Question about Kenwood Car Audio & Video
Ic 3 of kac-721
Stereo power amp.
4 Suggested Answers
  • 733 Answers
SOURCE: i got a 4 gauge power wire w a 20 amp fuse hooked
make sure you run your power and ground wires opposite of the rca/speaker wires. you tend to pick up alternator noise when all wires are bunched up together. Also, make sure you have a good chasis ground to the amp, and the stereo has also a good ground. good luck
Posted on Sep 05, 2009
SOURCE: leads for old kenwood car stereo amps
Hey wdalley69, I've got the KAC-8070. My setup has the crossover module for it.
Posted on Feb 27, 2010
  • 9 Answers
SOURCE: KAC-8070 kenwood 4-channel power amp
Audio section
Max Power Output (4 ohms, 1kHz)
Rear 70W + 70W
Front 35W + 35W
Max Power Output (4 ohms, 1kHz, 10% THD)
Rear 45W + 45W
Front 25W + 25W
Max Power Output (4 ohms, 1kHz, 1& THD)
Rear 37W + 37W
Front 20W + 20W
Frequency Response (-3dB)
Rear 2 Hz ~ 100 kHz
Front 5 Hz ~ 50 kHz
Posted on Jun 24, 2010
How to bridge a kenwood kac-9105d
Are you referring to something like this, using two different amps? It is a mono amp, meaning there's one amp in the box.
"KAC-9105D also has a Dual Mono Drive connection that allows you to strap two KAC-9105D amps together to power a single subwoofer."Quoted fromhttp://www.kenwoodusa.com/Car_Entertainment/Amplifiers/KAC-9105D
Here's a link to a page out of the Yamaha Sound Reinforcement book. the top shows a stereo amp (1 box, two different amps inside) hooked up to drive two different speakers, which is known as 'stereo' mode.It then shows the two amps hooked to the opposite sides of the same speaker, which is known as 'bridge' mode.http://books57.net/ampOuts.gif
Any help?
Feb 24, 2012 | Kenwood Car Audio & Video
The red light on my kenwood stereo amp KAC-628 will not turn on. I was wondering which wire is causing this to happen?
the power wire or the remote wire check ur fuse in ur power wire if thats good check your connection to the battery if thats all good its ur remote wire located in the back of ur head unit
Mar 16, 2010 | Kenwood KAC-628 Car Audio Amplifier
Leads for old kenwood car stereo amps
Oct 27, 2009 | Kenwood Car Audio & Video
I got a 4 gauge power wire w a 20 amp fuse hooked up to a kenwood stereo/bridgeable amp 350 watts max power model #kac~6295 it just dnt sound rite any sugestions?
Sep 04, 2009 | Car Audio & Video
KAC-9104D output terminals
This feature allows the amp to be paired to any stereo. The input may be in stereo but the amp then changes it back into mono using sound from both sides. Hope this answers your question.
Jul 23, 2009 | Kenwood KAC-9104D Car Audio Amplifier
920 Watt Kenwood Amp wont power on
Connect the remote wire to an accessory wire on your stereo.
Jul 08, 2009 | Kenwood KAC-9152D Car Audio Amplifier
KAC-7202 will not put out sound. Put in other amp works.
When you switch on the amp did the main amp ic produce heat. If does not change the main amp ic.
Feb 13, 2009 | Kenwood KAC-7202 Car Audio Amplifier
KAC-9152D AMP TURNS OFF AFTER 2-3 MINS.
when your amp cuts out,is it when your stereo is produceing a long low note.if it is then the problem lies within the power distribution from the battery.as your sub pulles a long low note it draws a lot of power and sometimes the battery cant supply the power fast enough and the amp cuts out. useing a power cap is one way to solve the problem,but the best option for you to use becouse your running high powered amps is to have a sepparate battery for your audio using a split charging system.when your car battery is fully charged a relay swiches the power so that it charges the audio battery,so your auio system will have constant power without putting stress on your car battery. you can get thes from all good audio shops. hope this helps you.
Feb 25, 2007 | Kenwood KAC-9152D Car Audio Amplifier
Car Audio & Video Logo
16 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
