Question about Minolta bizhub 350 Black and White Copier
I have problem with total counter in my copier konika minolta bizhup -210, how get codes to reset counter. Please help? Thank you.
  • 1 more comment
  • i_12188 Mar 11, 2009
  • i_12188 Mar 12, 2009
    DEAR PREMIUM TEAM,
    CAN YOU SENT MANUAL INSTRUCTION FOR BIZHUP 210.
    WE HAVE'NT ANY INFORMATION ABOUT THIS COPIER.
    WITH REGARD
  • i_12188 Mar 13, 2009
    THANKS FOR MANUAL
    Genius:
  • 1,239 Answers
Hi Check that KONICA MINOLTA bizhub  is selected in the Print Using ...... Click the [Initialize] button to reset the settings to their defaults. ......
Posted on Mar 11, 2009
  • ABHISHEK.C
    ABHISHEK.C Mar 11, 2009
    see on of these codes or what
    1.Details Subject:
    C-255A (C255A), C-255B (C255B), C-2559 (C2559) or C-255C (C255C) at power up.
    Description:
    C-255x code at power up.
    Solution:
    CAUSE: The K (black) IU (C-255C) has failed. The M (Magenta) IU (C-255A), Y (Yellow) IU (C-255B) or C (Cyan) IU (C-2559) is not fully seated or has failed.
    2.Description:C2551, C2553, C2555 or C2557 codes.
    Solution:
    CAUSE: Toner is not supplied due to abnormal position of coupling.
  • alauddin840
    alauddin840 Mar 02, 2013
    thank u for help....... r u right.....
    Brigadier General:
  • 3,614 Answers
Ei,
heres is the MANUAL, just download it right there
Posted on Mar 12, 2009
  • micromaster
    micromaster Mar 13, 2009
    N.P. your Welcome.
    Thank you for using fiXya.
    micro~
    Master:
  • 404 Answers
You cant reset the total counts "per 1000"
    Genius:
  • 1,550 Answers
Here is the reset procedure for counter
Must go to initial mode. Remove compact flash cover on top right side of machine. Press “warm restart” switch. When display shows a “.” on the left side, press “3.” Enter the service code; default is 8 zeros 000 000 00. Press “End.” Shut power and turn back on.
Hope this helps.
    Brigadier General:
  • 8,619 Answers
Hi!
In the right side on control panel, beside LCD contrast currsor is situated a small hole. Insert a pick in this hole until copier is restarted.
  • 1 more comment
  • Rylee Smith
    Rylee Smith Mar 12, 2009
    Try pressing the stop button for 1 minute and it will reset the counter. You can also look the manual for your refrence---
    Minolta bizhub 350 manual
    Thanks
    Rylee
  • Rylee Smith
    Also try pressing the reset key(Last Key in the top right corner).
    Also see page 4-18 in the manual i provided you.
  • Rylee Smith
    If that doesn't help then check your HV card and roller, clean them and again reset the machine.
    If still not able to do it then enter the service mode by---
    1. Utility
    2. Counters
    3. stop 00 stop01
    4. With regulator zoom function you want yes
    5. look for f8
  • Minolta Master
  • 19,396 Answers
I will see if the ink counter procedure is available online.
W to reset web supply of bizhub 750 konika minolta
First has the web been replaced. if not going to get bad image problems, have to go to service mode then counters a clear web roller.
Mar 03, 2015 | Konica Minolta bizhub 750
How to solve M2 in bizhub 164
Konika Minolta BizHub 163 - Error Code M2
Press the Utility button,
then Stop 0 0
then press again Stop 0 1
then scroll to Clear Data, and then Supplies Data and clear.
You must be aware that clearing this counter clears the drum, developer and other counters.
Feb 23, 2014 | Minolta bizhub 200 All-In-One Printer
Error c 3451 en konika minolta bizhup 184
You have a fuser problem, It is not heating up correctly.
Feb 04, 2014 | Konica Minolta bizhub C250 All-In-One...
Konika minolta bizhub 215 error code m2
You need to go into the service mode and then reset the supplies life counter.
Feb 02, 2014 | Konica Minolta Office Equipment & Supplies
C0F32 Minolta bizhub 210 and 211
C0f32 that means ATDC error, when toner amount in developer is uneven then this code will display, so you have to replace the developer and do the atdc auto adjust the code will remove.
please always mention the copy counter and life of consumables every time when ask the qustion.
Sep 15, 2012 | Konica Minolta DiALTA Di183F Copier
Konika minolta bizhub 350 Error c3451
error c3451 is abnormal heating temperature. al you have to do is reset the machine. open the back cover and on the main board look for a micro switch. press it will the machine is turn on. i hope this will help you.
Sep 16, 2011 | Konica Minolta bizhub 350 All-In-One Laser...
How can i reset m2 bizhub 211
I Have a Konika Minolta bizhub 211. I had been trying this solution for repairing m2 call. but the code is appear till now. anyone help me. please give me solution step by step.
Thanks
Mar 05, 2011 | Sharp AR-5320 Black and White Copier
Minolta bizhub 350 Black and White Copier Logo
574 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
