed this question
Top Dryers Experts
