Question about Samsung Series 4 32-inch UN32EH4000 720p LED HDTV
How to connect Samsung led tv model ua32c4000p to 5.1 channel 1000w dvd home theater system
Thin red line running from top to bottom of screen
What is this thin red line that is on my screen whenever my ...
https://answers.yahoo.com/question/index?qid...
Sep 23, 2010 - There is a very thin red line going from the top of my computer screento the bottom, ... If it's a single-pixel-wide red line from top to bottom it's a failure in ....have thin red lines running down the screen??some are thicker than ...
Thin Vertical Red Line [Solved] - Acer - Displays - Tom's Hardware
www.tomshardware.com > Forum > Displays
Tom's Hardware Guide
Jul 12, 2013 - 5 posts - ‎2 authors
hi all i am having a Thin Vertical Red Line on my Acer LED moniter ... the screen is having a part fail(cable or the screen/control board it self.).
Why is there a straight vertical line going from top to bottom on ...
forums.androidcentral.com > ... > Samsung Galaxy S6 edge
Apr 15, 2015 - 7 posts - ‎4 authors
Just bought the Samsung Galaxy s6 edge yesterday. After I charged the cellphone for the first time and turned it back on there was this straight.
Jan 26, 2016 | Samsung UN60ES6100 60-inch LED TV
LG LED LCD TV-I had no sound and a black screen, replaced the main board, still the same
IT is not wise to attempt repairs on LED TVs. They rarely work, and you end up replacing the unit anyway. The newer units have the LED drivers connected directly to the LED screen and there is no way to repair/replace them. Board swap/replacement is tempting, but overall the lost time versus the cost is often not worth it. Sets today are only designed to last 3-5 years. The manufacturers use the minimum rated electronic parts to ensure failure and thus a steady stream of replacement buyers. Some don't even make it out of warranty, but the manufacturers are willing to risk the cost in order to ensure that the planned obsolescence continues. Gone are the days of a set lasting 10-12 years or more. Take that into consideration when buying a replacement and only get what you need. Buying newer features that are not in full use yet only costs more and by the time you get the benefit of them, its time for another new set.
Jan 13, 2016 | LG 47LV4400 47 Class LED HDTV - 1080p,...
I can't get the tv to have the surround sound work
This effect varies greatly from one set to another, it may only barely perceptible.
Dec 25, 2014 | Sony DAV-TZ140 Home Cinema System Home...
How do I turn off the starting sound on a Samsung series 7 tv?
On your Samsung remote. Press the MENU button. At the botttom of your screen you have the setup selections. Scroll over to the SOUND option and select that, A menu should appear and toward the bottom of the menu you should see MELODY. Scroll down to that and select ON or OFF...
Nov 02, 2014 | Samsung UN50ES6500 Series 7 LED 3D 1080p...
AE 1000E HOW TO OFF THE MUTE
Just figured this out on accident actually. Hold down the lower left button for 3-5 seconds and it should turn mute off. Hope that helps
Feb 22, 2014 | Casio AE1000W World Time Sports Mens Watch...
TV has recently began displaying 2 images slightly offset from each other with lines. I absolutely love this tv plz help!
you have a digital problem..ive narrowed it down to 2 boards..the Main Bd..and the Tcon board..here are the purchasing details
http://www.shopjimmy.com/samsung-bn95-00496b-t-con-board.htm
http://www.shopjimmy.com/samsung-bn94-05038b-main-board-for-un40d6000sfxza.htm
looks like the main board is on backorder..id replace that first..its most suspect..lemme know how it goes
Feb 14, 2014 | Samsung Un40d6000sf 40" 1080p Hd Led Lcd...
Samsung 55" turns ON/OFF by itself and will not connect to wifi network
I have the same issue. I read and watched online tutorials about the compositors but after opening the set up I was unable to find any that had gone bad. I was able to upgrade the software by using a USB thumb drive but the issues are still there. I'm thinking of swapping out the motherboard and/or the power board next to see what the fix is.
Feb 24, 2013 | Samsung UN55ES7100 55" Class Smart TV 3D...
Samsung Series 4 32-inch UN32EH4000 720p LED HDTV Logo
29 people viewed this question
Top Samsung Watches Experts
 Mikey
Mikey
ray gallant
Are you a Samsung Watch Expert? Answer questions, earn points and help others
